Old 03-01-2023, 12:41 PM   #15
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by GrandSport View Post
My grand sport didn’t have one and it was definitely pulling a lot of hot air out. On cold days , the center of my windshield would fog up right behind it. I think the idea is that the air rushing in will build up pressure in the engine bay and the high speed air over the hood creates negative pressure. In the grill, out the top vent.
That’s why naca ducts there concern me. You’re not only feeding the hot air into them, you’re reducing/disrupting the low pressure air. Honestly, and this intuitively from someone who hasn’t been in a wind tunnel or even scientific field for two decades, that hood raises a lot of eyebrows.
Obviously, a flip will create more negative pressure, but it comes at the cost of drag.
I think I need air rushing to the coils, not removing more hot air.
Please note I said "extract efficiently," not "not work at all." Also not all cars have the same cooling arrangement. The way the air comes in, arrangement of the rads, and positioning of the ducts also has a large affect. From my own use, I can say that drag is negligible going off the speed at the end of a 1/2 mile straight.
If your goal is to cool the coils, maybe a naca over the coils and something below to deflect air over them may be something that would work better for you.
Old 03-01-2023, 01:05 PM   #16
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Originally Posted by RedReplicant View Post
How far do these extend from the hood surface? Greater than 3/8"?
The furthest forward vent is around 0.75” with the height decreasing at each blade behind that. Are you height limited with class rules?
kask2_6.0 is offline   Reply With Quote
The Following User Says Thank You to kask2_6.0 For This Useful Post:
RedReplicant (03-01-2023)
Old 03-01-2023, 01:14 PM   #17
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I've got four of the Verus ones in my hood, I can see them pouring heat out on grid and they leave dust trails on the hood behind the vents after events
It's cool to see them working. Though being a DGM car, I get bad water spotting on my hood behind the duct
Old 03-01-2023, 01:45 PM   #18
RedReplicant
Drives: None
Yeup, unfortunately. Could be trimmed, but I was curious out of the box.
RedReplicant is offline   Reply With Quote
Old 03-01-2023, 02:59 PM   #19
Kelse92
At the track
Drives: '14 FRS - Former e92 M3
I'm surprised nobody has mentioned updating to the 2016+ coils and engine wiring harness. That fixes most of the coil-pack issues.
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
Kelse92 is offline   Reply With Quote
The Following 4 Users Say Thank You to Kelse92 For This Useful Post:
DarkSunrise (03-01-2023), finch1750 (03-01-2023), NoHaveMSG (03-01-2023), RedReplicant (03-01-2023)
Old 03-01-2023, 03:15 PM   #20
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
This I'm interested in.
BTW: Do you run brake ducts on the AP Endurance kit? I feel like it doesn't need it and I could have ducted those hoses to the coils. Also, what pads do you run? Ferodos last forever but they are very hard to modulate imo. And they're loud AF.
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
Old 03-01-2023, 03:19 PM   #21
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I just assumed he had already done it
Old 03-01-2023, 05:39 PM   #22
GrandSport
GrandSport's Avatar
what's the best way to go about this? and how much does it help?
Old 03-01-2023, 05:56 PM   #23
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
They don’t have the same coil packs I do. They also get new coils after every session or two.
I don’t have a “heat” problem. I have a TON of cooling and if anything it’s over cooled because my oil doesn’t get above 205, even in texas.
My problem is the coil packs popping.
So fix the problem not add more vents, or change a hood. Replace the engine harness & coil packs with the updated harness and coilpacks.
For the 2014 the updated engine harness part number (from Subaru) is: 24020AG080 and the coil packs are part number (from Subaru): 22433AA730
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following 2 Users Say Thank You to Opie For This Useful Post:
jflogerzi (03-01-2023), Kelse92 (03-01-2023)
Old 03-01-2023, 06:11 PM   #24
Kelse92
At the track
It's a useful mod, for the cost of a hood and new vents, this is probably a cheaper route to try first.
As far as brakes go, I've never run ducting, but I also am not a fan of the Ferodo pads, Cobalt Friction has been my Go-to for a few years.
Old 03-01-2023, 06:48 PM   #25
jflogerzi
jflogerzi's Avatar
Only way to fix this is to switch to the 2015 Style harness. The issue is in the harness and not the coil.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Opie (03-02-2023)
Old 03-01-2023, 07:00 PM   #26
GrandSport
GrandSport's Avatar
What about the coil pack conversion kits? seems simpler and easier.
https://subimods.com/products/otl-pe...NNKva8iplDDZc4
The Following User Says Thank You to GrandSport For This Useful Post:
Old 03-01-2023, 07:29 PM   #27
jflogerzi
jflogerzi's Avatar
You can give them a shot but its the harness going into those adapters that needs to be fixed in order to make it 100% Good. There is another long thread about this very topic in this section.
The Following 2 Users Say Thank You to jflogerzi For This Useful Post:
Kelse92 (03-02-2023), Opie (03-02-2023)
Old 03-02-2023, 01:25 AM   #28
GrandSport
GrandSport's Avatar
Do you remember where it was or the subject? I tried a search but coil and harness are kind of generic.
So just replacing the harness and using 24020AG080 fixes it (and obviously, the updated coils).
Coil pack issue, pls help Limitz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 09-19-2022 12:17 AM
Varis V1 CF Cooling Hood beltax90 Cosmetic Modification (Interior/Exterior/Lighting) 0 09-04-2020 07:33 PM
Strange issue - looking for suggestions - Possible DI or Coil pack problem sfruski Engine, Exhaust, Transmission 6 10-02-2018 01:07 PM
Overheating / Cooling System Basics Rennmeister Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 11-08-2017 05:16 PM
FS: VARIS cooling bonnet hood 2 Chris6052 Canada Classifieds 10 08-18-2017 07:59 PM
