Old 04-03-2023, 12:52 AM   #1
norcalpb
norcalpb's Avatar
2013 USB Port vs 2017 USB Port
It looks like in 2017 the BRZ/86 ditched the aux port, but does anyone know if the 2017 usb port charges at a higher amperage than the 2013 version?
I believe 2013-2016 ubs port charges at .5amps. It's really slow.
Pics for reference.
2013:
2017:
Old 04-03-2023, 08:53 AM   #2
gkubed
gkubed's Avatar
Drives: 15 ZN6, 97 NA8, 87 AE82, 78 MX32
I do not see your pictures
gkubed is offline   Reply With Quote
Old 04-03-2023, 12:22 PM   #3
Racecomp Engineering
I see it. Don't have an answer but it's a good question.
- Andrew
norcalpb (04-03-2023)
Old 04-03-2023, 12:26 PM   #4
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I though that port was just to feed the radio?
DarkPira7e (04-03-2023)
Old 04-03-2023, 12:45 PM   #5
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
The zenki won't pass HDMI
Old 04-03-2023, 07:07 PM   #6
norcalpb
norcalpb's Avatar
Oh no! Not sure how to fix it.
I thought that port was just to feed the radio?
Yes it is for the radio but some usb ports obviously charge faster than others. Just seeing if they upped the amperage at the refresh year.
I only have HDMI 2.0 on the BRZ, can’t do 120hz @ 4k with such a small engine.
The Following User Says Thank You to norcalpb For This Useful Post:
bcj (04-04-2023)
Old 04-04-2023, 12:44 PM   #7
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I put a USB stick with a e85 tune on it into the port and started the car, but nothing happened? Help
Originally Posted by humfrz
I'm old and lazy
Old 04-14-2023, 12:55 AM   #8
RACECAR go brrr!
Custom Switch Panels!
RACECAR go brrr!'s Avatar
Drives: 2015 Subaru BRZ Series.Blue
Interesting question. Hopefully it's still just as useless, so more people have an excuse to swap it out for one of my excellent customizable switches :P
Order your own custom Toyobaru switch panel at www.racecargobrrr.com!
RACECAR go brrr! is offline   Reply With Quote
The Following User Says Thank You to RACECAR go brrr! For This Useful Post:
norcalpb (04-15-2023)
Old 04-17-2023, 03:49 PM   #9
norcalpb
norcalpb's Avatar
Luckily your switch is half the price of the OEM charger lol. I’m going to assume it’s still as useless as before, instead of charging at 2.1A like the (plug and play?) Tom’s “high performance” charger.
Searching For a replacement USB port for the factory port for aftermarket radio Kutanks Electronics | Audio | NAV | Infotainment 20 08-21-2021 09:12 PM
Re-pin ODB port stevo585 Software Tuning 6 01-08-2017 09:43 PM
USB port? nickhabi Electronics | Audio | NAV | Infotainment 13 09-02-2014 05:57 PM
USB port help _B_ Electronics | Audio | NAV | Infotainment 2 01-01-2014 10:36 PM
BRZ & USB Port brz007 Electronics | Audio | NAV | Infotainment 14 04-14-2013 09:06 PM
