#71 | |
| The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
#72 |
Drives: Crapcan
GruppeM Ram Air System Intake
My header would never clear that Gazoo intake.
#73 |
Drives: 2018 Subaru BRZ Limited with PP
Don't want to derail this thread... but I still don't get the obsession with OFT tune? ESPECIALLY when it comes to E85. Everyone that raves so much about it makes it sound like it's the absolute best bang for the buck. I just don't see how it comes even close. I mean how much does it really run for?? I got Ecutek with license and tune for about 750 after tax. I had the peace of mind of choosing ANY professional tuner out there that I preferred. I also have the peace of mind of fine tuning the car over and over again until I think it's perfect. I also get the benefit of the different maps and the extreme ease of switching between them. I also get the benefit of using flex fuel and never having to worry about how much of 93 or E85 I ever choose to fill.
For the what... few hundred bucks that I didn't get to save? Granted I went with a flex-fuel kit to add onto costs (about 500), but I didn't have to. It just seems like the far better bang for the buck to me. It also feels worlds safer to me knowing that I have one of the top tuners out there who will personally read my logs repeatedly and get my car to an optimal tune. Then you tack on the Shiv disappearing problems and it pretty much seems like a no brainer to me on what the best bang for the buck is. Am I crazy or missing something here? Are OFT tunes that much cheaper? |
| The Following User Says Thank You to Dzmitry For This Useful Post: | Tcoat (06-24-2022) |
#74 | |
I logged my canyon and track drives and could tweak and edit tunes easily on romraider to make as many adjustments as I wanted until I had each tune running exactly how I wanted. I created a tune for canyons at elevation. Had another more conservative tune for track days. Another for 91 and for 93. I could switch freely between tunes depending on what fuel I was using and where I planned to drive. I also could tell based on my logs the effect of each part I added (Mishimoto inlet tube, 2017 header, various catless and catted headers) and how my tune was compensating and adjusting to those parts. Not really sure how this all compare with Ecutek but I think $450 (or w/e it is now) for OFT is a bargain for everything that you’re getting (ots e85/91/93 stage 1 and 2 tunes, plus all the other tunes and maps available open source) plus the loading and logging and real time monitoring functionality. Probably the only downside was the customer service was very slow at OFT but you don’t really need them for much. I actually wish OFT would hurry up and release a product for the 2nd gens. Seeing how cheap e85 is right now compared to 91 is killing me lol.
2022 BRZ Build 2013 FR-S Build |
| The Following 4 Users Say Thank You to DarkSunrise For This Useful Post: |
#75 | |
Drives: '23 BRZ Limited
So are you REALLY trying to act like you don't understand why people would want to pick up a used OFT for $350 ($500 new) vs $1350 for an Ecutek tune and fuel kit? I never had any issues with my BRZ running E85 on the OTS OFT tune. Watched the parameters and saw no need to datalog to try to get another 4-5 whp out of it. Started fine in the cold and pulled strong with no knock and good fuel trims.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
| The Following User Says Thank You to OkieSnuffBox For This Useful Post: | Lantanafrs2 (06-23-2022) |
#76 | |
Drives: zd8 brz
If youre dumping $1k+ on an intake for a track car brz/86, you better be damn on the limit of the platform and be ready to jump ship into a something better or go FI with the brz/86. I grew up with vw's but am an advocate for NA motors having owned stuff like s2000s, ae86's, e36's, ITR's etc. Induction noise is very addictive. In fact ive only owned one turbo charged vehicle in my entire life and that was an STI. Out of every damn NA vehicle ive owned or worked on in the last decade, my mk6 golf was the ONLY car where an aftermarket intake made sense from a performance aspect. The OEM intake is routed right over the exhaust manifold and is