Old 09-02-2014, 04:56 AM   #1
nickhabi
Drives: Not yet
USB port?
Does the FRS 2014 have a USB port that connects to the audio system? Hoping to play MP3 off the USB. Can't find anything online about it.
Thanks
nickhabi is offline   Reply With Quote
Old 09-02-2014, 05:01 AM   #2
TJ3000
Drives: MT Raven Black FRS
Ya it's by the mission tray next to the shifter
TJ3000 is offline   Reply With Quote
The Following User Says Thank You to TJ3000 For This Useful Post:
GreenMonster (09-02-2014)
Old 09-02-2014, 05:21 AM   #3
nickhabi
Drives: Not yet
Fair enough. Thanks
Old 09-02-2014, 09:00 AM   #4
Don't leave your phone, player, pad, etc. plugged in and sitting on the passenger seat though as it will set off the seat belt alarm. I was baffled the first time it happened.
Old 09-02-2014, 09:16 AM   #5
Shady195
Drives: '13 10 Series FRS #1203
@Tcoat holy shit I'm not the only one. It only happens when my phone is plugged in, doesn't matter if it's the USB port or a cigarette lighter charger. At first I thought maybe it was sitting just right and the pressure switch had like a point where if anything on the seat would set it off if it didn't weigh over a certain amount. After putting various items on my seat I realized it was just my.pligged in phone. My only thought it some sort or frequency given off when plugged in that trips the seat up
Sent from my SM-G900A using Tapatalk
Shady195 is offline   Reply With Quote
Old 09-02-2014, 09:30 AM   #6
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Originally Posted by Boosted2.0 View Post
Its not a weight sensor - its a new technology that utilizes an electrical capacitance based sensor. It uses electrical capacitance to measure the body mass of an individual sitting there. Hence electronic devices that transmit like cell phones may give false readings. By the same token however, a 200 pound lump of platic would probably not turn the light on.
If you make your passenger piss them selves - it will actually set a DTC. (Seriously - it has a code that sets for the passenger seat cushion being wet)
http://www.ft86club.com/forums/showp...5&postcount=14
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
The Following 2 Users Say Thank You to @Art_Mighty For This Useful Post:
Dadhawk (09-02-2014), WhiteFRS69 (09-02-2014)
Old 09-02-2014, 09:35 AM   #7
Originally Posted by @Art_Mighty View Post
Like he said!
Didn't read about it until after it happened to me though.
Old 09-02-2014, 11:03 AM   #8
GreenMonster
Just doing research
GreenMonster's Avatar
Drives: 03 Acura CLS 6MT
Didn't realize it was called a mission tray... learn something new everyday here
GreenMonster is offline   Reply With Quote
Old 09-02-2014, 11:06 AM   #9
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Also don't leave your phone, player, pad on the seat while away from the vehicle. It can cause the passenger window to break and your device to disappear.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
The Following 4 Users Say Thank You to Apoc For This Useful Post:
8R6 (09-02-2014), FRSNewb (09-02-2014), Jyn (09-02-2014), WhiteFRS69 (09-02-2014)
Old 09-02-2014, 11:34 AM   #10
TStafford
TStafford's Avatar
Drives: 2015 FR-S Ultramarine Metallic
I bluetooth music as it does not work with my Samsung S3 via USB.
TStafford is offline   Reply With Quote
Old 09-02-2014, 12:27 PM   #11
HMMMM Odd! Is there a TSB out for that? Don't let the nay sayers get a hold of that info or you will soon see that FRS are now no good for another reason!
Old 09-02-2014, 04:31 PM   #12
carma143
carma143's Avatar
Drives: Toyota Highlander; Subaru BRZ (SWP)
It doesn't work with my GS4 either. I just use Bluetooth with it charging through the cigarette lighter plug with a thick 5-inch micro USB. The GS4 lays in the center console.
carma143 is offline   Reply With Quote
Old 09-02-2014, 04:45 PM   #13
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
yea i dont understand,
ill throw my cell phone on the seat and the seatbelt light will go off, ill put my lunch box or clothes on it and its fine
Old 09-02-2014, 04:57 PM   #14
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
It does, but don't let your mother use it.
Manic is offline   Reply With Quote
OBD2 Port RJ_ AUSTRALIA 33 08-25-2016 10:25 PM
USB port help _B_ Electronics | Audio | NAV | Infotainment 2 01-01-2014 09:36 PM
SOLD OEM USB/Aux port abutterman Interior Parts (Incl. Lighting) 2 07-14-2013 09:45 PM
BRZ & USB Port brz007 Electronics | Audio | NAV | Infotainment 14 04-14-2013 08:06 PM
my BRZ doesnt have a USB port, what should i do? chenshuo BRZ First-Gen (2012+) — General Topics 35 03-02-2013 05:31 PM
