Old 11-05-2022, 03:31 PM   #1
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Whistling When Pressing Clutch
While accelerating in any gear past ~4000 rpm, I press the clutch to shift and get a warbling whistle noise that winds down over a second or two. It sounds a bit like a string trimmer or small propeller freewheeling after being spun up. First thought is TOB.
Can anyone confirm this, or is there anything else it might be?
59,210 miles 2013
Also: "Build Thread"
Old 11-05-2022, 03:37 PM   #2
Would be my guess. Do it before it gets too cold to work.
Spuds (11-05-2022)
Old 11-05-2022, 05:27 PM   #3
Spuds
The Dictater
Spuds's Avatar
I've got an insulated garage...
The Following User Says Thank You to Spuds For This Useful Post:
spike021 (11-05-2022)
Old 11-05-2022, 06:48 PM   #4
Funny how that never occurs to me.
soundman98 (11-05-2022), Spuds (11-05-2022)
Old 11-05-2022, 08:16 PM   #5
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
59,210 miles 2013
Shoot a video.
The Following User Says Thank You to blsfrs For This Useful Post:
Spuds (11-05-2022)
Old 11-05-2022, 08:51 PM   #6
Spuds
The Dictater
Spuds's Avatar
Originally Posted by blsfrs View Post
Shoot a video.
That would make too much sense!
I did some more research and tests and I am certain it is the TOB. Gives a bit of squealing any time I have the clutch depressed when stationary. I can free rev in neutral and drop back to idle without any weird sound. However, if I depress the clutch pedal on the way back down I get the whistling.
blsfrs (11-06-2022)
Old 11-05-2022, 09:22 PM   #7
soundman98
ProCrastinationConsultant
soundman98's Avatar
time for the verus fork, pivot point, and pdm case saver!
https://www.verus-engineering.com/sh...rch=fork#attr=
https://sixstarbernie.com/i-23179109...1990-2018.html
The Following 5 Users Say Thank You to soundman98 For This Useful Post:
blsfrs (11-06-2022), spike021 (11-05-2022), Spuds (11-05-2022), Ultramaroon (11-05-2022), x808drifter (11-06-2022)
Old 11-05-2022, 10:03 PM   #8
Spuds
The Dictater
Spuds's Avatar
Already in my shopping cart along with Verus LCAs. Hesitating because I'm also looking at what a clutch costs since I am going to be pulling the transmission anyway and was trying to retain a semblance of budget. Might need to give up some other stuff...
Never heard of the case saver, I'll look into it.
Is the common knowledge on clutches/flywheels to just stay OEM because it's the most reliable?
Old 11-05-2022, 11:43 PM   #9
Spuds
The Dictater
Spuds's Avatar
@soundman98 So I'm torn on the pdm tsk1. It's a good idea, but it seems like a pita to get a new bearing if I ever need to replace it again. You ever used this?
Old 11-06-2022, 12:05 AM   #10
radroach
Drives: car
@Spuds if you ever need a tsk1 replacement then just get another tranquil bearing. They've been making case savers for MT subarus for years.
Old 11-06-2022, 12:12 AM   #11
Spuds
The Dictater
Spuds's Avatar
Aren't they like $100 for a bearing when the stock one for our cars is $20?
Old 11-06-2022, 12:22 AM   #12
radroach
Drives: car
hmm well i guess you could just remove the sleeve and just go back to stock bearing.
The main reason for a tsk1 kit is if your case and snout got worn by a broken bearing. If you don't have much damage to the case, then just run a regular bearing.
The Following User Says Thank You to radroach For This Useful Post:
Spuds (11-06-2022)
Old 11-06-2022, 12:42 AM   #13
soundman98
soundman98's Avatar
I found it via a thread here somewhere. I just like the idea of getting a more durable metal on the trans snout. And more importantly, the sleeve is replaceable/sacrificial. If
the snout is aluminum, and the bearing is steel, it's just asking for galling up the snout, bad bearing or not.
The thread had indicated they re-stamped a Toyota throw out bearing for the kit. I'll see if I can find it.
I'm currently at 55k, so I'm getting to the point of starting to order stuff for the 60k service. I'm starting to consider doing this as well just to get it out of the way.
Spuds (11-06-2022)
Old 11-06-2022, 12:44 AM   #14
soundman98
soundman98's Avatar
Found it.
https://www.ft86club.com/forums/showthread.php?t=135955
Spuds (11-06-2022)
Clicking sound when Pressing Clutch Pedal Archetyp3 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 01-03-2020 11:57 AM
Whining noise when pressing clutch? cupcake917 Issues | Warranty | Recalls / TSB 14 03-12-2019 01:49 PM
RPM goes up to 1.5k when pressing the clutch while slowing down pcuerpo Issues | Warranty | Recalls / TSB 13 02-28-2018 01:37 AM
Is it bad to have my ankle fully extended forward when pressing the clutch? cat94 Scion FR-S / Toyota 86 GT86 General Forum 70 11-24-2016 04:10 PM
Upgraded Clutch now seems like TOB is pressing on pressure plate when not depressed. Rybot Issues | Warranty | Recalls / TSB 35 03-06-2016 08:23 PM
