#15 |
I apologize for the cryptic post. Was trying not to muscle in on the pulley conversation. I don't know why the belt picks up that stuff. Maybe all longitudinally mounted engines do that to serpentine belts.
#16 |
ProCrastinationConsultant
yeah really doesn't make much sense, there's nothing obviously different about this setup than any other vehicle on the road. maybe the packaging/idler pulley radius' are smaller, which open up the grooves of the belt more for debris than other designs?
#17 | |
Señor Member
1974 TA22 Celica
2013 86 GT |
#18 | |
i found some 14ga 5/8"x1" spacer bushings that that need minor clearancing, but ought to add the clearance i desire to keep the retainer from getting scored up again.
#19 | |
Actually, looking again, I don't know exactly what to make of it, Dammit. Now I want to go look at mine.
#20 |
New one's are the same. Inner race is just shallower (3/1000?) than the retainer. A large flat washer(3/4" ID) held flat on the inner race visibly scuffs the lettering on the retainer collar.
They make 18ga spacer bushings that might be more preferable, my home depot only had 1 in stock though. I might try a different store to see if they've got more. It's just weird to me as every similar bearing like this I've come across commercially has a mounting surface recess machined into the contact surface so as to hit only on the inner/outer bearing surface, but steer well clear by a full 1/8" of the retainer.
#21 |
the pulley's definitely lost all their grease. they were rattling like a wrist trinket, but overall were still pretty solid.
definitely didn't help, probably would've cleared when new, but still not enough clearance IMO... i realized made a mistake when i picked the prettier pulley's. ![]() these definitely didn't clear, wouldn't even spin freely when tightened down. so the 18ga spacer bushings were a necessity, though honestly about 2x's the clearance i really needed. problem was the oem washer didn't fit. so i had to do some trimming. ![]() otherwise went in fine, no more squeaking so far, but seems like the other idler pulley under the alternator has some play now...
| The Following User Says Thank You to soundman98 For This Useful Post: | Ultramaroon (05-08-2022) |
#22 |
Drives: '20 BRZ tS (15/300) / '09 Scion tC
FWIW I replaced the idler pulley in the dryer as well and no more squeaks there either.
| The Following 2 Users Say Thank You to 2020BRZtS For This Useful Post: | soundman98 (05-08-2022), Ultramaroon (05-08-2022) |
#23 |
This is the lesson learned here. If a bearing makes any noise at all, if it isn't silky smooth, it's shot. Period.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | soundman98 (05-08-2022) |
| DRL worn out? | mrhandle | BRZ First-Gen (2012+) — General Topics | 4 | 08-10-2017 04:58 PM |
| Pulley install help.. Video inside | brzzy | Engine, Exhaust, Transmission | 4 | 04-27-2016 09:13 PM |
| Clutch worn already? | username404 | Engine, Exhaust, Transmission | 24 | 10-26-2014 01:15 AM |
| Worn Clutch? | Jakeedaman21 | Issues | Warranty | Recalls / TSB | 18 | 04-30-2013 03:06 PM |
| NEOPLOT Crank pulley Alternator pulley& Waterpump pulley | ANREX | Engine, Exhaust, Transmission | 10 | 10-25-2012 08:45 PM |
