Old 04-14-2022, 05:27 PM   #57
Edkwok99
Drives: GR86
It’s a good indicator of either driver error or you are outpacing the pad.
Here is CSG spec pad. Even transfer layer, pretty even rotor contact.
Thanks for sharing. But they are not the same pad and rotor than the ones I have.
Edkwok99 is offline   Reply With Quote
Old 04-14-2022, 05:34 PM   #58
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Edkwok99 View Post
I need to know if I should replace the rotor immediately as stated in my original post.
Are you saying Antilock brake system did this to the rotor? If yes, I disagree totally. I think you are confused with ABS and TRAC/VSC.
Usually Trac/VSC interference will show up on the rears. I've had the TCS overwork the rears when I didn't have the car warm enough to pedal dance. I personally, haven't seen it on the front, not that it isn't possible.
This is the CSG C1 pad on a stoptech BBK with 328mm rotors. Much different setup.
Old 04-14-2022, 05:35 PM   #59
soundman98
ProCrastinationConsultant
soundman98's Avatar
that's not a problem, as you're going to be changing pads and rotors soon anyways!
Old 04-14-2022, 10:23 PM   #60
dsc_pat
Drives: Too fast
I do not really care that you disagree. I am not confused and have been through 5+ sets of dtc on this chassis over the years. Your rotors are fine. DTC pads sometimes deposit. It doesn't affect anything other than triggering rich csg pad owner who swear deposits are a negative thing while it's not really
It is neither.
dsc_pat is offline   Reply With Quote
Old 04-14-2022, 10:53 PM   #61
soundman98
soundman98's Avatar
deposits are a bad thing. they create an unpredictable friction surface.
Old 04-15-2022, 12:05 AM   #62
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
You have been told 1/2 a dozen times.
This is what you want to hear. Replace the rotors with bigger dia rotors and a set of 4 piston front and 2 piston rear calipers (AKA BIG BREAK KIT) LOL BIG BRAKE KIT.
The Following User Says Thank You to gen3v8 For This Useful Post:
soundman98 (04-15-2022)
Old 04-15-2022, 03:40 AM   #63
CSG Mike
CSG Mike's Avatar
Originally Posted by WNDSRFR View Post
Can somebody explain to me what ABS actually is?
I thought it was an anti-lock brake system that pulses the brakes to prevent them from locking up?
I thought that the system is always on and is always engaged.
You mean you can turn it off? Why would you do that?
It wasn't that long ago that ABS did not exist.
Back in the day, if you slammed on the brakes, you would going merrily sliding out of control. Happened all the time.
It's one of the best safety features of our time.
So how do you turn it off? Pull a fuse?
ABS prevents brake lockup. It is traction control, for brakes. It is always on, but not always engaged. It only engages when lockup is detected.
For all intents and purposes, there is no reason to disable or turn the system off, even on track, as it is a reactive system. It only intervenes if you've already locked up one or more wheels. It is generally faster to leave ABS on, and to judiciously use the system only under circumstances where traction is uneven. (e.g. left tires have way less traction than right)
ABS comes with a LARGE heat penalty when used.
Old 04-15-2022, 03:41 AM   #64
CSG Mike
CSG Mike's Avatar
He just needs to get better pads. No need for a BBK at this time.
Old 04-15-2022, 03:42 AM   #65
CSG Mike
CSG Mike's Avatar
Nope
This happened because the pad is completely insufficient for your use. You need a better pad combination.
Old 04-15-2022, 03:44 AM   #66
CSG Mike
CSG Mike's Avatar
It is neither.
If the DTC works for you, stick to the DTC. It doesn't work for everyone.
If you think deposit are NOT a negative thing, then you should check out your own data. You'll very quickly change your mind when you see how it affects your braking ability.
Old 04-15-2022, 10:27 AM   #67
dsc_pat
Drives: Too fast
Haven't said anything about the dtc working for anyone or me, did I.
My data says that OP level of deposits have zero impact on braking, unless there is pad contamination.
Old 04-15-2022, 11:48 AM   #68
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
\ I am not confused and have been through 5+ sets of dtc on this chassis over the years.
It is neither.
But you have been through 5 sets of them I'd assume if you were not satisfied with them that wouldn't be the case.
I personally don't consider that level of deposit or difference in rotor heating alarming. I just wouldn't buy that combo again if it was me but I'd continue to run them till I wore that set out.
As for your goofy comment on "rich" CSG pad owners. Are they really more expensive if they last longer? XP10's at 500 a set lasted me maybe 60-65% of the life of C1's, not to mention the XP's suck. I am running Raybestos this go around, will probably try something else the next time variety being the spice of life so they say.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
CSG Mike (04-16-2022), soundman98 (04-15-2022)
Old 04-15-2022, 12:59 PM   #69
Edkwok99
Drives: GR86
Would you kindly elaborate on this?
Old 04-15-2022, 07:30 PM   #70
dsc_pat
Drives: Too fast
Sorry, that was rude and uncalled for.
XP10 were awful to me too.
5+ sets on this chassis, probably 30+ dtc sets total. Hundred+ of sets from other brands combined...dtc are very high on the scale of performance and life per $.
Brake pads to swap between for DD and Track Days jim985 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 12-25-2020 08:12 PM
Brake compound for Track Days fer3d Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 07-31-2018 08:47 AM
Brake Pads and Fluid For DD/AutoX/Track Days/HPDE ToyoburuBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 07-23-2016 03:59 PM
NPA: APR Carbon Fiber Brake Cooling Kit with Ducts - A must for track days 86_Insider Brakes, Suspension, Chassis 1 09-26-2013 01:39 AM
Brake pads for track days why Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-26-2013 06:42 PM
