Old 10-01-2016, 12:48 PM   #1
Phothiraj
Drives: Lightning Red BRZ
1 Piece aluminum driveshaft
So recently I've been having some rattling from the driveshaft which is still the oem 2 piece driveshaft but all the play is actually coming from the driveshaft carrier bearing. Obviously nobody sells just the entire bearing, so I've been looking into a 1 piece driveshaft aluminum driveshaft sold by ft86 speed factory. But before making the purchase are there any reviews or suggestions. I'm not tracking the car and just using it for everyday driving. I am also on coilovers though.
Phothiraj is offline   Reply With Quote
Old 10-01-2016, 02:52 PM   #2
humfrz
hmmmm.......I haven't read about the OEM driveshaft going bad on a non tracked car .... ??
What part of the OEM driveshaft do you call the "carrier bearing" .. ??
How do you figure it's bad .. ??
a search will yield many thoughts on a one piece driveshaft.
humfrz
Old 10-01-2016, 03:09 PM   #3
Eighty 6
Newbie
Drives: Gt86
Same problem as u, but its under warranty, so they're changing the whole gear system. Hopefully it all goes well
Eighty 6 is offline   Reply With Quote
Old 10-01-2016, 03:24 PM   #4
Phothiraj
humfrz
so pretty much when I got underneath, where the front and rear piece connect. there is a substantial amount of play where now when I drive it rattles and vibrates when in gear, a rattle noticeable when accelerating. if I can measure by my eye on how much play it has from moving it up and down I'd say about 1.5-2inchs. I do want to try just replacing the bushing but idk if that would do the job atm.
Old 10-01-2016, 03:26 PM   #5
What "gear system" are they changing? How would it help the driveshaft from rattling?
Legit questions not flaming
Old 10-01-2016, 03:28 PM   #6
There is up to 2 inches of play in your driveshaft u joint? I would be having it towed to the dealer if still under warranty. It is not pretty when a u joint lets go.
Old 10-01-2016, 03:31 PM   #7
Phothiraj
it's been raining a lot here and it's just out of the powertrain warranty. but when I can get back underneath I will double check. almost positive it's the u joint though.
Old 10-01-2016, 03:39 PM   #8
humfrz
DANG! If that bearing in the center is allowing the driveshaft to move up/down 1"-2", I wouldn't drive the car at all ..... if it snaps the universal joint, it could "pole vault" your car right off the road.
Are you sure the bearing is bolted down tight .... ??
Come back.
Edit ..... I see ol Tcoat was on the case ......
humfrz
Old 10-01-2016, 03:43 PM   #9
DANG! If that bearing in the center is allowing the driveshaft to move up/down 1"-2", I wouldn't drive the car at all ..... if it snaps it could "pole vault" your car right off the road.
Come back.
humfrz
Yes!
The u joint right after the bearing only is designed for so much travel if the bearing is loose and it is traveling that much it could let go at any time. Unfortunately they never let go at low speed or torque. This comes from a guy that has snapped way more then his fair share of u joints.
Old 10-01-2016, 03:46 PM   #10
Phothiraj
Come back.
humfrz
it's literally the section right there where the t shape comes off. That's where all the play is coming from.
Old 10-01-2016, 03:47 PM   #11
Ultramaroon
not playing cards
Ultramaroon's Avatar
Guys, I think he's talking about the foam isolator in the pillow. OP, is it torn? Do you feel zero resistance until some contact point, or are you just realizing that the bearing floats in there?
Old 10-01-2016, 03:50 PM   #12
Phothiraj
so when I got underneath, I didn't notice anything torn apart but also I did not unbolt anything to get a closer look. I did check if the bolts were tight and they were. I'm just worried because I need to get it fixed asap obviously before it comes to worse scenarios.
Old 10-01-2016, 03:51 PM   #13
Phothiraj
when I do get home I will try to show even clearer where my play comes from.
Old 10-01-2016, 04:01 PM   #14
humfrz
It's my understanding we are talking about the driveshaft ...... not the axles.
Speaking of pillows ..........
Do you need a nap ...... or do I ......
humfrz
Axle-Exchange One-piece Aluminum Driveshaft ~ impressions slates74 Engine, Exhaust, Transmission 152 08-07-2021 07:39 PM
Aluminum 1-piece Driveshaft Cjs_ Engine, Exhaust, Transmission 17 03-25-2015 04:45 PM
New The Driveshaft Shop Carbon Fiber 1-Piece Driveshaft Evasive Motorsports Engine, Exhaust, Transmission 1 09-24-2013 02:27 PM
