Old 05-03-2021, 06:32 PM   #169
Nails
Drives: 2016 FR-S (Halo MT)
Originally Posted by Mike_ZN6 View Post
I just installed the AVH-ZL5150 using the compete AutoHarnessHouse kit and my FM reception is horrible. I don't think I missed any connections, how can I check the antenna is powered?
I went back and took a look at my email's to Autoharnesshouse about the issue I was having with the radio reception. You'll need to refer to this post that has a diagram of the 2016 FR-S head unit stock connections:
https://www.ft86club.com/forums/show...ht=2016+wiring
On the stock 10 pin connector, pin 9 is the amp for the antenna. If you look at the Autoharnesshouse connector, pin 9 is not connected to anything, so the amp is not receiving power.
There was a connector provided in their harness that wasn't being used at all. I pulled I believe a red wire from that a connector, cut it and then added in to pin 9 of their 10 pin connector. I then spliced this wire to the blue "amp trigger" wire on the Pioneer connector. Attached is a picture of that.
I'm pretty sure this was the process used for the fix. Unfortunately, I didn't take photos of the end result. If you want me to pull the radio and take photos of the harness and splice to confirm, let me know.
Nails is offline   Reply With Quote
The Following User Says Thank You to Nails For This Useful Post:
Mike_ZN6 (05-03-2021)
Old 05-03-2021, 09:30 PM   #170
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
Attachment 200360
Really appreciate you taking the time to look at this! I reached out to AutoHarnessHouse this morning and they have not yet responded.
It appears my AutoHarnessHouse kit may be slightly different than yours for some reason. Not sure why because we have the same model year car and I ordered the kit for the 2016. On my AutoHarnessHouse 10 pin connector, it appears there is a blue wire in pin 9 that loops back in to pin 8. On the antenna adapter, there is no blue "amp trigger" wire at all.
I an wondering if they sent me the wrong harness/antenna adapter?
Mike_ZN6 is offline   Reply With Quote
Old 05-03-2021, 10:03 PM   #171
Nails
Very interesting. If that is the same harness, it does look like they changed it. I got mine back in 2019. When you hooked up the head unit, did everything else work correctly except for the antenna strength? According to their technical support person who got back to me, pin 9 needs 12 volts to power the antenna amp. Their loop back might not be providing any power.
Old 05-03-2021, 10:40 PM   #172
Mike_ZN6
Mike_ZN6's Avatar
Yeah, everything else is working perfectly. I did have to cut the pink wire as directed by this thread to resolve the muting Carplay audio while moving.
I swear, the speakers sound quality is really noticeably better. Very happy with this head unit. Just need to get the radio reception problem sorted.
Old 05-04-2021, 12:04 AM   #173
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
If your antenna adapter harness does NOT look like this one,
and it is missing the blue wire, then they need to send you the correct antenna adapter harness, because that blue wire in the picture here needs to be powered with +12 volts to power the antenna for proper radio reception.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
The Following 2 Users Say Thank You to FR-S2GT86 For This Useful Post:
Mike_ZN6 (05-04-2021), Nails (05-04-2021)
Old 05-04-2021, 01:35 PM   #174
Mike_ZN6
Mike_ZN6's Avatar
How long did it take them to get back to you? Going on 2 days now with no response from them.
Old 05-04-2021, 05:50 PM   #175
Nails
Their technical support got back to me the next day when I emailed them. The address I used to contact them was inquiry@autoharnesshouse.com.
Old 05-05-2021, 07:35 PM   #176
Mike_ZN6
Mike_ZN6's Avatar
AutoHarnessHouse got back to me today. They are sending me a different direct wire adapter and also a new AM/FM adapter. Hopefully this gets the problem sorted out.
The Following 2 Users Say Thank You to Mike_ZN6 For This Useful Post:
Nails (05-06-2021), Spankopotomous (05-07-2021)
Old 05-10-2021, 08:16 PM   #177
Mike_ZN6
Mike_ZN6's Avatar
I got the new direct wire and AM/FM adapters today. AutoHarnessHouse was nice enough to make the connection to the blue amp trigger wire on the AM/FM adapter before sending it out.
I connected everything back together and the AM/FM reception is working fine now. I am very impressed with this receiver. I will post some pics soon when I have time.
The Following User Says Thank You to Mike_ZN6 For This Useful Post:
Nails (05-11-2021)
Old 02-12-2022, 12:59 AM   #178
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
USB Storage Device - Capacity Limit?
I play FLAC audio files from a Samsung USB 3 thumb drive.
My 32 Gig drive is full and I just bought some more music.
How large a thumb drive does the AVH-ZL5150BT support?
How large and what brand of drive is anyone using?
Thanks!
LimitedSlip is offline   Reply With Quote
Old 02-16-2022, 10:19 AM   #179
Nails
Thanks!
I'm currently using a SanDisk 128GB Ultra Fit USB 3.1 flash drive with the head unit. You will need to format it for FAT32 using special software for it to work correctly. Here is a link to an article about that:
https://www.howtogeek.com/316977/how...32-on-windows/
The Following 2 Users Say Thank You to Nails For This Useful Post:
LimitedSlip (02-16-2022), omegared19 (02-23-2022)
Old 02-16-2022, 04:06 PM   #180
Yea, that's pretty common step to have to take. i have a 256GB mini-SD in the Pioneer AVIC-8200NEX in my Suburban that I did that with (reformatted as FAT32). It's worked flawlessly for 5 years.
LimitedSlip (02-16-2022), Nails (02-17-2022)
Old 02-23-2022, 01:20 PM   #181
omegared19
omegared19's Avatar
Drives: White 2013 BRZ Limited 6MT
Newb questions (and pardon my ignorance), so I'm pretty set on getting this head unit and harness. I know where I want to mount the mic and the usb port.
1) Is the usb port and wire long enough to go to cup holder area something additional I need to purchase?
2) Since I have a 2013, which came with no backup camera from the factory, is there one readily available or one you guys would recommend?
omegared19 is offline   Reply With Quote
Old 02-23-2022, 06:36 PM   #182
Nails
I can answer one of your questions. I replaced the cigarette lighter port in the armrest console with this extension cable that has both USB and 3.5mm auxiliary plugs:
https://www.amazon.com/gp/product/B00VAIEAUM
It has a 3 foot cable, which was enough to reach to the back of the Pioneer AVH-ZL5150 head unit. This is where I have my USB flashdrive plugged in.
Dadhawk (02-24-2022), omegared19 (02-24-2022)
Looking for suggestions on what carplay compatible head unit to get. wparsons Electronics | Audio | NAV | Infotainment 8 03-02-2018 08:09 AM
Android head unit drz400dude Electronics | Audio | NAV | Infotainment 6 12-20-2016 12:47 AM
200mm android head unit with android lollipop rsingh Electronics | Audio | NAV | Infotainment 3 05-23-2016 08:48 PM
New 200mm head unit from Pioneer AVIC-F7302 Clot Electronics | Audio | NAV | Infotainment 8 09-16-2014 11:39 AM
Android head unit drei Electronics | Audio | NAV | Infotainment 21 07-16-2012 02:42 AM
