Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 01-11-2022, 12:34 AM   #1
amelo
Drives: '22 BRZ
Fumoto oil drain valve
In pictures and videos I've seen of the 2022 BRZ, the undershielding is different from the previous gen in that the engine oil drain is covered. Has anyone tried to see if both the F108 and F108S Fumoto oil drain valves fit underneath?
amelo is offline   Reply With Quote
Old 01-11-2022, 07:48 AM   #2
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
I put F108S on mine and no issues.
dragoontwo is offline   Reply With Quote
Old 01-11-2022, 11:34 PM   #3
eyeballs
Drives: '22 BRZ
I've got the F108. Fits fine, though not a ton of clearance with the undertray.
eyeballs is offline   Reply With Quote
Old 01-12-2022, 12:32 AM   #4
Up4speed
Drives: 2023 BRZ Limited
I was considering using one, but after reading things like this:
https://www.subaruoutback.org/thread...roblem.378121/
I think it's best that I don't.
I have also read another thread, where a guy was told by a mechanic, that the valve will sometimes warp since it is brass, and it get's stuck, so to consider it permanent.
After all that info, I think I changed my mind, and I'll stick to the old fashioned way of removing bolt.
Up4speed is offline   Reply With Quote
Old 01-12-2022, 01:23 AM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
I dunno, seems like a very low failure rate. Normally if a product is crap, threads like that turn into a negative review where everyone piles on to the garbage product. That didn't happen at all, and fumotousa stepped in even, which is even rarer for a mfg to look into things.
I think your worry is unfounded.
Old 01-12-2022, 01:36 AM   #6
Up4speed
I agree to a certain point (and have used one in the past without problems).
But there are 4 other factors that helped me decide to not do it (at this time):
1- I want to track the car at HPDE events, so reliability is VERY important
2- I have a lift, so removing bolt isn't too bad
3- The way the valve sicks into the oil pan when installed, it leaves a little oil at the bottom
4- It drains slower
Don't get me wrong, it's a great device, and I'm sure that they are (mostly) reliable. I'm also convinced that they are great for those that have trouble accessing the drain bolt. It's just that I had a change of heart after the few reviews that I read. Before I read them, I was still not 100% on it due to the 4 reasons above, so it just pushed me enough to change my mind, that's all.
Old 01-12-2022, 08:46 AM   #7
otter
Drives: 22 BRZ
4- It drains slower
Just adding my $0.02 - I've had a Fumoto on 3-4 cars now, including cars that see track use, and all of them worked without issue. #3 on your list is really a non-issue as far as I'm concerned because you never get all the oil out of an engine when doing a change - the risk of having an extra teaspoon or two because of the valve is insignificant. #4 is valid - I usually open the valve then go do something else while it drains.
otter is offline   Reply With Quote
Old 01-12-2022, 08:51 AM   #8
Ohio Enthusiast
Drives: 2018 BRZ
The biggest advantage of the Fumoto for me is the ability to drain the oil when its hot. With the amount of oil I get on my hand when removing a drain plug I'd dread doing the old fashioned way on a hot engine. With the Fumoto I just need to be careful when turning the handle.
Ohio Enthusiast is offline   Reply With Quote
Old 01-12-2022, 08:59 AM   #9
Up4speed
I agree with this, that’s a very big benefit!
However, for me it’s a non-issue, as I mentioned, I have a lift with one of those drain pans that extend up to the car. It is a non-issue, I can pull the drain plug without a drop of oil anywhere, even when it’s hot. If I had to lie on my back with the car on ramps, I probably would get the Fumoto valve as well.
Old 01-13-2022, 01:47 PM   #10
Rossman
Rossman's Avatar
Drives: '22 BRZ, '17 BRZ (prev '13 FR-S)
You can also connect a tube to the quik valve so that you can direct oil flow, which is nice.
Rossman is offline   Reply With Quote
Old 01-13-2022, 03:29 PM   #11
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
4- It drains slower
I had a Fumoto from the 3rd oil change on my car to when I sold it in 2016.
About 6-8 track events each year, including the occasional off road excursion.
Never had any issues. New owner of the car still has it and still tracks it.
Never had any issues draining the appropriate amount of oil out of the engine. Even without the valve the engine won't drain 100% of the oil inside, and if I'm that paranoid I just change my oil more often.
As for slower... it's just an opportunity for me to inspect the rest of the car while it's up in the air.
YMMV.
Old 01-13-2022, 08:36 PM   #12
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Had the Fumoto valve for about 7 years on my BRZ now. No issues or complaints.
shiumai is offline   Reply With Quote
Old 01-17-2022, 03:43 PM   #13
KillerBMotorsport
KillerBMotorsport's Avatar
Fumoto valves are the first mod we put on every shop car and my own personal cars. Haves used and sold MANY of them and never once had any issues.
In the link Up4speed posted, that's just messed up and shows there is no such thing as perfection. I'm going to keep using them as I think that probability of an issue is extremely low. We have over the years tested other 'oil valves' that I will not use or recommend, so there are definitely worse units out there.
KillerBMotorsport is offline   Reply With Quote
Old 02-11-2022, 09:54 PM   #14
McMCOO
Anti-Social Media
McMCOO's Avatar
Drives: 24 GR86 Premium MT is on the way!
I installed mine just today. Clearance is fine. Mine is the short nipple version but I think the long version would actually clear the plate also. Just as importantly, once it was tightened down the lever is in a good position to manipulate.
McMCOO is offline   Reply With Quote
First Oil Change, Fumoto Oil Drain Valve oldnotdead Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 29 07-23-2021 12:39 PM
Where to buy Fumoto F-108 drain valve? FooisM AUSTRALIA 5 04-27-2020 08:39 PM
FS: Fumoto Drain Valve turbos86 Engine, Exhaust, Bolt-Ons 2 03-15-2017 06:41 PM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 07:36 PM
GROUP BUY: Fumoto Drain Valve Simon99 Mechanical Maintenance and Tools 8 03-28-2014 06:27 PM
