Old 01-27-2022, 03:58 PM   #43
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
blsfrs (01-28-2022), soundman98 (01-27-2022), Ultramaroon (01-27-2022)
Old 01-27-2022, 03:58 PM   #44
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Oh, yeah! Duh.
New *cough* twist: Exhaust briefly shoved into driveshaft while traversing speed bump. Package of fail arrives two weeks later.
It would be hard to ignore the racket. I also think it would more properly be a crushed exhaust.
If you hit the driveshaft on a speed bump, you have other issues.
The Following 2 Users Say Thank You to dragoontwo For This Useful Post:
blsfrs (01-28-2022), Ultramaroon (01-27-2022)
Old 01-27-2022, 04:03 PM   #45
Good thing I'm not getting paid for this.
Old 01-27-2022, 04:27 PM   #46
Grady
Grady's Avatar
And a dent in the exhaust.
Could have been a City Titti.
The Following 2 Users Say Thank You to Grady For This Useful Post:
blsfrs (01-28-2022), Ultramaroon (02-17-2022)
Old 01-27-2022, 06:18 PM   #47
Sapphireho
Famous Potatoes
Sapphireho's Avatar
It's just a suspiciously clean break. I would expect something more like this.
The Following 6 Users Say Thank You to Sapphireho For This Useful Post:
bcj (01-28-2022), blsfrs (01-28-2022), Grady (01-27-2022), soundman98 (01-27-2022), Turdinator (01-27-2022), Ultramaroon (01-27-2022)
Old 01-27-2022, 09:38 PM   #48
Grady
Grady's Avatar
Now that is a failure from more torque than the drive shaft was designed for.
The Following User Says Thank You to Grady For This Useful Post:
blsfrs (01-28-2022)
Old 01-27-2022, 09:41 PM   #49
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Yes, I know. I was posting more to show how aluminum usually bends and rips, not a perfect cut like a pipe cutter.
The Following 4 Users Say Thank You to Sapphireho For This Useful Post:
bcj (01-28-2022), blsfrs (01-28-2022), soundman98 (01-27-2022), Ultramaroon (01-27-2022)
Old 01-27-2022, 10:00 PM   #50
Thank you for that, btw
blsfrs (01-28-2022), Sapphireho (01-28-2022)
Old 02-10-2022, 02:24 PM   #51
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
What?
Here is the response from DDS. It leaves a lot to be desired.
Clifton (Driveshaft Shop)
Feb 10, 2022, 1:11 PM EST
Good afternoon. We calculated the critical speed rating to be around 110-115mph. There are a couple of different options for moving forward. If you're interested in upgrading to the carbon fiber we can do that, Also, we can make a 3.5 inch aluminum shaft, but we'd just need to make sure that it clears everything under the car. let me know what you would like to do.
thank you
The Driveshaft Shop
4530 Southmark Dr.
Salisbury, NC 28147
(800)564-2244
The Following User Says Thank You to blsfrs For This Useful Post:
NoHaveMSG (02-10-2022)
Old 02-10-2022, 02:43 PM   #52
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
thank you
The Driveshaft Shop
4530 Southmark Dr.
Salisbury, NC 28147
(800)564-2244
lol.
Sounds to me like they are claiming vibration from critical speed caused it to fail. Critical speed has been brought up as a reason for vibration in a thread before. Not exactly a confidence inspiring answer.
Edit: I messaged them talking shit. I absolutely don't feel comfortable with the one I have as a spare. Couldn't imagine if it failed on track suddenly like that.
blsfrs (02-11-2022)
Old 02-12-2022, 04:46 PM   #53
blsfrs
blsfrs's Avatar
Wikipedia reference, so take it for what it's worth:
All rotating shafts, even in the absence of external load, will deflect during rotation. The unbalanced mass of the rotating object causes deflection that will create resonant vibration at certain speeds, known as the critical speeds.
And
Many practical applications suggest as good practice that the maximum operating speed should not exceed 75% of the critical speed.
Old 02-12-2022, 04:56 PM   #54
dragoontwo
dragoontwo's Avatar
lol.
That's a shit critical speed for this car. I wonder what the carbon shaft speed is? Just as low?
The Following 3 Users Say Thank You to dragoontwo For This Useful Post:
blsfrs (02-13-2022), Muffled (11-16-2024), NoHaveMSG (02-13-2022)
Old 02-12-2022, 10:22 PM   #55
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The carbon shafts seem to fair better. Don’t know what the CS is. That’s math above my pay grade.
blsfrs (02-13-2022)
Old 02-12-2022, 11:24 PM   #56
Sapphireho
Famous Potatoes
Sapphireho's Avatar
thank you
The Driveshaft Shop
4530 Southmark Dr.
Salisbury, NC 28147
(800)564-2244
WTF? Sounds like they want to work with you for a solution? What more so you want?
I say good job DSS.
blsfrs (02-13-2022)
Drive Shaft Shop CF Drive Shaft BNIB (Auto trans) Lefty-FRS Transmission and Driveline 13 02-09-2018 11:02 PM
OEM drive shaft Baramzisyan Transmission and Driveline 13 03-22-2014 04:25 PM
Scion FR-S / Subaru BRZ Drive Shaft Shop Carbon Fiber Drive Shafts In Stock Anthony@RWHP Transmission and Driveline 4 12-25-2013 09:09 PM
Does FRS come with Carbon drive shaft? STi88 Engine, Exhaust, Transmission 30 07-30-2012 02:40 PM
