Old 09-23-2013, 08:01 AM   #1
diss7
Drives: AE86, 2x GT86, TE27
Pillowball or urethane for lca / uca
What would you use for a street car that sees drift use?
I was thinking urethane, in the interest of keeping nvh to a minimum; however at the same time I listen to the 2 way binding away and the cheap tyres chattering away, and I think that I've passed that point of working about NVH.
Urethane can't be all bad, considering all the other bushings are oem. Goin pillowball would not make sense in my eyes unless upgrading all bushings etc.
Thoughts..?
diss7 is offline   Reply With Quote
Old 09-23-2013, 11:40 AM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
If you grease the urethane bushings often there's no reason to worry about them binding. That said, how would you grease the UCA bushings with any sort of ease? Adding a grease fitting might work.
Scion FR-S Front Lip (Urethane) @ RacingSolution.com RacingSolution Exterior Parts - The Rest 24 09-01-2013 01:09 PM
Urethane Sway Bar Bushings? phm14 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 01-16-2013 10:32 PM
