Old 01-22-2022, 03:06 PM   #1
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Broken drive shaft
Fortunately it failed on the dyno and not on the road. One year old DDS aluminum drive shaft. No warning NVM. Tech said the bolts had worked loose. Hard way to learn a lesson: Check and retorque bolts.
Old 01-22-2022, 03:42 PM   #2
Code Monkey
Drives: Subaru BRZ
Did you reuse nuts and bolts?
Code Monkey is offline   Reply With Quote
Old 01-22-2022, 05:16 PM   #3
Ashikabi
Ashikabi's Avatar
Use blue locktite
Old 01-22-2022, 05:19 PM   #4
Joon525
Joon525's Avatar
Drives: 2016 BRZ
Damn, what does the underside of the car look like? Any major damage?
Joon525 is offline   Reply With Quote
Old 01-22-2022, 07:54 PM   #5
stacyu18
Drives: 2014 subaru brz
looks like to me its a bad driveshaft no way loose bolts cause that but where is the carrier bearing at?
stacyu18 is offline   Reply With Quote
The Following 2 Users Say Thank You to stacyu18 For This Useful Post:
humfrz (01-22-2022), Opie (01-27-2022)
Old 01-22-2022, 08:49 PM   #6
humfrz
I'll go with the "bad driveshaft" theory.
Is that blood all over the floor? -
Old 01-22-2022, 09:34 PM   #7
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Yikes! I have a stock driveshaft if for free. You just gotta pay for shipping from California.
The Following User Says Thank You to EAGLE5 For This Useful Post:
alphasaur (02-16-2022)
Old 01-23-2022, 12:20 AM   #8
demasrv
demasrv's Avatar
Drives: 2013 Rally Blue BRZ
Oooof. The red stuff on the floor makes it look like the driveshaft died a horrible bloody death.
How's the underside of the car look?
demasrv is offline   Reply With Quote
Old 01-23-2022, 10:35 AM   #9
blsfrs
blsfrs's Avatar
First of all, I'm not answering any questions about possible blood on the floor.
There was no damage to the underside of the car. The tuner shut it down as soon as he heard/felt it go.
PTuning already sourced a replacement shaft. Thanks for the offer
It's a one piece DDS aluminum shaft.
Yes, I reused the bolts.
And yes to the Loctite.
I'll add checking driveshaft to my pre-track check list.
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
Code Monkey (01-23-2022), NoHaveMSG (01-24-2022)
Old 01-23-2022, 11:48 AM   #10
soundman98
ProCrastinationConsultant
soundman98's Avatar
...pending litigation and all that
i'm sure tommy had it coming.
The Following 4 Users Say Thank You to soundman98 For This Useful Post:
blsfrs (01-23-2022), NoHaveMSG (01-24-2022), Spuds (01-25-2022), Ultramaroon (01-23-2022)
Old 01-23-2022, 02:48 PM   #11
Grady
Grady's Avatar
I bet when it went the drivers seat got totaled!
The Following 8 Users Say Thank You to Grady For This Useful Post:
alphasaur (02-16-2022), Jdmjunkie (01-23-2022), Muffled (11-16-2024), soundman98 (01-23-2022), Spuds (01-25-2022), Ultramaroon (01-23-2022), Wally86 (01-25-2022), x808drifter (01-24-2022)
Old 01-24-2022, 02:49 AM   #12
FrickingReallySlow
Drives: 2015 FR-S
Subaru notes these as one time use items but I never understood why, if its not rusty/striped what's the mechanical reason they can't be reused?
FrickingReallySlow is offline   Reply With Quote
The Following User Says Thank You to FrickingReallySlow For This Useful Post:
blsfrs (01-24-2022)
Old 01-24-2022, 04:56 AM   #13
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Looks like a two piece shaft to me!?
The Following 7 Users Say Thank You to Sapphireho For This Useful Post:
alphasaur (02-16-2022), Muffled (11-16-2024), NoHaveMSG (01-24-2022), Spuds (01-25-2022), Ultramaroon (01-24-2022), Wally86 (01-25-2022), x808drifter (01-24-2022)
Old 01-24-2022, 08:31 AM   #14
Code Monkey
Drives: Subaru BRZ
Maybe the bolts are TTY?
Drive Shaft Shop CF Drive Shaft BNIB (Auto trans) Lefty-FRS Transmission and Driveline 13 02-09-2018 10:02 PM
OEM drive shaft Baramzisyan Transmission and Driveline 13 03-22-2014 03:25 PM
Scion FR-S / Subaru BRZ Drive Shaft Shop Carbon Fiber Drive Shafts In Stock Anthony@RWHP Transmission and Driveline 4 12-25-2013 08:09 PM
Does FRS come with Carbon drive shaft? STi88 Engine, Exhaust, Transmission 30 07-30-2012 01:40 PM
