#15 |
Drives: Subaru BRZ limited 2015
I see, it seems that the most reliable and least complicated thing will be to buy the CP 10.5:1 pistons and not complicate my life, thanks anyway, I know that many easily reach that goal with E85. and for the guys above it will not be a stock block the question is for me to decide which piston was more suitable for my goal, I already have a lot of accessories to help keep everything good, oil cooler, a configuration of oil cans that have lowered the pressure in the crankcase, oil deflectors, oil pickup, ect. The last thing I need is to build the engine.
#16 |
Drives: Chevrolet Ram 250
You could get an IAG short block instead of building it. They also machine it to help the oiling issues.
I got a smooth brain.
| The Following User Says Thank You to Poogchomp For This Useful Post: | p1l0t (03-04-2022) |
#17 | |
Drives: Q5 + BRZ + M796
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | p1l0t (03-04-2022) |
#18 |
Drives: 2017 toyota 86
Doesn’t seem like stock block lasts long over the 3-350whp range regardless of octane.
But is there even any documentation of anyone even hitting 400whp on pump regardless of built block or lower compression or not? |
#19 |
The other thread claimed 693hp was the record on the stock block (probably not pump gas though). I'm sure that isn't a daily driver, lol.
Sent from my SM-G975U using Tapatalk |
#20 | |
300-320whp w/ sc or 330-350whp w/ turbo even on Ethanol seems the top end of reliable on stock block if you’re actually going to use the power. But reliability aside, I don’t think I’ve seen anyone hit 400whp+ on pump gas regardless of compression. |
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | p1l0t (03-04-2022) |
#21 | |
Drives: 2014 Subaru BRZ WRB
GTX2867R Gen 2. 18.5 Pounds. 420WHP On a Dynojet 93OCT. |
#22 |
#23 |
| The Following 2 Users Say Thank You to JOSEC For This Useful Post: | 86TOYO2k17 (03-05-2022), p1l0t (03-06-2022) |
#24 | |
What was the change from red to blue? |
#25 |
Drives: brz 2017 hksv2
i haven t understood if that is with stock compression or lowered? i guess lowered?
#26 |
2 different Maps.
Map 1, Red Line is gate pressure at 17 PSI. 380WHP I think somewhere around 320 TQ. Blue is Map 2, 18.5PSI More timing. 420 WHP. 347 TQ. Both gets on boost 3-3.5K. Lots of response, very linear power. It’s my track car, so there was more power with more aggressive timing. But wanted to keep it more conservative. |
| The Following 2 Users Say Thank You to JOSEC For This Useful Post: | 86TOYO2k17 (03-06-2022), p1l0t (03-06-2022) |
#27 |
| The Following 2 Users Say Thank You to JOSEC For This Useful Post: | 86TOYO2k17 (03-06-2022), tomm.brz (03-06-2022) |
#28 |
Howdy
Drives: 2020 BRZ PP
My understanding is you start eating transmissions and axels at those levels. So you change one thing in a huge way, you need to reenforce everything else ancillary to it. I’m just puttering around at 252whp, but also research for the “one day” thoughts.
The gen 2 transmission is supposedly stronger, but I’m not sure if it is a direct bolt-up.
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
| BRZ engine compression 13.5:1 or 12.5:1? | mangler | BRZ Second-Gen (2022+) — General Topics | 2 | 12-05-2021 05:16 PM |
| Lowering compression | Boris_Petrov | Forced Induction | 3 | 01-19-2019 05:19 AM |
| compression+boost? | subatoy | Forced Induction | 74 | 01-30-2015 04:32 PM |
| Low compression? | Venator | Engine, Exhaust, Transmission | 4 | 06-17-2014 10:37 AM |
| Low Compression - 10:1 // 9:1 | 1086 | Engine, Exhaust, Transmission | 12 | 12-13-2013 05:46 PM |
