| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
#43 |
#44 |
![]() This is what a deeply cycled rotor looks like, without overheated pad. Notice there is no streaked/melted pad on this rotor. |
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#45 | |
ProCrastinationConsultant
New cars are anything but "push a button and it's off" anymore.
| The Following 2 Users Say Thank You to soundman98 For This Useful Post: | CSG Mike (04-14-2022), WolfpackS2k (04-14-2022) |
#46 |
For the record-- those rotors are still considered good, or is that considered end of life?
#47 |
Drives: Miata
#48 |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Ohio Enthusiast (04-14-2022), soundman98 (04-14-2022) |
#49 |
https://www.instagram.com/p/Bck5ea0lWkH/
Some badly overheated pad (pads were insufficient for use). |
| The Following User Says Thank You to CSG Mike For This Useful Post: | soundman98 (04-14-2022) |
#50 | |
Drives: GR86
I didn’t feel the ABS kicking in (no vibration brake pedal and no front tires slipping and grabbing) Would you please educate me how Anti lock braking system (ABS) could contribute to this? I do not trail brake and always brake at a straight line. The track days were all on dry surface. I do not slammed on the brake and dive bomb. My inputs are smooth. |
#51 | |
Drives: Crapcan
#52 |
Drives: FR-S,GTI
Can somebody explain to me what ABS actually is?
I thought it was an anti-lock brake system that pulses the brakes to prevent them from locking up? I thought that the system is always on and is always engaged. You mean you can turn it off? Why would you do that? It wasn't that long ago that ABS did not exist. Back in the day, if you slammed on the brakes, you would going merrily sliding out of control. Happened all the time. It's one of the best safety features of our time. So how do you turn it off? Pull a fuse? |
| The Following User Says Thank You to WNDSRFR For This Useful Post: | Edkwok99 (04-14-2022) |
#53 | |
Drives: Crapcan
You can disable by pulling the fuse, or through can communication like what geraldjust has done. I imagine techstream may be able to disable it as well.
#54 |
Drives: Too fast
this is taking an unexpected proportion for something very simple
hawk dtc will do these kind of deposits, everyone who used them knows. everything is normal, what more do you need to read ? you 100% engage abs sometimes, and it is ok end of thread. |
| The Following User Says Thank You to dsc_pat For This Useful Post: | Q8D (04-14-2022) |
#55 | |
Drives: Crapcan
It’s a good indicator of either driver error or you are outpacing the pad. Here is CSG spec pad. Even transfer layer, pretty even rotor contact.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | CSG Mike (04-15-2022), soundman98 (04-14-2022) |
#56 | |
Drives: GR86
Are you saying Antilock brake system did this to the rotor? If yes, I disagree totally. I think you are confused with ABS and TRAC/VSC. |
| Brake pads to swap between for DD and Track Days | jim985 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 12-25-2020 08:12 PM |
| Brake compound for Track Days | fer3d | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 07-31-2018 08:47 AM |
| Brake Pads and Fluid For DD/AutoX/Track Days/HPDE | ToyoburuBRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 07-23-2016 03:59 PM |
| NPA: APR Carbon Fiber Brake Cooling Kit with Ducts - A must for track days | 86_Insider | Brakes, Suspension, Chassis | 1 | 09-26-2013 01:39 AM |
| Brake pads for track days | why | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-26-2013 06:42 PM |
