Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 05-27-2022, 03:37 PM   #29
CincyJohn
Drives: 2022 MT Neptune GR86 Prem.
If you are admittedly ignorant on oil extractors then why argue it? If you don't want to use one cool, more than one way to skin a cat. Not everyone has a driveway they can use ramps or stands on so an extractor is a good substitute for a DIY'er that may be in a situation they can't safely get the car in the air. I've used extractors a lot, not for my personal stuff, and have never had any kind of failure with one that resulted in oil going anywhere but the reservoir. And yes, dipsticks go down into the pan, that is where the oil is.
I can't get my car on ramps. If I am going to have it in the air on jackstands I might as well take the opportunity to do a nut and bolt check and inspect things. I am not going to travel 3 hours and have a day cut short because of an issue that could have been easily caught crawling around under the car with a flashlight. I consider an oil change as part of a service, not one job.
Whatever, I don't give a crap if you want to use an extractor or not, I really don't. Heck, I'm not even saying they are bad - I was just explaining why I don't/wouldn't use one.
CincyJohn is offline   Reply With Quote
Old 05-27-2022, 07:51 PM   #30
Haust
Driver
Haust's Avatar
Drives: 2022 BRZ
Originally Posted by OkieSnuffBox View Post
You're sounding like a Karen right now. "I have no knowledge of X, but I'm going to tell you why it doesn't work."
You should take a break from the internet for a while.
This is like s30series in the BBK thread all over again and this guy is going on the same list.
Won't research extractors or even the engine, but has decided absolutely 100% that there is too much risk involved. Growth vs fixed mindset omg.
Haust is offline   Reply With Quote
The Following User Says Thank You to Haust For This Useful Post:
Jdmjunkie (05-27-2022)
Old 05-27-2022, 08:18 PM   #31
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
You act like a loose fitting plastic tube is pulling a ton of vacuum on the system. It isn't.
I read it as, "you only take an hour during an oil change service?" I usually spend more time then that since it is an opportunity to inspect the whole underside of the car while I have it on jackstands.
Isn't the point of the Fumoto valve to not have to put it on jack stands in the first place? I know I can change my oil by turning the wheel and flipping the valve.
2020BRZtS is offline   Reply With Quote
Old 05-27-2022, 08:19 PM   #32
2020BRZtS
2020BRZtS's Avatar
I like that you continue to attack me because you don't seem to understand modern vehicles.
An hour isn't a long time. The car needs to be up to temp, which in normal driving takes 15-20 minutes. Then pull it in the garage, get it on jack stands, pull the drain plug, give it ample time to drain. Then refill let it idle, ensure no leaks, then check the level again.
JFC dude, why do you try to fight anything that's ever said on this forum?
Someone needs a snickers.
Old 05-27-2022, 08:25 PM   #33
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You can get a pan under your car?
I thought it was just for ease of not having do undo the drain plug.
Old 05-27-2022, 08:52 PM   #34
jvincent
jvincent's Avatar
I was able to get a pan under my lowered 2013.
Haven't installed my valve on the 2022 yet.
The Following User Says Thank You to jvincent For This Useful Post:
NoHaveMSG (05-27-2022)
Old 05-27-2022, 09:01 PM   #35
2020BRZtS
2020BRZtS's Avatar
Yes. I guess I have a low profile pan. It also doesn't hurt that my arm is as thick as a pixi stix
Old 05-27-2022, 09:14 PM   #36
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I'm short in a lot of areas, I don't think I could reach it if my car was tall enough anyway.
Old 05-27-2022, 09:31 PM   #37
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Where did I say $55? You can't buy an OEM filter and 7 quarts of quality synthetic for $55. That's why I pointed out $10 more than it would cost me to do it myself. The 135 was a $95 oil change. $85 if I did it myself.
And I don't have to spend an hour in the garage, take the oil to get recycled, etc.
Modern BMWs don't have dipsticks. They pull the oil out through where the filter goes. Which is under pressure when the engine is running. The same place is used for oil extractors on Subaru's.
I'm sure you can find a reputable shop where you live.
I've never used an extractor...
Since we have a dipstick, would we go through there for the extraction?
Old 05-27-2022, 10:19 PM   #38
soundman98
ProCrastinationConsultant
soundman98's Avatar
the point of my fumoto valves have always been to better control the oil stream. i prefer to use the hose.
the specific reasoning is because i'll get everything lined up, and it'll either overshoot the pan no matter where i place it, or near the end, will undershoot the pan, and i still end up with oil on my driveway. or i'll move the pan halfway through to adjust for the stream, it'll catch on some crack i've never noticed and splash onto the driveway anyways...
STLBRZ66 (05-22-2023)
Old 05-27-2022, 10:26 PM   #39
2020BRZtS
2020BRZtS's Avatar
No doubt. I cover half the garage with cardboard cuz I'm bound to step in something and it would look like a crime scene when I'm done. I don't think I open the valve to full spill for the same reason. I still like the convenience of not having to pull out the jack. Oil changes for me are usually pull the plug and come back in two days to wrap up. I get sidetracked easily.
The Following User Says Thank You to 2020BRZtS For This Useful Post:
soundman98 (05-28-2022)
Old 05-30-2022, 09:48 PM   #40
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Originally Posted by CincyJohn View Post
I've actually had soda cups collapse from sucking on the straw, soo...
The Following 4 Users Say Thank You to Yoshoobaroo For This Useful Post:
2020BRZtS (05-30-2022), Decep (05-31-2022), NoHaveMSG (05-30-2022), soundman98 (05-30-2022)
Fumoto oil drain valve amelo BRZ Second-Gen (2022+) — General Topics 13 02-11-2022 10:54 PM
FS: Fumoto Drain Valve turbos86 Engine, Exhaust, Bolt-Ons 2 03-15-2017 07:41 PM
FS: Fumoto Valve jvenetto Engine, Exhaust, Bolt-Ons 6 10-01-2015 08:16 AM
Fumoto valve in the winter? Muskokan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 02-25-2014 01:06 PM
Fumoto valve for transmission? SurfAndSand Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 09-16-2013 12:01 AM
