Old 01-26-2022, 09:12 AM   #29
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Originally Posted by FrickingReallySlow View Post
Turning it 4 times to try to get rid of vibration is def PITA having to get new bolts each time. But also there were a couple of threads a while back about the bolts being too short with aftermarket shafts and results in only half your nuts thread engaging. Solution was to get longer bolts so that all threads engage. I still haven't done it yet on mine @blsfrs do you remember if all the threads engaged on yours?
I'll get some close up pictures of the break and mounting flanges of the 2 drive shafts.
Thanks for all of the input.
I did find out that there is a 1 year warranty on DDS aluminum shafts. My receipt is dated 12/20/2020. It broke on 01/14/2022. I've emailed Vivid racing and DDS but have not yet heard back.
Old 01-26-2022, 12:04 PM   #30
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
On my DSS AL I had full thread engagement.
Originally Posted by EAGLE5 View Post
It's probably gonna be fine 999/1000 times in the first year.
But that 1/1000 is bad enough for a safety recall. 1/1000 * 100,000 cars is 100 failed cars that could kill people in the first year. And then the car companies look at a car's life over 20-30 years, and they start to sweat, because that 100 failures can become 10,000 or more if things go badly. Hence we get our valve springs recalled.
But you? In a car you probably inspect often? Fuggetaboutit.
Fair enough point.
@blsfrs I would call, not just email. If they don't help you out let me know. I have another spare stock drive shaft and a DSS AL that are both used. You can have either one for the cost of shipping. I only need to keep one as a spare and I have both these laying around.
Old 01-26-2022, 05:58 PM   #31
blsfrs
blsfrs's Avatar
The DDS flange is quite a bit thicker. If I ever again use a non-stock drive shaft I'll use longer bolts. @NoHaveMSG: Thank you for your kind offer. PTuning sourced a shaft while they had it in the shop.
The Following User Says Thank You to blsfrs For This Useful Post:
NoHaveMSG (01-26-2022)
Old 01-26-2022, 06:13 PM   #32
blsfrs
blsfrs's Avatar
Once the rear u-joint loosened enough for it to spin off axis, it was doomed. Still being fastened at both ends, it buckled like a bent straw. It looks like it may also have gotten scored rubbing against maybe the exhaust. Once a crack started, torque quickly finished the job.
Whole lotta guesswork based on those pics.
Pictures will probably lead to more guess work but here they are. Rubbing enough to cause scoring would make noise and I ain't that deaf yet. I would have thought that loose enough to deform would have been loose enough to cause perceptible vibration and my butt ain't that numb either.
Ultramaroon (01-26-2022)
Old 01-26-2022, 07:01 PM   #33
Grady
Grady's Avatar
Not enough definition in the pictures to tell. We will need to see grain structure in order to make a guess. What you are looking for is part of the separation being shiny and another part not, this is an indication of a fracture that was there prior to the failure.
Other thing you will be looking for is the rough fracture, Is the scoring folder over the fracture. An indication that the scoring happened after. Is the scoring not folder over, an indication the scoring happened prior to the fracture. This may be visible with a magnifying glass.
The Following User Says Thank You to Grady For This Useful Post:
blsfrs (01-27-2022)
Old 01-26-2022, 08:21 PM   #34
Even with the blurry pic, I clearly see a perfect circumferential cut which coincides with the failure point. Where your rear mounting screws really loose? Perhaps there was some intermittent contact with the exhaust leading up to the failure. Regardless, that's it. Doesn't take much to create a stress riser. It's like cutting glass. Sharp corners fracture easily.
blsfrs (01-27-2022), soundman98 (01-26-2022)
Old 01-27-2022, 08:52 AM   #35
blsfrs
blsfrs's Avatar
IMHO, What appears as scoring is probably because the broken ends of the shaft were rotating on the deck of the dyno for several seconds after it let go.
Ultramaroon (01-27-2022)
Old 01-27-2022, 09:55 AM   #36
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Subaru notes these as one time use items but I never understood why, if its not rusty/striped what's the mechanical reason they can't be reused?
Because bolts actually stretch when they are tightened to reach their torque value. Almost all driveline and suspension bolts are single use and should be used/torqued only once.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following User Says Thank You to Opie For This Useful Post:
blsfrs (01-27-2022)
Old 01-27-2022, 12:06 PM   #37
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
If you flip the right side around and look at where the broken 'tab' fits into the left side, you can see a clear mark around the circumference that continues on both pieces. Definitely got scored prior to failure.
MS Paint skills below:
CrowsFeast is offline   Reply With Quote
The Following 2 Users Say Thank You to CrowsFeast For This Useful Post:
blsfrs (01-27-2022), Ultramaroon (01-27-2022)
Old 01-27-2022, 12:24 PM   #38
blsfrs
blsfrs's Avatar
I guess the next step is to jack the car up and look for evidence of rubbing. The car is at stock ride height and has the oem midpipe. I don't recall running over anything that would have hit the driveshaft.
Old 01-27-2022, 12:46 PM   #39
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
An unfortunate contact with a speed bump is as likely as damage from the undercarriage.
The Following 2 Users Say Thank You to bcj For This Useful Post:
blsfrs (01-28-2022), Ultramaroon (01-27-2022)
Old 01-27-2022, 02:34 PM   #40
That would leave a helical mark.
bcj (01-28-2022), blsfrs (01-28-2022)
Old 01-27-2022, 02:52 PM   #41
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
And a dent in the exhaust.
The Following 3 Users Say Thank You to dragoontwo For This Useful Post:
blsfrs (01-28-2022), Muffled (11-16-2024), Ultramaroon (01-27-2022)
Old 01-27-2022, 02:57 PM   #42
Oh, yeah! Duh.
New *cough* twist: Exhaust briefly shoved into driveshaft while traversing speed bump. Package of fail arrives two weeks later.
bcj (01-28-2022), blsfrs (01-28-2022), CrowsFeast (01-31-2022)
Drive Shaft Shop CF Drive Shaft BNIB (Auto trans) Lefty-FRS Transmission and Driveline 13 02-09-2018 10:02 PM
OEM drive shaft Baramzisyan Transmission and Driveline 13 03-22-2014 03:25 PM
Scion FR-S / Subaru BRZ Drive Shaft Shop Carbon Fiber Drive Shafts In Stock Anthony@RWHP Transmission and Driveline 4 12-25-2013 08:09 PM
Does FRS come with Carbon drive shaft? STi88 Engine, Exhaust, Transmission 30 07-30-2012 01:40 PM
