Old 03-01-2023, 09:06 AM   #1
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Best track hood for cooling (coil overheating issue)
Is there a "best" hood to get? Mine has louvers in it already (but they are from eons ago before there were better options). So my options now are a new OEM hood + verus or just getting a whole new hood. By the time I get the hood and jack cut it and etc, I'd rather just get a carbon hood. It will match my carbon fenders, lol.
Just tired of overheating coils and killing track days. It doesn't happen OFTEN, but even twice a season is annoying.
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
Old 03-01-2023, 09:09 AM   #2
Pat
Pat's Avatar
Drives: 2023 BRZ
Look into Marsh Composites.
The Following 2 Users Say Thank You to Pat For This Useful Post:
Bergycheese348 (03-09-2023), whataboutbob (03-01-2023)
Old 03-01-2023, 09:13 AM   #3
whataboutbob
AutoX-10/10ths every run
http://www.marshcomposites.com/produ...86-gtspec-hood
Build thread:Here
Old 03-01-2023, 09:16 AM   #4
GrandSport
GrandSport's Avatar
I like the idea of positive pressure to let air in and negative pressure to suck it out... but it looks like the air coming out of the front will just go into the naca duct lol
And that's assuming you can even do that. I have a few intuitive (though far from substantiated) concerns about having positive and negative pressure zones so close to each other under the hood.
IDK. I assume there is a reason positive and negative pressure hoods aren't super popular/common.
Anyone have any experience with them in hot climates on dedicated track cars?
Old 03-01-2023, 09:22 AM   #5
KillerBMotorsport
KillerBMotorsport's Avatar
^ yeah that's not an ideal spot for naca ducts. That front exit duct should pull a ton of radiator heat out though. When I made that plunge on a shop STi there was a noticeable improvement in cooling, lower under hood temps, and even high-speed stability improved.
KillerBMotorsport is offline   Reply With Quote
The Following User Says Thank You to KillerBMotorsport For This Useful Post:
soundman98 (03-03-2023)
Old 03-01-2023, 09:24 AM   #6
Code Monkey
Drives: Subaru BRZ
This is good enough for GR cup cars... They have a resonator deleted with a block off plate so all the hot air can vent straight out...
Code Monkey is offline   Reply With Quote
The Following 2 Users Say Thank You to Code Monkey For This Useful Post:
Ohio Enthusiast (03-01-2023), RedReplicant (03-01-2023)
Old 03-01-2023, 10:07 AM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
My understanding(as a guy on the internet who eats pizza for breakfast) has always been that without a leading gurney flap on a hood vent, it is not going to extract efficiently. The air pressure under hood has to be greater than the air pressure on top(kinda sorta). If you look at the verus hood vents or the driveway labs, they have a gurney on the front to trip up the airflow and create a little low pressure zone. I have the driveway labs vent, and in the rain it actually causes the water to swirl inward on the windshield.
https://drivewaylabs.com/collections...ood-duct-large
https://www.verus-engineering.com/sh...ory=41#attr=64
The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post:
RedReplicant (03-01-2023), RT-BRZ (03-01-2023), soundman98 (03-03-2023), Ultramaroon (03-01-2023), Wally86 (03-01-2023)
Old 03-01-2023, 10:25 AM   #8
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Working on some vents for those looking to increase the size of existing vents to something more geared towards a track day car. I was in this boat as well. I don’t have CFD data or wind tunnel test results to back up any claims of increased cooling at this point. Would like to do some A to B track comparisons though.
kask2_6.0 is offline   Reply With Quote
The Following 3 Users Say Thank You to kask2_6.0 For This Useful Post:
NoHaveMSG (03-01-2023), RedReplicant (03-01-2023), soundman98 (03-03-2023)
Old 03-01-2023, 10:28 AM   #9
Ohio Enthusiast
Drives: 2018 BRZ
Yarn threads and a camera (or even just looking at them at speed) can serve you well.
Ohio Enthusiast is offline   Reply With Quote
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
kask2_6.0 (03-01-2023)
Old 03-01-2023, 10:40 AM   #10
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
That is first on the to do list! But at the moment I’m waiting on some other parts to get my car back up and running.
Old 03-01-2023, 10:53 AM   #11
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Attachment 218843
THis is what i should have done when cutting and installing my trackspec vents. Im are slightly off but you cant notice it from the outside. They get so much heat out especially when running my fans
Breadman is offline   Reply With Quote
Old 03-01-2023, 11:56 AM   #12
GrandSport
GrandSport's Avatar
They don’t have the same coil packs I do. They also get new coils after every session or two.
I don’t have a “heat” problem. I have a TON of cooling and if anything it’s over cooled because my oil doesn’t get above 205, even in texas.
My problem is the coil packs popping.
The Following User Says Thank You to GrandSport For This Useful Post:
Code Monkey (03-01-2023)
Old 03-01-2023, 12:02 PM   #13
GrandSport
GrandSport's Avatar
My grand sport didn’t have one and it was definitely pulling a lot of hot air out. On cold days , the center of my windshield would fog up right behind it. I think the idea is that the air rushing in will build up pressure in the engine bay and the high speed air over the hood creates negative pressure. In the grill, out the top vent.
That’s why naca ducts there concern me. You’re not only feeding the hot air into them, you’re reducing/disrupting the low pressure air. Honestly, and this intuitively from someone who hasn’t been in a wind tunnel or even scientific field for two decades, that hood raises a lot of eyebrows.
Obviously, a flip will create more negative pressure, but it comes at the cost of drag.
I think I need air rushing to the coils, not removing more hot air.
Old 03-01-2023, 12:39 PM   #14
RedReplicant
Drives: None
I've got four of the Verus ones in my hood, I can see them pouring heat out on grid and they leave dust trails on the hood behind the vents after events
How far do these extend from the hood surface? Greater than 3/8"?
RedReplicant is offline   Reply With Quote
The Following 2 Users Say Thank You to RedReplicant For This Useful Post:
GrandSport (03-01-2023), NoHaveMSG (03-01-2023)
Coil pack issue, pls help Limitz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 09-19-2022 12:17 AM
Varis V1 CF Cooling Hood beltax90 Cosmetic Modification (Interior/Exterior/Lighting) 0 09-04-2020 07:33 PM
Strange issue - looking for suggestions - Possible DI or Coil pack problem sfruski Engine, Exhaust, Transmission 6 10-02-2018 01:07 PM
Overheating / Cooling System Basics Rennmeister Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 11-08-2017 05:16 PM
FS: VARIS cooling bonnet hood 2 Chris6052 Canada Classifieds 10 08-18-2017 07:59 PM