notorious for having heat soaking issues. The cost of this GruppeM intake is a few hundred $$ cheaper than the Greddy ITB kit for the previous gen(not including install or tuning ofc) If you really care for induction noise, bling, and want to dump money into minimal gains, that ITB kit is perfect. Youll get more induction noise than youll ever want, youll be taking home awards at shows and if properly tuned, you might gain a tiny bit of power. in conclusion before i go too far off topic, i think the biggest issue with this GruppeM intake is that it doesnt make sense in any regard. It's $1600 for an intake on an NA vehicle where tuning isnt even unlocked yet. Intakes never show any reliable gains without tuning. Even if GruppeM wanted to show gains, they cant unless they somehow have unlocked the factory ECU and tuned the car with the intake. It's not that they didnt provide anything to back their product... its the fact that they cant because it literally isnt possible yet |
#77 |
Drives: 2013 frs red
My experience is that any swirl created before the throttle plate is gimmicky and will only confuse the maf anyway
| The Following User Says Thank You to Lantanafrs2 For This Useful Post: | Tcoat (06-24-2022) |
#78 | |
#79 | |
Drives: '22 BRZ
The D-Sport test was done vs the 2013 OEM intake. The 2017+ intake is better and so far I've seen *maybe* one intake outperform it by any statistically meaningful margin. A drop-in filter alone made 5-ish hp on an early intake. On a 2nd gen it makes like... 2 hp. Which is a MUCH smaller percentage gain when comparing 215whp to 165whp.
| The Following 3 Users Say Thank You to DocWalt For This Useful Post: |
#80 | |
Drives: 17 Asphalt 86
Had custom tunes done via forum members for less than $100. Ecutek is the superior tuning platform but for most NA stuff OFT is pretty decent. In retrospect I may have gone ecutek day 1 since @tomm.brz also does ecutek tunes and would have probably cost me same or less overall. |
| The Following User Says Thank You to RToyo86 For This Useful Post: | Dzmitry (06-27-2022) |
#81 | |
Drives: Crapcan
![]() The cool thing about OFT is it is great and simple way to get an improved tune. For DIY'ers it's also a lot of fun to play with. I spent a lot of time playing with the OTS tune and making changes to get my car running and make changes to it as I go. When I went flex fuel I had steve99 do a tune for my car buy I enjoyed playing around with it up until that point. It's not perfect but it does work pretty well.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | OkieSnuffBox (06-24-2022) |
#82 | |
What I haven’t seen, or missed if here, is that there are probably just as good gains to be had by tuning a completely stock engine as one with a gimmicky CAI. The stock tune is a compromise between power, mileage and emissions so room to improve any one of those at the expense of the others is there. The big difference between the gains to be had on the 86 and many of the older cars is that it already has a good CAI and header not an old school under hood intake and straight cast iron exhaust manifold.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | OkieSnuffBox (06-25-2022), Ultramaroon (06-25-2022) |
#83 |
Drives: JRSC BRZ SOLD
Wow I can't believe this got to 6 pages.
#84 |
Oh I doubt it is done yet.
Everything still needs to be repeated at least 6 more times to meet forum standards.
| The Following 5 Users Say Thank You to Tcoat For This Useful Post: | Dzmitry (06-27-2022), Jdmjunkie (06-25-2022), mycrors7 (06-25-2022), OkieSnuffBox (06-26-2022), PulsarBeeerz (06-25-2022) |
| '14 FR-S OEM Air Intake System w/ K&N Filter and Zeta Performance Intake Tube | SoCalArgento | Engine, Exhaust, Bolt-Ons | 4 | 02-06-2015 11:40 PM |
| Revolution x GruppeM Intake | TwinRz | Engine, Exhaust, Transmission | 15 | 07-31-2014 08:34 PM |
| aFe Dry intake system | FT-86 SpeedFactory | Engine, Exhaust, Bolt-Ons | 1 | 08-15-2013 04:13 PM |
| .: GReddy Air Intake System · Increases intake airflow · 4 Layer filter :. | Speed Element | Engine, Exhaust, Bolt-Ons | 14 | 05-20-2013 07:06 PM |
| FS: afe DRY intake system | Laika | Engine, Exhaust, Bolt-Ons | 2 | 02-28-2013 11:37 AM |
