Old 10-02-2022, 03:46 PM   #15
It's a good thing my post was vague, because I was WRONG!
Old 10-02-2022, 05:26 PM   #16
soundman98
ProCrastinationConsultant
soundman98's Avatar
if you want the right answer, just confidently state the wrong answer first.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
jbailey8748 (04-16-2024), Ultramaroon (10-02-2022)
Old 10-02-2022, 07:18 PM   #17
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
I know for a fact that the water in my toilet down here/under flows in the same direction as you guys up above.
The Following User Says Thank You to gen3v8 For This Useful Post:
soundman98 (10-02-2022)
Old 10-02-2022, 09:30 PM   #18
No pain, no gain.
Old 10-03-2022, 01:32 AM   #19
makinen
makinen's Avatar
Drives: Toyota 86
Originally Posted by Muskoka800 View Post
I’ll be installing the sensor block into the lower (larger diameter) rad hose.
The stock coolant temp sensor is located at the upper coolant gallery (14050 in the picture). Usually the hot side (upper rad hose) is used to get the temp as I know.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
Old 04-09-2024, 03:09 AM   #20
FR-Saliba
FR-Saliba's Avatar
Drives: 13' Scion FR-S 10 Series
Originally Posted by makinen View Post
just came across this thread while searching for the coolant flow for our car, is this quoted flow picture 100% legit, according to the flow if we close the coolant line going in the throttle body with a valve (not uploading picture link:https://images.app.goo.gl/bngpSJPjUkEMtN2y8)
for summer days it shouldn't cause any issue/problem, and reopen it for 2-3 winter months.
FR-Saliba is offline   Reply With Quote
Old 04-10-2024, 01:09 PM   #21
JD001
JD001's Avatar
Drives: Subaru BRZ
My head hurts, need to cool it down..
Old 04-10-2024, 06:40 PM   #22
Man, this topic had me humbled. Just never discussed it with anyone. Feels good to learn!
Old 04-10-2024, 06:55 PM   #23
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
So the porch of knowledge turned into the porch of humble?
Warm the car up with the cap off and watch.
Old 04-10-2024, 07:05 PM   #24
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Convivial porch of banjo noises.
Then a "Sproing -g-g-g! Ping!"
Followed by the precessing hubcap.
Ultramaroon (04-10-2024)
Old 04-10-2024, 11:39 PM   #25
Humility always has a seat at the porch.
Old 04-11-2024, 12:39 AM   #26
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Do you take it apart?
Ultramaroon (04-11-2024)
Old 04-11-2024, 01:16 AM   #27
lolfu
Sapphireho (04-11-2024)
coolant flow
How is it possible to lose coolant, if the coolant system in a car is a closed loop, ghostzfh Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 09-12-2020 02:09 AM
throttle body coolant flow direction mhiscott Forced Induction 3 07-12-2016 05:24 PM
WTB: OEM Mass Air Flow Sensor/Meter Assembly Air Flow Sensor driftking96 Want-To-Buy Requests 0 02-16-2016 04:57 AM
Coolant loss - Void Warranty/ Edit: coolant flush question BRZach Engine, Exhaust, Transmission 15 01-02-2016 09:21 PM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 06:56 PM
