Old 02-27-2018, 11:55 AM   #1
Dee
Drives: 2014 Asphalt FRS
Clunking sound after coilover install
Just installed coilovers. Getting a clunk in the right rear over bumps. Really loud sound. Its only the rear right. I’ve heard check the endlinks. They feel super snug. I did the top hat torque to spec. Note I did install lower control arms with the coilover install.
Any ideas? Could it be bushings?
Dee is offline   Reply With Quote
Old 02-27-2018, 12:20 PM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Were they new or used?
Only advice I can give right now is to go back under and tighten all the nuts and bolts again.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 02-27-2018, 12:29 PM   #3
When you checked did you have the weight on the car? If so jack up the corner and check again.
Old 02-27-2018, 01:14 PM   #4
Dee
Right, jacked it up. Just felt with hands no wrench, but everything seems to be snug. I felt all the bolts in this picture
Old 02-27-2018, 01:17 PM   #5
8RZ
The Gunshine State
8RZ's Avatar
What about up top inside the trunk?
Current DD: M235i
Old 02-27-2018, 01:42 PM   #6
jasonojordan
Drives: 2013 satin white brz limited
When I had a noise like that it was due to the nut ontop attaching the damper to the tophat was loose.
jasonojordan is offline   Reply With Quote
Old 02-27-2018, 02:38 PM   #7
Dee
So an update: I am pretty sure it is coming from the top plate. However I did torque it down to manufacturers spec 15 ft/lb. I may give the manufacturer a call and see if they recommend going any higher than that.
However the left side has no issues and it is at the same torque rating
Old 02-27-2018, 02:50 PM   #8
jasonojordan
Does your plates have the pillow bearing in it or no?
Old 02-27-2018, 03:32 PM   #9
Dee
It is the stock plates
Old 02-27-2018, 03:34 PM   #10
jasonojordan
How many miles? Did you inspect the bearing at all before switching them onto the new setup?
Old 02-27-2018, 03:41 PM   #11
Dee
I did not. 60k miles. The left rear is doing it now too...
Old 02-27-2018, 03:51 PM   #12
jasonojordan
60k is not alot of miles but I would deff check out the bearings in them if you are willing to remove each one that is making the noise.
What coil-overs did you go with out of curiosity.
Old 02-27-2018, 03:55 PM   #13
Dee
ST coilovers. I am awaiting response for torque rating
Old 02-27-2018, 03:58 PM   #14
Dee
Can anyone tell me what torque rating I should be doing for the piston rod to plate?
unknown knocking/clunking sound, whatever you call it.... FR-Sky Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 10-25-2017 09:19 PM
Clunking Noise after Coilover install? Bowen Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 07-15-2016 10:47 AM
Clunking sound coming from suspension Maverickgear Issues | Warranty | Recalls / TSB 9 07-11-2014 02:41 PM
Weird Sound After Coilover Install (when moving steering wheel left and right) taimysho0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 07-20-2013 01:18 AM
Neutral to 1st clunking sound wallace03 Issues | Warranty | Recalls / TSB 3 01-10-2013 09:50 PM
