Old 04-27-2022, 07:07 PM   #1
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
22 Warped wheel
I went to discount tire to get a puncture repaired and found out that at least 1 stock 18" wheel is out of round by a bit.
Anybody have any luck with warranty replacement wheels?
I will have to lift the car and check the others before going to the dealer.
Old 04-27-2022, 10:42 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
how is this not noticeable when driving the car?
and if it's not noticeable, what difference does it really make?
Old 04-28-2022, 06:44 AM   #3
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
I don't think you're going to get that taken care of under warranty
Old 04-28-2022, 07:46 AM   #4
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
22 Warped wheel
How much are we talking? Anything up to 3mm out of round I wouldn’t worry about. I don’t know about Subarus suppliers but I’ve seen others be out of round by up to 3mm straight out of the box. The tire should be able to absorb that error.
Old 04-28-2022, 08:07 AM   #5
dragoontwo
dragoontwo's Avatar
Ill get a straight edge under there when I check the other wheels this weekend. It's on the inside lip and makes the tire wobble pretty good as well.
Can't say if I can feel it or not. The KY roads here suck. Can't drive in the right lane on the interstate. Seen some RVs grab inches of air in the right lane.
Old 04-28-2022, 11:10 AM   #6
Grady
Grady's Avatar
Warped or bent? If it is defective from manufacture I would say yes you can get it replaced under warranty. It will take some work because I am sure they will go to it was bent after manufacture.
The Following 2 Users Say Thank You to Grady For This Useful Post:
Opie (05-11-2022), soundman98 (04-28-2022)
Heat Warped Sun Visors Whats that smell? Arizona 5 06-30-2017 03:07 PM
warped discs? dejxx Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 01-03-2015 01:35 PM
Front pipe flange warped? Fizz Engine, Exhaust, Transmission 3 12-23-2014 02:47 PM
Warped dashboard by middle AC vents thatWESguy Issues | Warranty | Recalls / TSB 6 05-02-2014 03:21 AM
3rd brake light warped? ericmpena BRZ First-Gen (2012+) — General Topics 1 07-31-2013 10:21 PM
