Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 03-04-2023, 05:34 PM   #43
Pat
Pat's Avatar
Drives: 2023 BRZ
Originally Posted by KillerBMotorsport View Post
The Killer B Motorsport Dual Catch Can AOS system is designed to remove excess oil vapor from crankcase gasses before they reach your intake. Doing so keeps your intake and valves cleaner and maintains proper octane levels. We do this using a vortex system that is efficient without limiting flowrates, unlike baffled units.
Our Performance Dual AOS configuration places the AOS's infront of and behind the intake manifold. This setup is intended for high performance track use.
-Light weight
-3D printed from automotive grade reinforced plastic
-Comes in Single or Dual configuration
-Looks OEM
-Easy to drain
-Installs in less than 20 minutes
Single $129
Dual $249
I just tried installing the AOS on the intake tube, but the intake on my 2023 BRZ looks different than the intake in your photo. Check it out:
In your picture, the rubber hose supplied with the AOS goes all the way over the OEM plastic tube to the 90* elbow just above where it joins the intake. But check out my picture. There is a "stop" on the OEM plastic bit the Killer B rubber hose is supposed to slide over. This prevents me from sliding the hose all the way to the left just before the elbow.
I tried to highlight the extra length on my car in the picture with two red lines.
I realize this isn't rocket surgery, but wonder if you've seen this before. And, if so, what do you think the best way to make this fit is? Right now it pushes the AOS out of what I think is its intended home, and the drain of the AOS rubs on some wiring.
Old 03-04-2023, 07:22 PM   #44
KillerBMotorsport
KillerBMotorsport's Avatar
Step 2 & 3
Killer B Motorsport Dual AOS - BRZ GR86 Installation Instructions
KillerBMotorsport is offline   Reply With Quote
Old 03-04-2023, 07:26 PM   #45
Pat
Pat's Avatar
Drives: 2023 BRZ
Thanks I hadn't seen that previously.
Old 03-10-2023, 03:30 PM   #46
Tr4ck_day
Drives: 22 BRZ
@KillerBMotorsport Any update on the oil pan for the gen 2 cars? Starting to schedule lots of events for this season and I'd love to have it on the car.
Tr4ck_day is offline   Reply With Quote
Old 03-12-2023, 10:34 PM   #47
OkieSnuffBox
Drives: '23 BRZ Limited
There is a thread in the GR section about it, but suffice to say it's a small niche company that is still waiting on lots of testing.
I wouldn't expect it to be available any time soon.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
Old 03-13-2023, 09:08 AM   #48
KillerBMotorsport
^ this right here.
It's a complex part and what we're finding is that it's not the oil pan that's the low hanging fruit. Most of the oil is in the upper pan, which is very complex and expensive, but a lot of oil sloshes into the timing cover. We're going to attack what appears to be the low hanging fruit on the oil control front. We're also going to be testing the oil flow and pressure. I think AVCS causes a lot of the pressure drop 'issues' people are seeing, which is common with Subaru engines using oil pressure to manipulate cam position. We'll defnitely keep the forum posted on our progress.
Old 12-06-2023, 09:12 AM   #49
nomtimesthree
Drives: GR86
If you forget to drain these and they fill up to capacity what happens?
nomtimesthree is offline   Reply With Quote
Old 12-07-2023, 12:52 AM   #50
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Cars totaled.
Old 02-29-2024, 06:19 PM   #51
JIM THEO
Drives: BRZ 2018
Anyone has fitted the catch can on first gen car?
JIM THEO is offline   Reply With Quote
Verus Engineering Air Oil Separator - Information and Release VerusEric Engine, Exhaust, Transmission 127 07-08-2023 07:40 AM
Killer B Motorsport 2022 BRZ Dyno Plot with Oil Pressure and Temp KillerBMotorsport BRZ Second-Gen (2022+) — General Topics 50 10-29-2022 07:36 AM
Killer B Motorsport Carbon Fiber Strut Braces KillerBMotorsport Groupbuys 17 10-25-2022 10:05 AM
FREE Delrin Shift Knob - Killer B Motorsport KillerBMotorsport BRZ Second-Gen (2022+) — General Topics 56 04-27-2022 06:32 AM
High Flow Oil Pickup by Killer B Motorsport KillerBMotorsport Engine, Exhaust, Bolt-Ons 4 04-26-2022 09:51 AM
