Old 12-23-2014, 10:08 AM   #1
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Front pipe flange warped?
I purchased this front pipe from a local manufacturer, and was about to install it when I noticed one of the flange looked funny. So I checked with a straight edge and it appears the ends of the flange is bent outwards, but the area around the pipe hole is flat.
At first it doesn't look too bad, but when you place the straight edge flat against the bolt hole, it really magnifies the amount its out of shape.
Should this be a concern, or will the ends be "pulled" in once fully tightened?
Fizz is offline   Reply With Quote
Old 12-23-2014, 10:19 AM   #2
mike the snake
I bet you'll be just fine with that. Should get pulled together, and the gasket will have extra pressure right where you want it I would think.
I'd use good high grade bolts/nuts and use anti-sieze as well.
I'm not an exhaust expert, but that looks OK to me. I'd try and run it if it were mine.
Old 12-23-2014, 10:21 AM   #3
Koa
Completely normal, flanges don't need to be perfectly flat to fit correctly
Old 12-23-2014, 02:47 PM   #4
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
They "should" be flat if its bolted to fixture when welded and then surfaced after. However with that said the actual sealing surface on that flange isn't too bad so i would bet you'll be fine.
Jesse@JDLAutodesign is offline   Reply With Quote
HKS front pipe or dual resonated front pipe unsurety Engine, Exhaust, Transmission 18 02-22-2016 09:22 AM
Need to get a Catback doughnut flange (Just the flange), but where??? Kostamojen Engine, Exhaust, Transmission 11 04-12-2014 09:10 PM
Gains from aftermarket catted front pipe vs stock front pipe? Vmax911 Engine, Exhaust, Transmission 4 01-20-2014 01:42 PM
Front hub/knuckle/flange shared with any other model? ft_sjo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 05-19-2013 03:03 AM
Borla UEL flange, more in common with a pretzel then a flange. Adeets Engine, Exhaust, Transmission 13 04-12-2013 05:38 PM
