Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > CANADA > Canada Classifieds
Old 08-20-2015, 11:33 AM   #1
Rabbit86
Drives: Scion FR-S
FS: Beatrush PillowBall Mounts (Front)
Selling Beatrush PillowBall Top Hats/Mounts (Front), taken off from KW V3 used for one summer season.
They are great while I had them on, absolutely no problems with them at all. Much cheaper in price than Vorshlaq but not in quality.
SOLD
Description from FT86SF:
Beatrush engineers have redesigned the camber adjustment pillow ball mounts in order to handle extreme racing conditions and provide consistent camber angles. In order to change the camber angle from the top strut mounts, the damper must be attached to a bearing case and this assembly must be easy to adjust and move inside the top camber plate. Other aftermarket manufacturers use a standard flat camber plate with four small bolts holding the damper and bearing case assembly in place. However, this old design causes the camber plate to warp and shift over time from the strut load. Once this happens it is hard to make camber adjustments from the top strut mounts. Likewise a warped plate leads to inconsistent camber angles on the track.
In order to combat this issue Beatrush has redesigned the camber plate to handle everyday use as well as harsh road racing conditions.
Rabbit86 is offline   Reply With Quote
Old 08-21-2015, 01:13 PM   #2
Rabbit86
Drives: Scion FR-S
Bump
Old 08-24-2015, 09:14 AM   #3
Rabbit86
Drives: Scion FR-S
Pending Sale
WTB: Beatrush front bumper brace Summerwolf Want-To-Buy Requests 3 07-04-2020 03:12 AM
Beatrush Pillow Ball Mounts with KW V3? digital_assassin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 09-07-2015 11:21 PM
Group-N front mounts, anyone running these? Calum Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 03-06-2015 02:44 AM
FS: FRS/BRZ Beatrush Front Rebar reggie@circuitsoul Brakes, Suspension, Chassis 5 08-27-2014 08:01 PM
FS: FRS/BRZ TRD Intake System and BEATRUSH FRONT BEAM reggie@circuitsoul Engine, Exhaust, Bolt-Ons 10 12-16-2013 06:56 PM
