Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 03-14-2022, 11:16 PM   #1
suhhh
suhhh's Avatar
Drives: 2022 WRB Limited 6 Speed
Clunking after coilover install
Hi all,
So this weekend I installed coilovers for the first time with my buddy. Super fun experience and I learned a lot, everything went smoothly for the most part except now I'm noticing some clunking when driving.
Watched a couple vids and got somewhat of an idea but thought maybe I'd ask here to see if anyone has personally had experience with it + the solution.
Before my rear right would clunk on a bump, stopped by my shop to tighten the front sway bar end links which ended up being loose and also switched two bolts in the rear camber arms that I installed wrong. After that I don't notice anymore clunking during bumps, but I still hear some sort of thud/clunk at low speeds like when I brake to a stop while going slowly. I was going from a stop/reversing multiple times and noticed that I hear the thud right as i brake to a halt. I also notice it when doing some turns in low speeds or when I'm turning and I hit a small bump.
Thanks all in advance for the help.. it's my first toyobaru and this platform will also be the first car I will try to do most/all of the work myself as a learning experience. Super rewarding experience and I hope to learn lots, I'm just a bit hyper sensitive to stuff like this since I just want to make sure I installed everything correctly. thanks again
suhhh is offline   Reply With Quote
The Following User Says Thank You to suhhh For This Useful Post:
SuperTom (03-16-2022)
Old 03-15-2022, 06:18 AM   #2
obito.frs
team TEMPEST
obito.frs's Avatar
Drives: 2015 Scion FR-S
Originally Posted by suhhh View Post
Hi all,
For starters what kind of coilovers are they?
"I don't want to regret the way I lived"
obito.frs is offline   Reply With Quote
The Following 2 Users Say Thank You to obito.frs For This Useful Post:
suhhh (03-16-2022), timurrrr (03-15-2022)
Old 03-15-2022, 06:54 AM   #3
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
How low did you go? Stock endlinks?
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
The Following User Says Thank You to Wally86 For This Useful Post:
suhhh (03-16-2022)
Old 03-16-2022, 12:03 PM   #4
suhhh
suhhh's Avatar
Silver neomax, I used the endlinks. my guess is I didn't set the preload correctly or a couple loose bolts, I think endlinks of sway bar might be hitting the frame but I'm confused because I used the shorter endlinks.
I just did a bunch of research on old posts for the gen1 brz because afaik suspension setup is identical.
Old 03-16-2022, 12:03 PM   #5
suhhh
suhhh's Avatar
2.5 inches or so but it's not even height all around which could also be why I hear sounds, I used shorter endlinks provided by Silver
Wally86 (03-16-2022)
Old 03-16-2022, 09:56 PM   #6
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Check out the area of the front LCA's where they are the closest to the bottoms of the end links.
That's a common area of contact, and you don't even need to take off the wheels to see it. You can turn the steering wheel to one extreme and take a photo of that area on the other side of the car. Turn the steering wheel to the other extreme, repeat.
Old 03-20-2022, 08:26 PM   #7
MMoore4545
Drives: 2022 BRZ
Most coilover brands tell you to drive for a few miles and then retorque.
Frontend things to check:
1- See if there are any contact marks with the front control arm and the swaybar endlink. (near the swaybar connection, just as Timurrr suggested)
2- Endlink torque and washer orientation. (Some brands have the washer between the endlink and the swaybar, eg my HKS coilovers)
3- Top nut torque, camber bolt torque, top mount bolts.
All of these you can knock out with the wheels still on and the steering wheel turned.
'91 Fc3s Turbo
'22 Brz Limited MT
Too Many motorcycles.
MMoore4545 is offline   Reply With Quote
Old 03-20-2022, 09:11 PM   #8
dsc_pat
Drives: Too fast
I am reading you and sincerely think you should bring it to someone who has a clue before something dangerous happens.
dsc_pat is offline   Reply With Quote
Old 03-20-2022, 10:54 PM   #9
Daedex
That One Guy
Daedex's Avatar
Drives: White 2017 BRZ
I just did the GR spring/shocks (not coils technically) and had this same problem.
My issue was the top hat bolt wasnt torqued all the way down.
Easy way to test this is to open the trunk and push down against the bumper, making the car rock up and down, then listen/see if it s the top hat portion.
"I am not bound to win, but I am bound to be true."
Daedex is offline   Reply With Quote
Old 03-21-2022, 12:30 PM   #10
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Precisely, when it stops, or exactly when you first apply the brakes?
There's a bit of slop in the brake calipers to allow for thermal expansion of the calipers and brake pads.
If it wasn't there, the pads could lock up inside the caliper and not do anything when hot.
When you brake going forward, the pads slide up to the stop on one end of the caliper and force is transferred to that end.
Braking backing up after that, the pad slides to the stop on the other end of the caliper.
It's not a great distance. You'll definitely be able to hear it and it's a critical part of the design.
Turning over bumps would be something else though unless you're transitioning from forward to back and braking at the same time.
Clunking sound after coilover install Dee Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 09-22-2018 04:12 PM
Clunking Noise after Coilover install? Bowen Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 07-15-2016 10:47 AM
Clunking Noise After LCA Install Bach415 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 07-06-2015 03:24 PM
clunking noise after LCA install starron Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-17-2015 04:02 PM
Coilover install JerryMichaels7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 02-05-2014 03:31 PM
