Old 09-14-2013, 05:05 AM   #1
SurfAndSand
8SiX
Drives: FRS 10series
Fumoto valve for transmission?
I have yet to poke my head under my car, but seeing how this valve would work for engine oil, would it be feasible for use on the transmission and gear box drain plugs also?
They offer different sizes of valves. Any idea if it will work or what size to use if it will work?
SurfAndSand is offline   Reply With Quote
Old 09-14-2013, 05:08 AM   #2
SurfAndSand
8SiX
Never mind. Ifi remember right, our transmissions have a magnetic drain plug. Probably don't want to lose that since the transmission fluid isn't filtered like engine oil
Old 09-15-2013, 11:01 PM   #3
alex_86
alex_86's Avatar
Drives: 2013 scion firestorm frs
well that and the fact that you dont change out your transmission fluid as much as you do your engine oil i mean its a 6:1 ratio.
alex_86 is offline   Reply With Quote
Fumoto valve quick question #87 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 130 11-21-2015 04:32 AM
help me decide: Fumoto Valve or Greddy MagDrain chenshuo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 41 09-10-2013 09:43 PM
Question about Fumoto valve Bleevin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 04-18-2013 09:27 AM
Installed Perrin shifter bushing & Fumoto oil drain valve zooki Engine, Exhaust, Transmission 23 03-31-2013 05:18 PM
FS: Fumoto quick valve Laika Engine, Exhaust, Bolt-Ons 1 01-08-2013 01:51 PM
