Old 07-31-2022, 03:35 PM   #29
Fa20Toybaru
FA20ToyBaru
Fa20Toybaru's Avatar
Drives: Manual
Thank you for this post, I have been looking everywhere for a solution. I have the same vibration, in the rear of my vehicle. I have checked the balance of both rear tires, and also checked tire pressure for both rear tires. The vibration originally started at 67mph, that is now gone and the vibration starts about 80mph. I have been testing and since yesterday.
We pulled the axels, checked the LSD for any clearance issues. We have now marked all bolts to see if the vibrations cause any bolts to loosen up. I am concerned because i have gone through a checklist of things that could be wrong...and now i have found your thread thanks to another member.
So, if am correct, I am to check the alignment of the shaft, starting at the box and traveling all the way down to the LSD to see if there is a difference of more then 3 degrees. I am a little puzzled on adding the shims, what kind of shims would I look for? Also, could I just measure how off the shaft is using a leveler?
Fa20Toybaru is offline   Reply With Quote
Old 08-01-2022, 01:03 AM   #30
gpvecchi
gpvecchi's Avatar
Exactly, no more than 3 degrees for each joint, and no more than 1 degree difference between them. You can use a digital leveler, checking the engine tilt (use the pulley), the driveshaft tilt and the differential tilt.
Old 08-02-2022, 11:05 AM   #31
MX-5RACER
Drives: 1999 Miata
One thing people do not think about is side to side alignment. Not only should you have the correct pinion angle, but you should also not have a deviation side to side. You can use laser pointers to see if you have a side to side clearance issue that is putting the joints in a bind.
DJ
1999 Miata VVT swap "Maggie"
2013 BRZ "Nancy-Drew BRZ"
MX-5RACER is offline   Reply With Quote
The Following User Says Thank You to MX-5RACER For This Useful Post:
gpvecchi (08-02-2022)
Old 08-02-2022, 11:22 AM   #32
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
The differential input is off to the side and not centered to the transmission output.
Old 08-02-2022, 05:05 PM   #33
gpvecchi
gpvecchi's Avatar
I never thought of this, thank you. Anyway, the degree rule is still valid for lateral shift.
Just more measures and more difficulty to fix the issue.
1 Piece aluminum driveshaft Phothiraj Engine, Exhaust, Transmission 60 10-03-2016 05:53 PM
Does anyone track their car with a 1 piece DSS driveshaft? mhiscott Tracking / Autocross / HPDE / Drifting 3 08-10-2016 12:02 AM
Aluminum 1-piece Driveshaft Cjs_ Engine, Exhaust, Transmission 17 03-25-2015 04:45 PM
New The Driveshaft Shop Carbon Fiber 1-Piece Driveshaft Evasive Motorsports Engine, Exhaust, Transmission 1 09-24-2013 02:27 PM
