Old 02-05-2014, 10:48 AM   #1
JerryMichaels7
Drives: Whiteout FRS
Coilover install
So I got my FA510's in today and am about to install them asap. Before I dive in to far will I need anything other than an allignment.
life's greatest stories usually start with the words, "fuck it!".
JerryMichaels7 is offline   Reply With Quote
Old 02-05-2014, 10:58 AM   #2
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
If you only lower an inch or tad more should be fine. Go much lower and you'll want to bring in back camber ie: Rear Lower Control Arms to bring in and balance camber as well you'd then want toe links.
Old 02-05-2014, 12:29 PM   #3
JerryMichaels7
Yeh i am not slamming it..gonna go as low as my base allows...have to lower it test it out at the stupid as speed bumbs to get on/off base then lower again if i can lol. As soon as taxes gets here I am getting full RacerxFab setup so the rest of it will be taken care of in about a month or so
Old 02-05-2014, 02:32 PM   #4
JerryMichaels7
Can anyone give me the torque values for what i am going to need on the install...At work and i can't download the pdf for the information and i can't find it (going to hobbyshop from work or i would look it up when i get home)
Old 02-05-2014, 02:50 PM   #5
FR-S Matt
It's in the DIY coilover section. There's a few pages out of the service manual showing all stock torque values on the LCA, and struts, and tophat nuts.
Old 02-05-2014, 03:04 PM   #6
DAMotorsports
Drives: 2013 Scion FRS "Raven"
Stay with one inch drop and you will be fine. if you want lower then that you will need to adjust camber. most will say to get LCA's but after installing the Racer X upper control arms i would recommend those to make the adjustment. they do not change your toe like the LCA with can require you to buy toe links also.
DAMotorsports is offline   Reply With Quote
Old 02-05-2014, 03:31 PM   #7
JerryMichaels7
Thanks for the info. I found that in the DIY after i asked the question. Like I said earlyer I do not plan to drop it that much because I have to drive over 4 ridiculas speed bumbs everyday getting onto base and leaving...But I planned on getting the Racerx setup anyway after taxes to get the alignment dialed in correctly. I will post some pictures after the install is done :P
Need a little advice on coilover install swift996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 02-01-2014 10:00 PM
Pro opinions before coilover install Thongpocket Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-07-2014 12:35 PM
HELP kw coilover top hat install problem autoCAR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 10-18-2013 10:55 PM
HKS Coilover install gtauto AUSTRALIA 16 04-21-2013 07:37 AM
Coilover install cost? BRZranger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 08-14-2012 10:16 AM
