#15 | |
Drives: BLue 2013 frs
Front timing cover itself is pretty new. ~ 3K-4k miles. The teeth have some light scoring. Measuring at the stock oil dummy light location. Plunger didn’t just fall out easily. It was stuck until i used another tool to push it out, now i have to hit the housing to make it fall out. Plunger has light scoring. |
#16 |
The pump gears don't look good, but I still suspect the plunger is the culprit here. If there's wear, it will have a light polish, no scratches, and should slide right out.
With that low of a mileage on it, assuming it was all done on the same oil filter? That should tell the rest of the story. This engine definitely saw cold start debris going through it. |
| Tags |
| engine block, oil pump |
| BRZ fuel pump wiring question | Clash0901 | Engine Swaps | 16 | 06-23-2020 04:03 PM |
| Fuel Pump Assembly Question | amanzoli | Issues | Warranty | Recalls / TSB | 21 | 01-09-2018 07:25 PM |
| AEM 320 Pump installation question | Gixxer86 | Engine, Exhaust, Transmission | 0 | 10-11-2015 12:35 AM |
| Question to whomever has installed the DW 65 fuel pump... | Sportsguy83 | Engine, Exhaust, Transmission | 24 | 01-18-2015 10:08 PM |
| Question for any amateur/pro mechanics here... | Sport-Tech | Other Vehicles & General Automotive Discussions | 4 | 08-14-2014 02:55 AM |
