Old 12-02-2021, 10:47 AM   #15
almostquick
Drives: 2017 BRZ PP
Not a platform specific application of the theory at hand but a good write up none the less.
https://www.motortrend.com/how-to/pinion-angle-change/
It’ll will be interesting to see the measured pinion angles of transmission and rear carrier. I’m due for an oil change soon and will see what mine are. Have an axle exchange alum driveshaft along with all of the whiteline transmission and rear carrier inserts.
almostquick is offline   Reply With Quote
Old 12-02-2021, 10:39 PM   #16
Turdinator
Señor Member
Turdinator's Avatar
I bought my carbon drive shaft used. At first I had horrible vibrations. It took me a few tries but eventually I found a driveshaft shop that both shimmed the uni joints to be centered and added balance weights and its been great ever since. I also have STi engine and gearbox mounts as well as a light flywheel so should be able to feel any new vibrations.
1974 TA22 Celica
2013 86 GT
The Following 2 Users Say Thank You to Turdinator For This Useful Post:
gpvecchi (12-03-2021), jcw99 (02-06-2022)
Old 12-23-2021, 04:07 PM   #17
almostquick
Drives: 2017 BRZ PP
So I just checked both pinion angles (rear diff side and trans side). Rear diff showed a +2 degrees of pinion angle while the trans side was at -5 degrees of pinion angle. This would put the trans side out of the ideal range of -3 degrees (assuming that ideal angles would be +/- 3 degrees at opposing ends.)
I have an axle exchange alum driveshaft, Perrin shifter bushing, and whiteline trans insert. Ideally I would be able to bring the trans side closer to -2degrees to match my opposing rear diff +2 however it looks like clearances are already very tight on the transmission side with the diameter of the driveshaft and it almost touching the perrin shifter mount. Any thoughts on potential ways to bring the trans side more in line? Has anyone else take taken pinion angles?
The Following User Says Thank You to almostquick For This Useful Post:
gpvecchi (12-23-2021)
Old 12-23-2021, 05:06 PM   #18
gpvecchi
gpvecchi's Avatar
The total ideal difference should be less than 1 degreee, and every side should be less than 3 degree. Your diff is ok, you have to correct the transmission angle.
You have to raise the gearbox, right? You should put a shim between the transmission support and its plate.
Keep in mind that rising the gearbox will change the diff angle too.
Old 12-29-2021, 11:59 AM   #19
almostquick
Drives: 2017 BRZ PP
Agree on the less than 1 degree (opposing) differences. I’ve read that you don’t want to go any further than 5 degrees and that 3 degrees is the optimum.
Yes, ideally I would raise the transmission to be closer to the opposing +2 degrees on the diff end. The issue arises with the fact that I (and I assume anyone else with a alum 1-piece driveshaft) do not have the clearance on the trans side to shim the trans to raise it and get it to -2/-3 degrees, as the driveshaft is almost coming in contact with the rear shifter mount bushing.
As a shear test to see if bringing the two inline will indeed fix the vibration problems we are experiencing, I might try to shim the diff to +5 degrees to be inline with the trans. This is not optimal but at least gets to the answer as to whether pinion angle is the culprit for the driveline vibration many experience.
Old 01-02-2022, 02:35 AM   #20
FrickingReallySlow
Drives: 2015 FR-S
So where on the diff should we use as the edge to measure the diff angle? I labelled (A,B,C) the areas where I think it could be close but there's no real guarantee that these edges are 100% parallel to the shaft inside.
I would say using the face of "A" where U-joint bolts to would be the most accurate but that requires removing the driveshaft so the face is exposed.
FrickingReallySlow is offline   Reply With Quote
Old 01-02-2022, 09:18 AM   #21
gpvecchi
gpvecchi's Avatar
Tha "A" place. I saw somebody putting a metal ruler "between" the diff face and the driveshaft and then use it as a flat surface.
The Following User Says Thank You to gpvecchi For This Useful Post:
FrickingReallySlow (01-02-2022)
Old 01-02-2022, 07:39 PM   #22
almostquick
Drives: 2017 BRZ PP
Location A. I had just enough surface area even with the driveshaft connected to put an angle finder on the face surface.
Old 01-25-2022, 08:07 PM   #23
FrickingReallySlow
Drives: 2015 FR-S
Measured my angles, 3.4 in the front and about 3.1 at the diff. One way I think this can be reduced is with the STI engine mounts (perhaps others too). They're used by ppl that has ACE350 headers to raise the engine slightly to clear the big ACE overpipe from subframe. Raising the engine and keeping the pivot point of the trans mount the same would reduce both angles slightly since the tail bushing would now be pointed slightly downward and also start lower in height (reducing the height difference between it and the diff). I guess here a softer trans mount that is more compressible could help (at least statically) since the pivot point would be lowered slightly
Old 01-26-2022, 03:45 AM   #24
gpvecchi
gpvecchi's Avatar
I have the STi supports and bushings. They don't raise the position, but they will flex less. The only way to change the angles are shims and spacers.
Did you check the angle of your driveshaft too?
Old 01-26-2022, 12:01 PM   #25
FrickingReallySlow
Drives: 2015 FR-S
Yeah those numbers are the angles between the engine to driveshaft and driveshaft to diff. I have an aluminum one. using my phone on these edges aren't very accurate (varies by a +/-0.2) depending on slight changes in how I hold the phone. So take it with a grain of salt.
Did you pull the trigger on your Carbon shaft purchase yet?
Old 01-27-2022, 02:59 AM   #26
gpvecchi
gpvecchi's Avatar
No, I quitted the idea as I didn't want to spend quite a lot of money to have issues.
Your angles are not that bad, you could try to lower the gearbox support with washers and longer bolts. You need around 1.5 degrees, you shouldn't need big spacers.
FrickingReallySlow (02-03-2022)
Old 02-05-2022, 03:49 AM   #27
9101
Drives: Toyota 86
You mind sharing who you used in Melbourne? Also, what this would cost? Cheers
9101 is offline   Reply With Quote
Old 02-07-2022, 05:07 PM   #28
Turdinator
Señor Member
Turdinator's Avatar
Indrotech in Hallam. They didn't have the means to attach the balance weights to the shaft so they taped them in place and I had to then glue them on. I got Loctite involved and used their recommendation which worked perfectly. I can't remember what it all cost me though I am sorry.
1974 TA22 Celica
2013 86 GT
1 Piece aluminum driveshaft Phothiraj Engine, Exhaust, Transmission 60 10-03-2016 05:53 PM
Does anyone track their car with a 1 piece DSS driveshaft? mhiscott Tracking / Autocross / HPDE / Drifting 3 08-10-2016 12:02 AM
Aluminum 1-piece Driveshaft Cjs_ Engine, Exhaust, Transmission 17 03-25-2015 04:45 PM
New The Driveshaft Shop Carbon Fiber 1-Piece Driveshaft Evasive Motorsports Engine, Exhaust, Transmission 1 09-24-2013 02:27 PM
