| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
#43 |
Drives: 2023 BRZ
In your picture, the rubber hose supplied with the AOS goes all the way over the OEM plastic tube to the 90* elbow just above where it joins the intake. But check out my picture. There is a "stop" on the OEM plastic bit the Killer B rubber hose is supposed to slide over. This prevents me from sliding the hose all the way to the left just before the elbow. I tried to highlight the extra length on my car in the picture with two red lines. I realize this isn't rocket surgery, but wonder if you've seen this before. And, if so, what do you think the best way to make this fit is? Right now it pushes the AOS out of what I think is its intended home, and the drain of the AOS rubs on some wiring.
Director of Rocky Mountain 86CUP
#44 |
| The Following 3 Users Say Thank You to KillerBMotorsport For This Useful Post: |
#45 |
Drives: 2023 BRZ
Thanks I hadn't seen that previously.
| The Following User Says Thank You to Pat For This Useful Post: | Wally86 (03-01-2024) |
#46 |
Drives: 22 BRZ
@KillerBMotorsport Any update on the oil pan for the gen 2 cars? Starting to schedule lots of events for this season and I'd love to have it on the car.
#47 | |
Drives: '23 BRZ Limited
I wouldn't expect it to be available any time soon.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
#48 | ||
It's a complex part and what we're finding is that it's not the oil pan that's the low hanging fruit. Most of the oil is in the upper pan, which is very complex and expensive, but a lot of oil sloshes into the timing cover. We're going to attack what appears to be the low hanging fruit on the oil control front. We're also going to be testing the oil flow and pressure. I think AVCS causes a lot of the pressure drop 'issues' people are seeing, which is common with Subaru engines using oil pressure to manipulate cam position. We'll defnitely keep the forum posted on our progress. |
#49 |
Drives: GR86
If you forget to drain these and they fill up to capacity what happens?
| The Following User Says Thank You to nomtimesthree For This Useful Post: | Wally86 (03-01-2024) |
#50 |
LMGTFY
Drives: 13 FRS, 91 Miata
| The Following 4 Users Say Thank You to x808drifter For This Useful Post: |
#51 |
Drives: BRZ 2018
Anyone has fitted the catch can on first gen car?
| Verus Engineering Air Oil Separator - Information and Release | VerusEric | Engine, Exhaust, Transmission | 127 | 07-08-2023 08:40 AM |
| Killer B Motorsport 2022 BRZ Dyno Plot with Oil Pressure and Temp | KillerBMotorsport | BRZ Second-Gen (2022+) — General Topics | 50 | 10-29-2022 08:36 AM |
| Killer B Motorsport Carbon Fiber Strut Braces | KillerBMotorsport | Groupbuys | 17 | 10-25-2022 11:05 AM |
| FREE Delrin Shift Knob - Killer B Motorsport | KillerBMotorsport | BRZ Second-Gen (2022+) — General Topics | 56 | 04-27-2022 07:32 AM |
| High Flow Oil Pickup by Killer B Motorsport | KillerBMotorsport | Engine, Exhaust, Bolt-Ons | 4 | 04-26-2022 10:51 AM |
