Old 01-05-2014, 07:56 PM   #1
dave77
Big Member
dave77's Avatar
Drives: 2014 FR-S
What are some of the lightest wheel options?
I'm not good with wheels and brands and whatnot. Hoping people could post some ideas or threads that talk about the lightest options available. I also get confused on what happens when you change the size/width. I'm thinking about doing 17in so same as stock, and then maybe same width but get stickier tires. But it'd also be nice to get a bit wider wheels/tires I guess.
dave77 is offline   Reply With Quote
Old 01-05-2014, 08:13 PM   #2
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Check out this one.
http://www.tws-forged.com/tws_t66-f.html
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 01-05-2014, 08:19 PM   #3
nismo300zr2
in slow-out fast
nismo300zr2's Avatar
Drives: REAR WHEEL DRIVE
Enkei RPF1's have been the proven choice by so many for lightweight performance. At only 16lbs!? per wheel, youll gain better accel/braking/and handling all in one. Dont forget to replace your stock lugs with lighter ones also. Losing that unsprung rotating mass from each corner reaps huge benefits.
http://www.frsport.com/RPF1-Wheel-17...FTJp7Aod5TsAZw
Changing the size of the wheels, affects your tire size choices directly. Me personally, id keep the stock set with the tires it came with, and put them on during the foul weather season and/or long drives. Save the more expensive (grippier) tires for when you are actually driving to DRIVE.
Wider tires will give you more grip compared to the same tire that lays less rubber on the road. You -could- get more grip out of a skinnier tire.. but you'd have to pay for a stickier compound. Read- less tire life.
85 AE86, 91 Z32, 01 SVSfighter, 05 CTD RAM
would trade his AE86 for a Murcialago anyday!
nismo300zr2 is offline   Reply With Quote
Old 01-05-2014, 08:20 PM   #4
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Check out this thread for a long list of wheels with weights: http://www.ft86club.com/forums/showthread.php?t=11454
Your options will be limited by your budget. If you have the money, forged Volks have been the standard for lightweight wheels. If you don't want to blow your entire budget on forged wheels, Enkei RPF1s are a good compromise, but get ready to be flamed by some as they're pretty common.
mit_peid is offline   Reply With Quote
Old 01-05-2014, 08:29 PM   #5
diss7
Drives: AE86, 2x GT86, TE27
If you want ligher, go smaller.
There is no performance gain at all running 18's. Its for looks.
Get 16x7 or 16x8. Weigh less, weight closer to centre.
If 205-225 road tyre is not giving you enough grip, use a semi. If semi is not enough grip, use a race slick.
diss7 is offline   Reply With Quote
Old 01-05-2014, 08:31 PM   #6
dave77
Big Member
dave77's Avatar
Drives: 2014 FR-S
Yea good point. But wondering how 16s would look. I'll see if I can find some pics. Don't want to go up to 18s for sure.
Old 01-05-2014, 08:38 PM   #7
dave77
Big Member
dave77's Avatar
Drives: 2014 FR-S
Maybe get some 16 in BBS wheels, and then get higher profile tires to make the wheel/tire diameter the same as the stock wheel/tire diameter, for speedo/gear ratio purposes.
Old 01-05-2014, 09:18 PM   #8
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
The Kosei K4R is a great option: 17x8, +36mm offset, 15.6lbs, Less than $800 for a full set of 4...use with the stock tires and you will drop 5lbs a corner.
16" wheels would be a nice choice, but tire selection is horrible in 16" while 17" has about the best selection of any tire diameter and are less expensive than 16" tires.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 01-05-2014, 09:27 PM   #9
diss7
Agree, 16" tyre selection is shit.
If you HAVE to stay 17", this was the lightest combo I came up with.
Volk SE37K 17x7.5" with Achilles 205/40/17 semi slick. 14.705kg, 32.42lbs.
I am selling these, but shipping to US would be cray cray.
Going smaller & lighter.
Old 01-05-2014, 09:43 PM   #10
dave77
Big Member
dave77's Avatar
Drives: 2014 FR-S
Yea looking around today, I've also realized that there are not many 16inch wheels out there.
Found these O.Z. wheels which I like. I'm thinking about doing white.
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
But whatever I get, maybe I could find some used wheels for cheaper but still in good condition.
Old 01-05-2014, 09:45 PM   #11
dave77
Big Member
dave77's Avatar
Drives: 2014 FR-S
Yea dang, wish I was in NZ.
Old 01-05-2014, 09:57 PM   #12
Pete156
I like to eat!
Huh?
My 18x8 "cheap" TSW Nurburgrings are at least 3lbs lighter (each) than the stock 17" rims. Bigger is not necessarily heavier. I also run a lower profile, so circumference gain is minimal, thus no perceptible performance loss, and less unsprung weight.
Pete156 is offline   Reply With Quote
Old 01-05-2014, 09:58 PM   #13
diss7
Originally Posted by Pete156 View Post
Huh?
My 18x8 "cheap" TSW Nurburgrings are at least 3lbs lighter than the stock rims. Bigger is not necessarily heavier.
Yes, but what if they were 17x8, or 16x8. Also, its where the weight is. Closer to the centre the better.
Old 01-05-2014, 10:00 PM   #14
dave77
Big Member
dave77's Avatar
Drives: 2014 FR-S
IDK but here they say bigger diameter changes the gear ratio and makes the car slower.
[ame="http://www.youtube.com/watch?feature=player_embedded&v=r_IWa_qlt3g"]2013 Scion FR-S - YouTube[/ame]
Huh?
My 18x8 "cheap" TSW Nurburgrings are at least 3lbs lighter than the stock rims. Bigger is not necessarily heavier. I also run a lower profile, so overall diameter circumference gain is minimal, thus no perceptible performance loss.
Lightest wheels for the $$$ - besides the RPF-1's SubieNate Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 109 02-04-2016 04:50 PM
Lightest Brakes or BBK? Anthony Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 09-11-2015 02:33 PM
What are the lightest wheels for this car? quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 10-15-2014 05:56 PM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 12:53 PM
18x9 wheel fitment and options? epson1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 07-31-2012 05:36 PM
