Old 12-31-2019, 12:56 AM   #1
Archetyp3
Drives: 2014 Satin White BRZ
Clicking sound when Pressing Clutch Pedal
I recently noticed a clicking sound when pressing my clutch pedal in. It sounds like it is coming from under the car so I am guessing it is coming from the clutch assembly. Has anyone ever encountered this before?
Side note: The sound does not always trigger at the same point, sometimes its mid press sometimes its at the bottom of the press. It sounds almost like something is slipping though.
Current clutch setup: Exedy stage 1, Exedy oem fly wheel, versus forged clutch fork, versus billet fork pivot
Last edited by Archetyp3; 12-31-2019 at 02:09 AM. Reason: Embedded video didn't work, added link
Archetyp3 is offline   Reply With Quote
Old 12-31-2019, 10:25 AM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Easiest thing first. Try greasing the fork/pivot and see if it goes away. Sounds like it is binding.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Stomachbuzz (01-03-2020)
Old 01-01-2020, 11:18 PM   #3
Archetyp3
Well looks I am going to have to pull the transmission then >.> I have a feeling you are right. This did start happening after driving through about 3 inches of water during some flash flooding here in AZ so i'm guessing some water got into the bell housing and dried out some of the greased areas.
Old 01-02-2020, 02:31 AM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I believe @Ultramaroon has had luck greasing it through the access hole at the top of the bell housing. I have not tried it myself.
Old 01-03-2020, 11:57 AM   #5
Stomachbuzz
Drives: 2013 FRS
Some cars have a rubber dust boot around the clutch fork as it goes through the hole in the bell housing. You can pull the boot out, or squeeze a spray can straw through
Stomachbuzz is offline   Reply With Quote
clicking, clutch, pedal
Clutch Clicking/ Tapping sound nooserbtf Issues | Warranty | Recalls / TSB 3 05-04-2016 05:18 PM
Clutch pedal springy sound pdreams Issues | Warranty | Recalls / TSB 16 06-01-2015 02:33 PM
Clicking / tapping sound + fuel pump noise + clutch grinding Mikeez Issues | Warranty | Recalls / TSB 11 04-26-2015 11:19 PM
Strange clicking sound when clutch is engaged? synchromesh Issues | Warranty | Recalls / TSB 0 11-12-2014 12:13 PM
Pressing/releasing clutch pedal - audible click sound (not the clutchs switch tanner BRZ First-Gen (2012+) — General Topics 26 06-03-2014 08:24 PM
