Old 02-11-2023, 08:48 PM   #1
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Pillowball Question
So, I'm installing Vorshlag camber plates and RCE T2s. After tightening the top nut on one side, the pillowball is at least twice as stiff as the other side when I manually tilt the plate. I cannot remember if it started stiffer or not, but I think I would have asked about that earlier if it had.
By stiffer, I mean side A moves with just firm finger strength, and side B needs me to grab and move with arm motion.
Anyway, does anyone know what is going on here? Did I mess up the pillowball somehow? Should I even care about them being mismatched?
Also: "Build Thread"
Old 02-11-2023, 10:13 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I don't think it's something to be concerned with, they probably need to wear in a little. The weight of the car will overcome any difference in friction resistance you can feel with your hands
Old 02-12-2023, 03:11 AM   #3
marco_mc22
Drives: Toyota 86
My Kw CS plates were the same even when new with oem kw pillow balls, not a problem, after some driving if you check them out you’ll find them loser, it’s normal.
Recently I replaced those bearings with some fresh new Rodobal and they’re the same with one side slightly stiffer, totally fine to me.
Also…tight the top nut with an air gun or electric impact, just a couple click, or they’ll be lose.
marco_mc22 is offline   Reply With Quote
Old 02-14-2023, 12:03 AM   #4
jflogerzi
jflogerzi's Avatar
Is it safe to check the top nut of the front suspension with a torque wrench once on the car? I know when I put the same camber plates on and compressed the springs on my T2s I used a ratchet strap to prevent the strut from spinning (2 man job). I don't want to damage my shiny new T2s
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
Old 02-14-2023, 03:33 AM   #5
marco_mc22
Drives: Toyota 86
From my experience torque wrench is not enough: I did the same the first time and then I marked the position of the top nut to the shaft, then I gave it a quick bus with an electric impact and the nut went another 1/8 of turn in, this removed the pillow ball noises when hitting bumps.
The best way is to use an impact while holding the shaft with a strap wrench as you said IMO, you don’t need anything crazy just a couple clicks of your tool and everything will be properly tightened.
Old 02-14-2023, 11:07 AM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Old 02-14-2023, 12:21 PM   #7
jflogerzi
jflogerzi's Avatar
So I did use my Impact as recommend by RCE unofficially
Old 02-14-2023, 01:57 PM   #8
Racecomp Engineering
Officially and unofficially I would highly highly recommend NOT using air tools lol. I'll leave it at that. Yes it's a pain to get that nut tightened...but please don't use air tools.
- Andrew
Old 02-14-2023, 02:02 PM   #9
Autoxer62
Contrary to the video you can use a torque wrench, you just need to use a crows foot socket or a torque adapter, this is exactly what they're made for. Amazon has a reasonably priced set, a friend gave me them some years ago and I've found them very useful. There is a minor adjustment to the torque value, but if you can put the crows foot at 90 degrees to the torque wrench there's no error.
https://www.amazon.com/Neiko-03324A-...dp/B000N7DHFK/
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace
Autoxer62 is offline   Reply With Quote
Old 02-14-2023, 02:23 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I've literally never seen a brz/frs camber plate that needed a crows foot.
Old 02-14-2023, 02:50 PM   #11
Ohio Enthusiast
Drives: 2018 BRZ
I just used a Harbor Freight passthrough socket set (and Allen wrench) with a luggage scale to torque down the nut.
Old 02-14-2023, 02:56 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I'm an idiot never mind
Old 02-14-2023, 02:57 PM   #13
jflogerzi
jflogerzi's Avatar
- Andrew
I did use a Torque Wrench to tighten it down 95% and gave it a few clicks from my Impact on low speed to confirm it was tight.
Old 02-14-2023, 05:39 PM   #14
jflogerzi
jflogerzi's Avatar
So based on this they recommend an impact and you can check after the Strut/Shock is on if using their top hats. I am confused here
Tein CSG FLA pillowball bearings replacement nkobns Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-16-2021 10:52 AM
LCA PillowBall Joint Rubber Cover Bach415 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-22-2016 02:01 AM
FS: Beatrush PillowBall Mounts (Front) Rabbit86 Canada Classifieds 2 08-24-2015 09:14 AM
Pillowball trailing and control arm bushings? Proof Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 03-17-2014 06:23 PM
Pillowball or urethane for lca / uca diss7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-23-2013 11:40 AM
