Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 11-11-2022, 11:44 AM   #15
Panda Grahams
Panda Grahams's Avatar
Drives: '22 BRZ
Since this thread has been revived. Here's a relevant new video:
Panda Grahams is offline   Reply With Quote
Old 11-11-2022, 02:46 PM   #16
ruturaj001
Drives: BRZ 2023
Originally Posted by tiger1964 View Post
For those of us that likely won't at the track... What does that mean for highway rpm in 6th gear at, say, 55mph & 65mph? Considering there are five other gears to choose from, relaxed highway cruising would be nice.
Bigger the final drive, higher rpm would be needed to reach certain speeds.
ruturaj001 is offline   Reply With Quote
Old 11-11-2022, 05:26 PM   #17
ZDan
ZDan's Avatar
Drives: '23 BRZ
1:42 "A little bit closer"? Nope, different diff gearing does NOT give you closer ratios. geez....
1:56 "SO much more power!"?! NO! You have exactly NO more power!
If you want a good illustration of exactly what going from a 4.1 diff to a 4.3 diff will do for you, here's what it did for the '17 BRZ vs. previous 4.1:
https://drive.google.com/file/d/0B78...YU3YzZ0JB/view
https://drive.google.com/file/d/0B78...uaXRfRl9j/view
0-30mph: '13 = 2.3s, '17 = 2.2s
30-40mph: '13 = 1.0s, '17 = 1.0s
40-50mph: '13 = 1.4s, '17 = 1.4s
50-60mph: '13 = 1.6s, '17 = 1.6s
60-70mph: '13 = 1.9s, '17 = 1.9s
70-80mph: '13 = 2.2s, '17 = 2.3s
80-90mph: '13 = 2.8s, '17 = 2.7s
90-100mph: '13 = 3.2s, '17 = 3.2s
30-100mph: '13 = 14.1s, '17 = 14.1s
WildCard600 (11-11-2022)
Old 11-12-2022, 12:05 AM   #18
ruturaj001
Drives: BRZ 2023
It's kinda feels like it does, with higher final drive you would be shifting more often than usual. It feels more like power due to effective gear. Technically both things didn't change but feel did.
Old 11-12-2022, 02:48 AM   #19
blackspike
blackspike's Avatar
Drives: Toyota GT86 racing red, Aero
When shifting into the next gear, you end up at a higher engine speed where there may be more torque.
In addition, you get higher wheel torques, which can be very good with a fast revving naturally aspirated engine.
The difference between 4.1 and 4.3 is almost irrelevant, but I will switch from 3.9 to 4.67... it will feel like a completely different car.
Especially with the very long steps between gears in the automatic transmission.
blackspike is offline   Reply With Quote
Old 11-12-2022, 03:00 AM   #20
blackspike
blackspike's Avatar
Automatic speeds with different FD.
As you can see, the automatic transmission has a much too high gear ratio and the gradation of the gears is very bad. I wouldn't change anything with manual transmission, but definitely with automatic transmission:
Old 11-12-2022, 07:52 AM   #21
tiger1964
tiger1964's Avatar
Drives: 2023 BRZ
True, but I was looking for an actual value in rpm at those speeds.
1964 Sunbeam Tiger, 2015 Porsche Boxster, 2023 Subaru BRZ
tiger1964 is offline   Reply With Quote
Old 11-12-2022, 08:09 AM   #22
ZDan
ZDan's Avatar
Drives: '23 BRZ
You will end up at exactly the same engine speed when you shift up. The rpm drop when upshifting is strictly due to the difference in the transmission ratios, this does not change with altered diff gearing.
With numerically higher diff gearing, you get slightly higher wheel torques at some speeds, but there will be speeds at which you have to be in the next higher transmission gear, where you'll have *greatly* reduced wheel torque. Net result is usually a wash. Changing diff gearing doesn't magic you any additional power/weight. You benefit at some speeds, but you pay the price at other speeds by having to upshift sooner.
Again, the rpm drop between transmission gears is going to be *exactly the same* with 4.67 gears as 3.9 gears. Strictly a function of the transmission ratios. If your 3rd gear is 1.404 and 4th is 1.00, and you shift from 3rd at 7400rpm, the rpm in 4th is 7400(1.00/1.404) = 5271rpm, no matter what the diff ratio is.
The Following 6 Users Say Thank You to ZDan For This Useful Post:
B T (12-21-2022), OkieSnuffBox (11-13-2022), PBR (11-19-2022), Stonehorsw (11-12-2022), Tatsu333 (11-12-2022), WildCard600 (11-12-2022)
Old 11-12-2022, 09:22 PM   #23
ruturaj001
Drives: BRZ 2023
If I understand it correctly, it should be inversely proportional, so rpm should be about 5% more.
Old 11-13-2022, 02:33 PM   #24
OkieSnuffBox
Drives: '23 BRZ Limited
It's painful how many don't understand this incredibly simple stuff.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
Needed: drive line shop in Houston for 4.56 final drive install - good experiences? Joesurf79 Southwest 3 03-10-2017 12:21 AM
Final Gear Ratios FNCrazy Engine, Exhaust, Transmission 28 06-30-2016 12:24 PM
WTB: 4.56 Final Drive jaorocks1 Want-To-Buy Requests 0 11-04-2015 07:36 PM
3.7 Final Drive GsxrMe Engine, Exhaust, Transmission 9 09-28-2015 07:55 AM
Tuning adjustments for different final drive ratios? PantsDants Software Tuning 9 01-29-2014 03:18 PM
