Old 08-31-2022, 05:01 PM   #1
Lucero
Drives: 2013 FR-S MT
Lightbulb Oil pump question for the mechanics
just kind of an off-shoot on the chance that a mechanic dropped their tools to frequent this sub.
my oil pump has some issues:
this portion is a bit worn but since I'm rebuilding the engine I wanted to know if this is worth buying the entire housing or if it can be fixed.
Lucero is offline   Reply With Quote
Old 08-31-2022, 06:13 PM   #2
If you have any doubt buy a new one. Don’t go to all that trouble and expense just to cheap out on the very heart of the engine.
Old 08-31-2022, 06:18 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
In addition to what Tcoat said, people have a hard time getting that oil pump to seal properly after removing it from its chamber in the front cover. I would just get a new front cover, it comes with everything you need ( and won't be potentially gouged from being removed)
Old 08-31-2022, 07:32 PM   #4
KillerBMotorsport
KillerBMotorsport's Avatar
That pic is small, and you've not described what's worn out, so there's no way to know. Like Tcoat said, if it's questionable, don't risk it.
If there's a lot of miles, It's a good idea to replace it.
If the engine experiences a catastrophic failure, it's a good idea to replace it.
If it has low mileage and you want to save some money, and have some precision measuring tools, you can check the pumps dimensions to see if you're within service or at wear limits.
If you do buy a new pump, it's recommended to disassembly and check the bypass plunger for smooth action. The backplate screws should also have Loctite applied.
KillerBMotorsport is offline   Reply With Quote
Old 09-02-2022, 03:13 PM   #5
Lucero
Thumbs up
Thanks for the input, The car does have a of of miles 135k+; there is no way to replace that specific portion without buying the entire oil pump assembly which includes the housing so it comes down to having to spend $450+ for something that may or may not make a load of difference. The 'damage' though i'm not sure if it's standard wear, comes from the oil drive gear leaving marks on the oil gallery assembly, specially the pictured casting plate.
Thats being said, if the expense is going to happen then would there be a good after market option with better distribution/performance?
Old 09-02-2022, 06:22 PM   #6
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
Originally Posted by Lucero View Post
miles 135k+
I would replace it.
Old 09-02-2022, 07:07 PM   #7
Wear limits and inspection procedure are not in the manual. That's a first for me.
Old 09-03-2022, 08:40 PM   #8
KillerBMotorsport
Factory Service Manual
Old 09-03-2022, 08:43 PM   #9
KillerBMotorsport
The factory suby pumps have excess flow as-is. The best thing you can do is disassemble, check the bypass piston for smooth action, and reassemble with Loctite on the backplate bolts.
Old 09-03-2022, 08:55 PM   #10
Look in my sig line
Old 09-05-2022, 02:31 PM   #11
KillerBMotorsport
At home, but this is what I have handy. It's for an EJ but makes the point. Are the manuals you have links to actual FACTORY Service Manuals, or made by a third parts? What we use is created by Subaru.
FWIW, same type of pump is used on both engines.
Old 09-05-2022, 02:45 PM   #12
Let me know what you think after reviewing. I understand that they were ripped directly from TIS but your chart is what I'm used to seeing. I have a whole bookshelf full of FSMs for cars I and my family have owned. I'd gladly pay for hard copies of everything available for the twin too.
Old 04-17-2023, 05:39 PM   #13
fableluke
Drives: BLue 2013 frs
Been having oil pressure that seems low. ~5psi at idle around 176F. My thought was bypass piston is stuck open or isnt working correctly. Opened up the oil pump assembly to see some scoring in the oil pump gears. Not sure how to check bypass piston but i disassembled it. The plunger/piston took some help to get out but it somewhat moves smooth. I already have a new front timing cover but i was hoping to find something that would explain my low oil pressure. You know what could low oil pressure? Ive already pulled the pan off to look at the pickup tube and couldnt find anything.
Thank you!
fableluke is offline   Reply With Quote
Old 04-17-2023, 05:54 PM   #14
KillerBMotorsport
What is the mileage on that pump assembly? Looks to be some decent scoring. How do the rotor faces (teeth) look?
The bypass should move smoothly. Not somewhat smoothly, it should be smooth. It should also come right out. Is the plunger bore scored? Plunger itself have any wear?
Not uncommon, if a plunger sticks, it happens when cold and pressure is highest. as the oil warms, the plunger stays open and pressure will tank. 5psi at idle is LOW. What location were you measuring pressure at?
I would cut apart the oil filter just as a precaution in case there is more going on here.
engine block, oil pump
BRZ fuel pump wiring question Clash0901 Engine Swaps 16 06-23-2020 04:03 PM
Fuel Pump Assembly Question amanzoli Issues | Warranty | Recalls / TSB 21 01-09-2018 07:25 PM
AEM 320 Pump installation question Gixxer86 Engine, Exhaust, Transmission 0 10-11-2015 12:35 AM
Question to whomever has installed the DW 65 fuel pump... Sportsguy83 Engine, Exhaust, Transmission 24 01-18-2015 10:08 PM
Question for any amateur/pro mechanics here... Sport-Tech Other Vehicles & General Automotive Discussions 4 08-14-2014 02:55 AM
