Brake pads to swap between for DD and Track Days
I am looking to get 2 sets of brake pads, one for DD and the other for Trackdays.
Tried searching the forum but could only find topics about pads for dual purpose. I have the AP racing sprint kit on the car, and have previously had DS2500 in it for dual purpose, however I found them completely unsuitable on the street due to how loud they are. I am a beginner with track days and am pretty light on the brakes, but I want to improve this coming season. I don't want to swap rotors each track day, just want to swap pads before the first session, so I was looking at trying to find 2 compounds that will work well on the same rotor. I have my eye on Hawk HPS 5.0 for street pads and DTC-30 for the track, as I can get these for a decent price locally. Does anyone know if these compounds are compatible and suitable for what I want? Also open to any other options, but I find it hard to find pads for the AP Racing kit in Australia. I will import if I have to, but the shipping charges are a killer. Thanks in advance |
30 minute maintenance
Drives: My18 wrxsti
I put my track pads in a week before and I always put the same pad in the same position in the caliper. I mark the street pads and the track pads LI, LO, RI and RO.
So whats wrong with DS2500 for track only as you did not say. |
Drives: 2014 GT86
DS2500 works fine for me on stock (non PP brembos) twins brakes though.
Also which AP racing kit you have? |
I have the Essex AP Racing sprint kit.
I didn't have any performance issue with the DS2500 on track, however when asking the supplier for a less aggressive ferodo pad (for Street use) for these callipers I was told that there was not one available. I figure that if I am going for dedicated track pads it wouldn't hurt to go one step up from the DS2500 I still have DS2500 in the rear as they are working fine there, but I'll swap them out to match whatever I end up running in the fronts in the future |
Drives: My18 wrxsti
wrong discussion
Because compromise ®
Drives: Red Herring
I use Carbotech 1521 for street. Sprint kit fitted.
Carbotech has an office in Aus. https://carbotech.com.au/
#7 | |
I run Carbotech 1521's for street and XP10/XP8's for track setup. You can use the same rotor with both sets of pads
2013 Series 10 FRS #553
Scott M
Drives: '13 BRZ (DocWalt's old car)
Another suggestion for using Carbotech. I’m switching between XP12 for track and AX6 for street/autocross duty. Frankly, I’d didn’t like the feel of Carbotechs I’d tried before this setup on the BRZ. No complaints regarding performance and ease of switching/swapping. Noise, however, would be an issue for most people.
AP BBK Sprints up front. OE rear calipers and rotors
13 BRZ (DSTprep)
14 Lotus Evora S; 08 Exige S240 06 BMW Z4M Roadster, 20 M850 Last edited by Molez93; 12-23-2020 at 10:02 PM. Reason: Brake hardware |
#10 |
Ordered some Carbotech 1521 and XP10. Thanks for the recommendations
#11 | |
#12 |
Scott M
My AX6 pads are essentially as noisy as the track pads on the street. Which is to say, consistently like a bus unless I’m using heavy peddle pressure. I feel like they were kinda sorta quiet with appropriate lube applied to the right spots when swapping, but that didn’t seem to work every time so I gave up trying after a couple noise inducing swaps.
13 BRZ (DSTprep)
14 Lotus Evora S; 08 Exige S240 06 BMW Z4M Roadster, 20 M850 |
#13 |
Weight Weenie
Drives: 15 FR-S
It sounds like the Sprint kit is noisy in general on the street. I hope that's not the case because it's been on my radar for some time...
#14 |
Drives: 2023 BRZ
I have not found that to be the case.
Director of Rocky Mountain 86CUP
| Brake compound for Track Days | fer3d | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 07-31-2018 08:47 AM |
| FS: Hawk track brake pads, DTC-30 front/HP+ rear, 90% life left, best track day combo | tampaSi | Brakes, Suspension, Chassis | 4 | 05-27-2017 02:31 PM |
| Brake Pads and Fluid For DD/AutoX/Track Days/HPDE | ToyoburuBRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 07-23-2016 03:59 PM |
| Daily drivers, do you swap street and track brake pads? | qoncept | Tracking / Autocross / HPDE / Drifting | 31 | 06-26-2013 03:50 AM |
| Brake pads for track days | why | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-26-2013 06:42 PM |
