Old 06-24-2022, 02:16 PM   #1
Keegster55
Keegster55's Avatar
Drives: 2017 Toyota 86
Cicada/clicking sound after installing factionfab Rotors/pads
Hey all, I just installed brand new factionfab rotors(FFA1.10038.1)(FFA1.10037.1) and pads(1.10066.1)(1.10067.1) and it seems like I’m running into some noise issues. The noise only comes from the rear drivers side of the car. The best I can describe it as is a cicada/ clicking sound, I can hear it while driving not even braking. I’ve read the slotted rotors can make a similar sound but it doesn’t make sense to why it’s only on one rotor. I’ve had them all off 4 times to make sure everything is correct, cleaned etc.
Keegster55 is offline   Reply With Quote
Old 06-24-2022, 08:40 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
could it be a wheel bearing?
Old 06-25-2022, 12:31 AM   #3
Keegster55
Keegster55's Avatar
I don’t think so, the sound started right after doing the brakes and I did check to see if the wheel had play in it. I’m stumped.
Old 06-25-2022, 12:06 PM   #4
soundman98
soundman98's Avatar
can you hang the caliper up and off the brake disc on the car safely, and then roll forward 20 feet? that would eliminate 1 of the options.
Old 06-25-2022, 01:32 PM   #5
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
That’s insane.
Lift the rear take it off and spin it by hand or start the engine and put it in gear if you want to try this OP. Idk what the solution is, video would help a lot.
ineedyourdiddly
wparsons (06-27-2022)
Old 06-27-2022, 10:56 AM   #6
wparsons
wparsons's Avatar
Did you clean/lube the slider pins on all the calipers? The one corner might be sticking slightly and dragging.
flickr
Old 06-27-2022, 11:27 AM   #7
Keegster55
Keegster55's Avatar
That’s insane.
I did nothing sounded out of the ordinary.
The Following 2 Users Say Thank You to Keegster55 For This Useful Post:
soundman98 (06-28-2022), strat61caster (06-27-2022)
Old 06-27-2022, 11:28 AM   #8
Keegster55
Keegster55's Avatar
I’ll definitely give that a shot. I didnt feel the need to do it at the time everything okay, but perhaps not.
Old 06-28-2022, 11:27 AM   #9
churchx
churchx's Avatar
Drives: 2014 GT86
Might be that you accidentally bent tin guard and now it's screeching?
Clicking sound above 2k RPM - helpppp slyphen Issues | Warranty | Recalls / TSB 6 09-10-2019 09:11 PM
Clicking sound on startup radroach Issues | Warranty | Recalls / TSB 2 01-17-2019 07:55 PM
FRS Clicking/Tapping sound DCStorm Issues | Warranty | Recalls / TSB 30 12-29-2017 10:59 AM
clicking sound? FR-Sky Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 11-26-2016 10:21 PM
Clicking sound when shifting into 4th? Marcbrz86 BRZ First-Gen (2012+) — General Topics 4 05-19-2015 09:52 PM
