Old 12-25-2014, 03:41 PM   #1
dejxx
dejxx's Avatar
Drives: FT-86
warped discs?
I have a set of aftermarket discs on my car (Fremax Sloted OEM size discs, Brazilian shop). And ive been running them for a while with no problems. But on the last track day, i tracked with Ferodo DS2500 on them, and now it seems that i warped my discs, but very slightly. There is no stutter when i brake at high speed, or anything like that, only thing i feel is that when im breaking very softly (for ex., stopping at a red light), i feel the breaks coming on and off... like the pads bit the disc hard, then only a little bit...
Warped discs, or other things going on?
thanks!
dejxx is offline   Reply With Quote
Old 12-26-2014, 01:31 PM   #2
dejxx
dejxx's Avatar
Drives: FT-86
anyone?
Old 12-26-2014, 01:45 PM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
Well, it was Christmas yesterday.
Pulsing under slight braking is the classic symptom of a warped rotor.
Did you check your wheel lug torques after installation? Too tight or uneven will cause problems especially if the rotors get super hot. Also, after hard braking, never leave them applied after coming to a full stop.
Old 12-26-2014, 01:58 PM   #4
dejxx
dejxx's Avatar
Drives: FT-86
heheh true.. sorry!!!
Checked the wheel lugs, but maybe that was the problem...
Also, i never leave the breaks applied after tracking =) mandatory 1 lap cooldown, then roll very slowly to the pits heheh.
thanks!
Old 12-26-2014, 02:53 PM   #5
Ultramaroon
not playing cards
Even if installed/handled perfectly there are no guarantees. Might just be a manufacturing variation.
Old 12-27-2014, 06:42 PM   #6
Racecomp Engineering
Most of the time (as in 99%) its uneven pad deposits, not warped discs. A good rebedding will help. If left too long the discs could be toast. Do a google search for the stoptech white paper on the warped rotor myth and cementite.
- Andy
The Following 5 Users Say Thank You to Racecomp Engineering For This Useful Post:
Captain Snooze (01-04-2015), juliog (12-27-2014), OkieSnuffBox (01-04-2015), Ultramaroon (12-27-2014), Whatabouteggs (12-27-2014)
Old 12-27-2014, 08:38 PM   #7
Sleepless
Sleepless's Avatar
Drives: 2016 FR-S
Driving on the street with your DS2500 should clean off the pad deposits in a few days.
Sleepless is offline   Reply With Quote
Old 12-27-2014, 09:01 PM   #8
juliog
juliog's Avatar
Drives: 86
Most likely uneven brake pad deposits on the rotors. This can happen at the track if you ride your brakes driving through the pits after a session, when the pads are still smoking hot. Follow the bedding procedure like suggested above to get the pad material evenly distributed along the rotor surfaces.
juliog is offline   Reply With Quote
Old 12-27-2014, 09:46 PM   #9
Ultramaroon
not playing cards
- Andy
This is an excellent resource. Thanks very much, Andy.
http://www.stoptech.com/technical-su...l-white-papers
Racecomp Engineering (12-28-2014)
Old 01-03-2015, 10:58 AM   #10
dejxx
dejxx's Avatar
Drives: FT-86
thanks all for the replies!!
Old 01-03-2015, 12:06 PM   #11
Pete156
I like to eat!
Good brake info.
Thanks fellas
Pete156 is offline   Reply With Quote
Old 01-03-2015, 01:06 PM   #12
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I did manage to warp the discs on my Dodge Neon, within something like the first 5000 miles. That POS was made with bailing wire, hay, and dog shit. Chances of warping an FR-S disc, even aftermarket, are pretty slim. It's all about the pad deposits, no warping.
Old 01-03-2015, 01:35 PM   #13
Ultramaroon
not playing cards
Yeah, I learned something new. Andy came through with some great stuff!
Front pipe flange warped? Fizz Engine, Exhaust, Transmission 3 12-23-2014 02:47 PM
Cheap discs? EAGLE5 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-06-2014 01:54 PM
Warped dashboard by middle AC vents thatWESguy Issues | Warranty | Recalls / TSB 6 05-02-2014 03:21 AM
Endless Discs OnionTou Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 11-25-2013 11:54 AM
3rd brake light warped? ericmpena BRZ First-Gen (2012+) — General Topics 1 07-31-2013 10:21 PM
