Old 10-23-2014, 04:17 PM   #1
username404
Drives: 2013 BRZ Limited GB 6MT
Clutch worn already?
1. At 5th and 6th gear around 55mph when accelerate too fast rpm will spike, and smell clutch burning.
2. The gear indicator display incorrect gear 50% of the time.
Does it mean, my clutch is done? Please help. Thanks!
username404 is offline   Reply With Quote
Old 10-23-2014, 04:19 PM   #2
nick_318is
Drives: 2013 Subaru BRZ, 1991 BMW 318is
1. Sounds like a worn clutch.
nick_318is is offline   Reply With Quote
Old 10-23-2014, 04:50 PM   #3
ANTLAY
Drives: 2013 FR-S in Whiteout
How many miles?... Definitely sounds like clutch is gone bro..
ANTLAY is offline   Reply With Quote
Old 10-23-2014, 04:54 PM   #4
woode
Boosted Member
woode's Avatar
Send a message via MSN to woode
Sounds like a pedal adjustment issue maybe.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 10-23-2014, 06:06 PM   #5
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
Absolutely not.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 10-23-2014, 06:24 PM   #6
Akari
Drives: 2013 DGM BRZ
Originally Posted by Thorpedo View Post
Absolutely not.
If the clutch pedal is adjusted so improperly that it cannot fully engage it would cause these exact issues. It's worth checking.
Akari is offline   Reply With Quote
The Following 2 Users Say Thank You to Akari For This Useful Post:
cdrazic93 (10-23-2014), Ultramaroon (10-23-2014)
Old 10-23-2014, 08:29 PM   #7
kodyo
Drives: Scion FR-S
How many miles? I smelled a burnt clutch/rubber smell for about the first 10k miles off and on. It's fairly common on here.
kodyo is offline   Reply With Quote
Old 10-23-2014, 09:14 PM   #8
Ultramaroon
not playing cards
Ultramaroon's Avatar
Absolutely not.
If the clutch master isn't allowed to fully open/relax it will actually pump up and cause exactly that issue. Unless OP or someone messed with the adjustment, I doubt this is the issue.
OP, see if you can compress the piston further into the slave cyiinder. Doesn't take much. If you can push it a couple mm, then the clutch master cylinder is fully releasing.
Most likely, your clutch is just toast. Sorry. Bummer.
Old 10-23-2014, 10:32 PM   #9
username404
Bought it 2 years ago...now it has 27K miles on it. Daily driver. I noticed the issue #2 for about 2 months then issue #1 happened 2 days ago. I am definitely feeling loss of pressure when releasing the clutch and issue #1 becomes more often too.
Old 10-23-2014, 10:37 PM   #10
kodyo
Drives: Scion FR-S
Shot in the dark: Potentially an issue with the master cylinder or there is air in the line. Try to bleed the clutch first and see if it improves. You could also try to diagnose if there is a possibility of it being the master, and replace that if you are confident.
Check that you have hydraulic fluid in the reservoir for the clutch and see if it looks like air might have been sucked in.
This could be the root cause for an otherwise toast clutch.
The Following User Says Thank You to kodyo For This Useful Post:
humfrz (10-23-2014)
Old 10-23-2014, 10:55 PM   #11
Ultramaroon
not playing cards
No, if there was air in the line OP wouldn't be able to shift into gear.
Replace clutch.
Calum (10-24-2014)
Old 10-23-2014, 11:06 PM   #12
username404
I am taking it to the dealer on Wednesday and hopefully i don't have to replace the clutch.
Old 10-23-2014, 11:06 PM   #13
kodyo
Drives: Scion FR-S
Replace clutch.
My friend had a master cylinder go out on his '05 GTO. The symptoms were a soft clutch similar to what OP described. We bled the lines and he was able to shift a little better, but it still didn't disengage the clutch fully, but enough to get it to the shop. He replaced the master cylinder and it fixed his problem.
A clutch going out at 27k miles is a clear indication of some other problem. Driver or mechanical. He may need to replace the clutch. But if he doesn't find the underlying problem, he may encounter this again in the future.
Old 10-23-2014, 11:11 PM   #14
Ultramaroon
not playing cards
My friend had a master cylinder go out on his '05 GTO. The symptoms were a soft clutch. We bled the lines and he was able to shift a little better, but it still didn't disengage the clutch fully. He replaced the master cylinder and it fixed his problem.
A clutch going out at 27k miles is a clear indication of some other problem. He may need to replace the clutch. But if he doesn't find the underlying problem, he may encounter this again in the future.
Yes, but did the clutch in your friend's GTO slip on throttle in top gear? OP's clutch disengages just fine. It slips.
And the pedal feels soft because the clutch disc is worn down to the rivets - loose pressure plate.
Stock brakes worn out? Brahsbrah Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 04-05-2014 01:08 AM
Worn floor mats - Covered under bumper to bumper warranty? Philly758 Issues | Warranty | Recalls / TSB 45 08-19-2013 01:32 PM
Worn out clutch stopper AsianStyle Issues | Warranty | Recalls / TSB 1 07-05-2013 07:07 PM
Worn Clutch? Jakeedaman21 Issues | Warranty | Recalls / TSB 18 04-30-2013 02:06 PM
