Old 04-26-2022, 11:01 PM   #15
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Check for seized brake caliper pins
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
Jfheisenberg (04-28-2022)
Old 04-28-2022, 08:29 AM   #16
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
Originally Posted by Jfheisenberg View Post
Stop tech, lasted < 2 years
Which friction material?
Stonehorsw is offline   Reply With Quote
Old 04-28-2022, 11:45 AM   #17
Jfheisenberg
Jfheisenberg's Avatar
Drives: 2015 BRZ Series Blue WRB
calipers are good, car is doing fine after replacing all rotors and 1 wheel hub.
Jfheisenberg is offline   Reply With Quote
Old 05-03-2022, 12:34 PM   #18
series.trackday
series.trackday's Avatar
Drives: '17 Subaru BRZ series.Yellow
I can't tell you precisely what it is, but you have some problem on your rear brakes. Slightly sticky caliper, sticky piston, something. It's not totally unusual for a single-pot caliper to produce uneven wear (especially on the rear) but that's way beyond uneven wear.
That rotor wear is very abnormal. And with it coming from a manufacturer with proven quality control like StopTech, I doubt it's a manufacturing issue with the rotor.
series.trackday is offline   Reply With Quote
Old 05-04-2022, 11:31 AM   #19
Nickel
Nick
Drives: 2013 10 Series GT86 #182 of 2500
Your brake fluid is scorched. Replace it with something that has a higher boiling point. If you've already replaced the rotors and pads, then it's your fluid. I've had the same issue before. People also assume you need some sort of drilled/slotted rotor to stop better but it all comes down to the pad compound and fluid you use.
2013 Scion FR-S 10 Series MT #182 of 2500/2007 BMW Z4 3.0si Coupe/2016 Yamaha FZ-09/2022 Ford Mustang Mach 1 Handling Package MT Recaro 700A (#N3956)/2023 Toyota Camry XSE
Instagram: @the_white_comet_of_zion
Nickel is offline   Reply With Quote
Old 05-10-2022, 02:07 PM   #20
Joon525
Joon525's Avatar
Drives: 2016 BRZ
This is what I'm thinking.
Were BOTH sides like that or only one?
Joon525 is offline   Reply With Quote
Brake fluid problem WNDSRFR Issues | Warranty | Recalls / TSB 24 08-10-2021 10:18 PM
Valenti 4th brake wiring problem andrewtgg Cosmetic Modification (Interior/Exterior/Lighting) 14 08-21-2017 08:10 AM
Need help figuring something out Jrevans1992 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 09-30-2016 12:56 PM
Brake pad problem (CL Brakes RC5+) Tor Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 09-13-2016 06:32 PM
Rear brake problem fender9530 Issues | Warranty | Recalls / TSB 18 03-15-2013 07:52 AM
