Old 02-13-2023, 07:54 PM   #1
TylerM
TylerM's Avatar
Drives: 2013 WRB BRZ
Brz Fueling Issues/AFRs all over the place
Hey Everyone,
A little back story of the car. Its a 2013 and I turboed the car 2-3 years ago and it has 60k miles on it now. I haven't done any maintenance on it recently at all.
I have looked through a lot of the forums about fuel trims and other fueling issues but my issues never seem to be quite the same so I thought I would make a post on my own.
Ive had this issue for a few months now but it has slowly gotten worse over the past couple weeks.
First while cruising, the car would randomly go very rich (10-12 afr) and would bog/ almost die. this would happen for about 2 seconds then would go completely back to normal. I can never recreate it and it seems to be very random. At first this would happen every few weeks now its more like every few days and last 5ish seconds + sometimes it actually dies.
The AFRs are all over the place even while normal driving. They fluctuate between 11-17 while just cruising.
When I start the car and idle the AFRs also jump around and sometimes the car dies. I did a data log and my fuel trims are definitely off and have a very wide range. I will attach a couple of the logs.
Anyone have any ideas on what part has failed? also let me know if you need anymore information.
Thank you!
TylerM is offline   Reply With Quote
fueling, issues, runs bad
TC messing with fueling dholloway543 Software Tuning 31 08-06-2020 10:13 AM
Why AFRs and power change after first dyno run? mkodama Engine, Exhaust, Transmission 11 09-16-2017 01:14 PM
When to upgrade fueling? SirSpectre Forced Induction 5 10-06-2015 11:56 AM
Fueling Issue Simisimi Issues | Warranty | Recalls / TSB 5 12-22-2014 05:17 PM
How closely should AFRs be monitored when not WOT? post_break Software Tuning 23 06-10-2014 10:36 PM
