Old 04-26-2016, 06:10 PM   #1
brzzy
@anthonysestito
brzzy's Avatar
Drives: 2013 Sterling Silver Metallic BRZ
Pulley install help.. Video inside
Installed my Perrin light weight pulley this week and noticed something. The actual crank bolt looks like it's wobbling. I made damn sure everything went in straight, bolt went in straight no problems. But when it spins it's scaring me a little. There's no wobble at all in the pulley itself, just the bolt. Could it be that the bolt is just dirty/discoloured and I'm losing my mind. Or should I just play it safe and order a new one and drop it in? No issues so far and the car runs fine. But I get ultra worried about minute things like this. XD
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO
brzzy is offline   Reply With Quote
Old 04-26-2016, 06:11 PM   #2
brzzy
@anthonysestito
brzzy's Avatar
IG: @ANTHONYSESTITO
Old 04-27-2016, 07:22 PM   #3
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
Oh I've has this problem the first time. the pully isn't sitting flushed or not tightly screw in or it could maybe be the belts are out of place but not likely.
check them again. when screwing it back in pull hand brake all the way up and put into first gear or reverse.
hope this helps!!
turtlefeeder is offline   Reply With Quote
Old 04-27-2016, 07:51 PM   #4
brzzy
@anthonysestito
brzzy's Avatar
hope this helps!!
Real strange. Pulley sits flush, belt I triple checked and is %100 on. Bolt went in no problem, no force and its torqued to spec. No wobble in the pulley either. Honestly I may order up a new bolt regardless and just re-install it. But super strange.
IG: @ANTHONYSESTITO
Old 04-27-2016, 08:13 PM   #5
turtlefeeder
Drives: UltraMFrS
I thought mines was flush the first time too but tighten using a pully I borrow from my mechanic. than it was truly tight. because that bolt will move the whole belt. unless you use a pully.
Revworks UEL headers (video inside) The Racers Line Engine, Exhaust, Bolt-Ons 4 05-12-2014 11:19 PM
Red inside door handle grips how to install? 914_WHITE_FRS Cosmetic Modification (Interior/Exterior/Lighting) 13 03-24-2014 12:21 AM
Broken down FRS-T! video inside Silverdub Forced Induction 26 05-22-2013 02:21 AM
Chirp (Video Inside) StOpNG0x Issues | Warranty | Recalls / TSB 17 12-13-2012 09:06 AM
Idle RPM dip.... video inside. CSG Mike Engine, Exhaust, Transmission 24 08-17-2012 01:45 PM
