Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > GR86 General Topics (2nd Gen 2022+ Toyota 86)
GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86
Old 02-22-2022, 02:28 AM   #1
Lelandjt
Drives: '04 STi, '12 Mazda 3 Hatch
Lightest Stock Size Wheels
I'm looking for the lightest wheels with the exact same width and offset as the stock 17s. Feel free to list 18s too for anyone looking for those. This doesn't seem like a difficult find but searching through old posts some wheels are no longer available and others are 8" wide or slightly different offset. Coming up empty searching retailers too. Am I being silly wanting exactly 48mm offset?
I just want bronze wheels that are lighter than stock but don't change the tire shape or suspension geometry.
Lelandjt is offline   Reply With Quote
Old 02-22-2022, 02:43 AM   #2
Jianlun
Drives: GR86 RC
Rpf1 17x7.5 et48 silver 6.93kg 3797758048SP
Rpf1 17x8 et45 gold 7.1kg (tyre rack), 7.3kg (oem brochure) 3797808045GG
Tc105x titan 17x7.5 et45 6.8kg
OZ Alleggerita HLT 17x7.5 et48 7kg W0182320176
BBS RF 17X7 et48 6.4kg
BBS RF 17X7.5 et48 6.6kg
Ce28n 17x7.5 et50 6kg
Ce28sl 17x7.5 et48 6.8(unconfirmed)kg
Ssr gtf01 17x7.5 et48 7kg (potentially discontinued?) Sgd630
Advan tc4 17x7.5 et45 7.5kg sgd537
stock is 7.5 et48 so i exercised some +/- hahaha.
your best bet is OZ Alleggerita, many colours avail in tire rack.
Jianlun is offline   Reply With Quote
Old 02-22-2022, 03:02 AM   #3
Lelandjt
I thought stock is 7" wide. It seems like offsets between 43-50mm are okay.
Old 02-22-2022, 07:46 AM   #4
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
The 2nd gen cars are 7.5" stock. That being said, the Alleggerita in 17x8 are under 16 lbs.
dragoontwo is offline   Reply With Quote
The Following User Says Thank You to dragoontwo For This Useful Post:
timurrrr (02-22-2022)
Old 02-22-2022, 01:52 PM   #5
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
I'm looking for the lightest wheels with the exact same width and offset as the stock 17s. [...] others are 7.5" wide or slightly different offset. [...] Am I being silly wanting exactly 48mm offset?
Yes, changing the offset to a lower value won't hurt if you're only changing it slightly (et45? maybe even et40?). If anything, it will improve how the wheels fill the wheel arches.
As others have already pointed out, gen.2 stock wheels are 7.5" in width.
Won't hurt to consider 17x8 either. It will also be better for 225/45R17 tires when inevitably you change your tires from stock.
Also note that stock Primacy HP look narrower than many other tires in the same dimension.
225/45R17 SX2's will look less stretched on 17x8 than stock tires are on stock wheels.
timurrrr is offline   Reply With Quote
Old 02-23-2022, 12:31 AM   #6
AndyRC
Drives: GR86
I'm looking for the lightest wheels with the exact same width and offset as the stock 17s. Feel free to list 18s too for anyone looking for those. This doesn't seem like a difficult find but searching through old posts some wheels are no longer available and others are 7.5" wide or slightly different offset. Coming up empty searching retailers too. Am I being silly wanting exactly 48mm offset?
How about these
https://www.toyota.com/content/dam/t..._Ebrochure.pdf
Slightly wider fitment by 5mm but Toyota are recommending it and only 17lbs , I’ve not seen a part number yet but look the same as the TRD ones sold for the GT86
AndyRC is offline   Reply With Quote
The Following User Says Thank You to AndyRC For This Useful Post:
alex87f (02-18-2023)
Old 02-23-2022, 03:17 AM   #7
Lelandjt
Thanks for the suggestions guys. It's weird that all my searches came up with 7.0" width for the 2nd Gen.
Old 02-23-2022, 05:28 PM   #8
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
For the price and the weight, it's pretty hard to beat RPF1s...
daiheadjai is offline   Reply With Quote
Old 02-23-2022, 05:36 PM   #9
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Konig Hypergram?
It's cheaper right now, and might be stronger.
Haven't compared the weight though.
The Following User Says Thank You to timurrrr For This Useful Post:
Dzmitry (02-28-2022)
Old 02-24-2022, 10:56 AM   #10
Varelco
Drives: '15 GT86 & '22 GR86
You limit your options trying to keep the same offset. One of the lightest wheels available...
17x8 ET42 TWS T66-F 13.93 lb
These are labelled specifically for 86/BRZ fitment
https://www.tws-forged.com/tws_t66-f.html
Varelco is offline   Reply With Quote
The Following 4 Users Say Thank You to Varelco For This Useful Post:
Haust (03-07-2023), PBR (02-24-2023), timurrrr (02-24-2022), Yoniyama (02-26-2023)
Old 02-24-2022, 11:41 AM   #11
Lelandjt
Yeah, I realize now it's okay to go down to 41ish offset, but I wouldn't go higher than 48. That's a very light suggestion!
Old 02-24-2022, 03:00 PM   #12
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
May I ask why you need lightest wheels possible?
Are you ok to potentially sacrifice the strength of the wheel just trying to chase down the mythical "lightest wheel = fastest acceleration"?
Are you really going to feel the difference of a few % worth the risk of bending the wheel on every pothole?
Old 02-24-2022, 04:17 PM   #13
lostinmysenses
Drives: 2022 GR86
Originally Posted by BlkTrax View Post
https://enkei.com/shop/wheels/racing/rpf1/
Part# 3797758048 Finish - SP Size 17x7.5, ET+48 Bolt- 5x100 Bore -73 Weight (lbs)- 15.25
^^^ Fits your request for the Exact same Dimensions of the OEM wheel. Paint or Powder coat to color?
This is the Lightest Wheel for SCCA Solo Street Class I've been able to find ; that is widely available, and not a one off, or overpriced (less than $300) unobtanium.
I sent an email to APEX To see if they would make a Specific Auto-X Wheel, 17x7.5 +41 that's Hub-centric and hopefully lighter than the RPF1, They were looking into it, was the response.
OEM Wheel(s) 17x7.5, 18x7.5 +48
Ideal Street Class wheel - 17x7.5 +41 with 225/45-17 Tire
2022 Street Class Rules:
Any type wheel may be used provided it complies with the following:
A. It is the same width as standard and as installed it does not have an offset more than ±7.00 mm (±0.275”) from a standard wheel for the car.
The resultant change in track dimensions is allowed.
B. Wheel (rim) diameter may be increased or decreased 1” from the standard part. This change may be applied to the front, rear, or both axles.
What are the advantages of running a +41 offset vs +48? Does it have any effect on handling characteristics?
lostinmysenses is offline   Reply With Quote
Old 02-24-2022, 04:46 PM   #14
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Slightly wider track => slightly less lateral weight transfer in corner => slightly more grip.
Also slightly compromised suspension geometry => slight negative impact on steering feedback.
Also arguably better esthetics.
steel86gt (03-03-2023)
Lightest wheels for the $$$ - besides the RPF-1's SubieNate Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 109 02-04-2016 04:50 PM
optimal tire size for stock wheels brillo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 12-05-2015 12:01 PM
Wat are the lightest 17x8 track wheels $ can buy Icanfaptothis86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 07-27-2015 11:06 AM
What are the lightest wheels for this car? quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 10-15-2014 05:56 PM
Best performance tire size for stock wheels? Tenchi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 04-30-2014 06:06 PM
