#169 | |
Drives: 2016 FR-S (Halo MT)
https://www.ft86club.com/forums/show...ht=2016+wiring On the stock 10 pin connector, pin 9 is the amp for the antenna. If you look at the Autoharnesshouse connector, pin 9 is not connected to anything, so the amp is not receiving power. There was a connector provided in their harness that wasn't being used at all. I pulled I believe a red wire from that a connector, cut it and then added in to pin 9 of their 10 pin connector. I then spliced this wire to the blue "amp trigger" wire on the Pioneer connector. Attached is a picture of that. I'm pretty sure this was the process used for the fix. Unfortunately, I didn't take photos of the end result. If you want me to pull the radio and take photos of the harness and splice to confirm, let me know. |
| The Following User Says Thank You to Nails For This Useful Post: | Mike_ZN6 (05-03-2021) |
#170 | |
Drives: 2016 Toyota 86
Really appreciate you taking the time to look at this! I reached out to AutoHarnessHouse this morning and they have not yet responded. It appears my AutoHarnessHouse kit may be slightly different than yours for some reason. Not sure why because we have the same model year car and I ordered the kit for the 2016. On my AutoHarnessHouse 10 pin connector, it appears there is a blue wire in pin 9 that loops back in to pin 8. On the antenna adapter, there is no blue "amp trigger" wire at all. I an wondering if they sent me the wrong harness/antenna adapter? ![]() ![]() ![]() ![]() ![]()
#171 | |
#172 | |
Yeah, everything else is working perfectly. I did have to cut the pink wire as directed by this thread to resolve the muting Carplay audio while moving. I swear, the speakers sound quality is really noticeably better. Very happy with this head unit. Just need to get the radio reception problem sorted. |
#173 |
Master Collaborator
If your antenna adapter harness does NOT look like this one,
and it is missing the blue wire, then they need to send you the correct antenna adapter harness, because that blue wire in the picture here needs to be powered with +12 volts to power the antenna for proper radio reception. |
#174 | |
How long did it take them to get back to you? Going on 2 days now with no response from them. |
#175 |
#176 |
AutoHarnessHouse got back to me today. They are sending me a different direct wire adapter and also a new AM/FM adapter. Hopefully this gets the problem sorted out.
| The Following 2 Users Say Thank You to Mike_ZN6 For This Useful Post: | Nails (05-06-2021), Spankopotomous (05-07-2021) |
#177 |
I got the new direct wire and AM/FM adapters today. AutoHarnessHouse was nice enough to make the connection to the blue amp trigger wire on the AM/FM adapter before sending it out.
I connected everything back together and the AM/FM reception is working fine now. I am very impressed with this receiver. I will post some pics soon when I have time. |
| The Following User Says Thank You to Mike_ZN6 For This Useful Post: | Nails (05-11-2021) |
#178 |
Senior Citizen Member
Drives: Then-1977 Celica GT Now-2017 860SE
USB Storage Device - Capacity Limit?
I play FLAC audio files from a Samsung USB 3 thumb drive.
My 32 Gig drive is full and I just bought some more music. How large a thumb drive does the AVH-ZL5150BT support? How large and what brand of drive is anyone using? Thanks! |
#179 | |
https://www.howtogeek.com/316977/how...32-on-windows/ |
| The Following 2 Users Say Thank You to Nails For This Useful Post: | LimitedSlip (02-16-2022), omegared19 (02-23-2022) |
#180 | |
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following 2 Users Say Thank You to Dadhawk For This Useful Post: | LimitedSlip (02-16-2022), Nails (02-17-2022) |
#181 |
Drives: White 2013 BRZ Limited 6MT
Newb questions (and pardon my ignorance), so I'm pretty set on getting this head unit and harness. I know where I want to mount the mic and the usb port.
1) Is the usb port and wire long enough to go to cup holder area something additional I need to purchase? 2) Since I have a 2013, which came with no backup camera from the factory, is there one readily available or one you guys would recommend? |
#182 | |
https://www.amazon.com/gp/product/B00VAIEAUM It has a 3 foot cable, which was enough to reach to the back of the Pioneer AVH-ZL5150 head unit. This is where I have my USB flashdrive plugged in. Last edited by Nails; 02-24-2022 at 03:57 PM. |
| The Following 2 Users Say Thank You to Nails For This Useful Post: | Dadhawk (02-24-2022), omegared19 (02-24-2022) |
| Looking for suggestions on what carplay compatible head unit to get. | wparsons | Electronics | Audio | NAV | Infotainment | 8 | 03-02-2018 08:09 AM |
| Android head unit | drz400dude | Electronics | Audio | NAV | Infotainment | 6 | 12-20-2016 12:47 AM |
| 200mm android head unit with android lollipop | rsingh | Electronics | Audio | NAV | Infotainment | 3 | 05-23-2016 08:48 PM |
| New 200mm head unit from Pioneer AVIC-F7302 | Clot | Electronics | Audio | NAV | Infotainment | 8 | 09-16-2014 11:39 AM |
| Android head unit | drei | Electronics | Audio | NAV | Infotainment | 21 | 07-16-2012 02:42 AM |
