Old 04-11-2022, 01:02 AM   #1
ItsReiko
ItsReiko's Avatar
Drives: 2017 subaru brz
Lightest OEM Size Wheel?
Hi everyone, like most people, I'd like to get a aftermarket set of wheels. My primary goal is saving some un-sprung weight. I'd like to stick to the OEM wheel size to maintain the stock feel and lightest weight possible.
I notice that most aftermarket wheels are wider. What are the lightest wheels I can find that has OEM sizing (215/45r17) and are under $450 per wheel? (Enkei RPF1 isn't my cup of tea unfortunately)
ItsReiko is offline   Reply With Quote
Old 04-11-2022, 05:50 AM   #2
MrSkubi
MrSkubi's Avatar
Drives: 24 GR Yaris, 23 GR86
Wedssport TC105X comes in OEM like size:17x7,5 +45 (for PP at least) and weight should be around 15 lbs. Not sure if you can get them under 450$/wheel.
MrSkubi is offline   Reply With Quote
Old 04-11-2022, 10:32 AM   #3
ZDan
ZDan's Avatar
Drives: '23 BRZ
Enkei PF01 5x100 17x7.5 +45 = 17 lb
Old 04-11-2022, 06:24 PM   #4
ItsReiko
ItsReiko's Avatar
Yea I really want the TC105x however after tax and shipping they're more like $550 per wheel x.x
With the Enkei RPF1's, will going with 17x7.5+48 be just like oem where my rear wheels are way too sunken in?
Old 04-11-2022, 10:10 PM   #5
Pat
Pat's Avatar
Drives: 2023 BRZ
Kosei k4r 17x8 et36 is 15.8 pounds
Edit:. Oops, OEM isn't 8" wide, sorry.
Old 04-15-2022, 01:39 AM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
Used set of forged wheels.
Old 04-15-2022, 04:33 AM   #7
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Used sets of TE37 in 17x7/7.5 usually do not command a lot of interest and can be had for about $1500-$2000
SSR Type C are also quite lightweight. There is a set available on craigslist for $1k . I read 17x7.5 weighs in at 14.9 pounds
EndlessAzure is offline   Reply With Quote
Old 04-15-2022, 07:10 AM   #8
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
While that’s true they’re also very difficult to find. I snagged a set of 18x7.5 TE37s for my 2013 after over a year of periodically searching. I’d love to find another set for the 2022.
Old 04-15-2022, 07:53 AM   #9
ZDan
ZDan's Avatar
Drives: '23 BRZ
Of course with the same width, same offset, they'll put the wheel lip and tires in exactly the same place relative to fenders. Get lower offset and/or wider if you don't want them to look as sunken-in.
Old 04-15-2022, 10:26 AM   #10
sygfrid
FT8Syg
sygfrid's Avatar
Drives: `12 FRS & `17 BRZ Inazuma
IMO, just go for it! Save some more & get this really fantastic wheel, you won't regret it.
I have 18x8.5 +43 TC105X @ 16.4 lbs/wheel w/ 225-40 PS4S (21 lbs) & such huge difference in weight from stock makes the car feel so much lighter & agile. Yes, it's not cheap but I'm happy not only with its performance but also knowing I have a little more unique setup than most who go for Enkei’s, Work, Rays, etc.
Sent from my SM-G781W using Tapatalk
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
sygfrid is offline   Reply With Quote
Old 04-17-2022, 01:30 PM   #11
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
Fun fact, 2004 STI wheels are 17x7.5 and weigh <16lbs. They will clear Brembos too.
cmiovino is offline   Reply With Quote
Old 04-20-2022, 07:03 PM   #12
saltywetman
Drives: 2020 Toyota 86 GT 6M
Those trd 17" RS2.0 wheels are lighter than stock but for a 17x7.5 forged wheel they are not light compared to other options.
I believe the TWS t66-f still holds the title for lightest forged consumer aluminum wheels.
Their 17's don't come available in 7.5 though but they 17x8.0 weigh in at just under 14lbs (6.32kg)
EDIT: sorry didn't see the price cap. @ 450 a wheel you best bet would be the TRD. I'd just go with the rpf1's in that case and use the saved $ over getting the trd's towards better rubber
saltywetman is offline   Reply With Quote
Old 07-03-2022, 11:14 AM   #13
mike2100
mike2100's Avatar
Drives: 23 BRZ
Originally Posted by BlkTrax View Post
That looks really good. Got any other pics?
mike2100 is offline   Reply With Quote
Old 07-03-2022, 02:41 PM   #14
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
If you are open to a 225/45R17 tire you can cross shop 17x8 sizing. Still gives you plenty of offset flexibility.
Lightest Stock Size Wheels Lelandjt GR86 General Topics (2nd Gen 2022+ Toyota 86) 35 03-01-2023 08:58 AM
Best wheel and rim size ggiddix Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 01-09-2017 05:47 PM
Best Wheel Size? VinJah Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 08-29-2016 11:51 AM
What are some of the lightest wheel options? dave77 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 01-09-2014 02:15 AM
FI and wheel size. Adeets Forced Induction 41 05-24-2013 12:23 AM
