Old 06-18-2022, 02:12 PM   #1
Limitz
Drives: Black Scion FR-S
Coil pack issue, pls help
So I have a silly question, does the 2013 brz coil packs fit a 2013 Scion FR-S ? My guess is yes it should no problem, but online I’m trying to buy TRQ coil pack of 4 for $112 but it says it fits the 2013-2014 Subaru BRZ but when I click the Scion FR-S it says “this part doesn’t fit your car” any clue if they really are the same or a bit different ?
Limitz is offline   Reply With Quote
Old 09-19-2022, 12:17 AM   #2
Stephen02
Stephen02's Avatar
Drives: 2013 Manual Trans FR-S
Late response so you've probably already done the job but they should fit. I believe everything inside the engine bay is exactly the same between 2013-2016 BRZs and FR-Ss unless you count the front shocks and springs.
Stephen02 is offline   Reply With Quote
Coil Pack upgrade 2015 BRZ Mad-BRZ BRZ First-Gen (2012+) — General Topics 2 04-14-2019 11:53 AM
Coil pack options ROADRACER Engine, Exhaust, Transmission 14 12-24-2018 02:33 AM
Strange issue - looking for suggestions - Possible DI or Coil pack problem sfruski Engine, Exhaust, Transmission 6 10-02-2018 01:07 PM
FML: Tired of the same old coil pack issue? Enjoy your new rod knock... Yigal.K Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 07-31-2018 04:25 PM
Coil ignition pack D86Ellis Issues | Warranty | Recalls / TSB 7 09-20-2016 02:01 AM
