#43 |
Famous Potatoes
Drives: '15 ultramarine
| The Following 3 Users Say Thank You to Sapphireho For This Useful Post: |
#44 | |
Drives: 22 BRZ limited
If you hit the driveshaft on a speed bump, you have other issues. |
| The Following 2 Users Say Thank You to dragoontwo For This Useful Post: | blsfrs (01-28-2022), Ultramaroon (01-27-2022) |
#45 | |
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | blsfrs (01-28-2022), soundman98 (01-27-2022) |
#46 |
| The Following 2 Users Say Thank You to Grady For This Useful Post: | blsfrs (01-28-2022), Ultramaroon (02-17-2022) |
#47 |
Famous Potatoes
It's just a suspiciously clean break. I would expect something more like this.
| The Following 6 Users Say Thank You to Sapphireho For This Useful Post: | bcj (01-28-2022), blsfrs (01-28-2022), Grady (01-27-2022), soundman98 (01-27-2022), Turdinator (01-27-2022), Ultramaroon (01-27-2022) |
#49 |
Famous Potatoes
| The Following 4 Users Say Thank You to Sapphireho For This Useful Post: |
#50 |
Thank you for that, btw
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | blsfrs (01-28-2022), Sapphireho (01-28-2022) |
#51 |
Drives: 2013 frs base
What?
Here is the response from DDS. It leaves a lot to be desired.
Clifton (Driveshaft Shop) Feb 10, 2022, 1:11 PM EST Good afternoon. We calculated the critical speed rating to be around 110-115mph. There are a couple of different options for moving forward. If you're interested in upgrading to the carbon fiber we can do that, Also, we can make a 3.5 inch aluminum shaft, but we'd just need to make sure that it clears everything under the car. let me know what you would like to do. thank you The Driveshaft Shop 4530 Southmark Dr. Salisbury, NC 28147 (800)564-2244 |
| The Following User Says Thank You to blsfrs For This Useful Post: | NoHaveMSG (02-10-2022) |
#52 | |
Drives: Crapcan
Sounds to me like they are claiming vibration from critical speed caused it to fail. Critical speed has been brought up as a reason for vibration in a thread before. Not exactly a confidence inspiring answer. Edit: I messaged them talking shit. I absolutely don't feel comfortable with the one I have as a spare. Couldn't imagine if it failed on track suddenly like that.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | blsfrs (02-11-2022) |
#53 |
Wikipedia reference, so take it for what it's worth:
All rotating shafts, even in the absence of external load, will deflect during rotation. The unbalanced mass of the rotating object causes deflection that will create resonant vibration at certain speeds, known as the critical speeds. And Many practical applications suggest as good practice that the maximum operating speed should not exceed 75% of the critical speed. |
| The Following User Says Thank You to blsfrs For This Useful Post: | Ultramaroon (02-17-2022) |
#54 | |
#55 | |
Drives: Crapcan
The carbon shafts seem to fair better. Don’t know what the CS is. That’s math above my pay grade.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | blsfrs (02-13-2022) |
#56 | |
Famous Potatoes
I say good job DSS. |
| The Following User Says Thank You to Sapphireho For This Useful Post: | blsfrs (02-13-2022) |
| Drive Shaft Shop CF Drive Shaft BNIB (Auto trans) | Lefty-FRS | Transmission and Driveline | 13 | 02-09-2018 10:02 PM |
| OEM drive shaft | Baramzisyan | Transmission and Driveline | 13 | 03-22-2014 03:25 PM |
| Scion FR-S / Subaru BRZ Drive Shaft Shop Carbon Fiber Drive Shafts In Stock | Anthony@RWHP | Transmission and Driveline | 4 | 12-25-2013 08:09 PM |
| Does FRS come with Carbon drive shaft? | STi88 | Engine, Exhaust, Transmission | 30 | 07-30-2012 01:40 PM |
