Old 12-22-2021, 04:53 AM   #15
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
You guys need to chill out with the coolant colour though, you can get asian PHOAT coolant in a variety of colours.
Subaru's hot sauce isn't blue because of magic, it's blue because it's dyed blue.
Old 12-22-2021, 05:52 AM   #16
Yes but it is dyed blue for a reason. The different coolants are different colours to distinguish between the chemical makeup. It isn't a fashion choice and they should not be mixed. Just because some place goes against the norm and makes random colours doesn't make it suddenly OK to mix the types.
omegared19 (01-24-2022), Poogchomp (12-22-2021), soundman98 (12-22-2021), x808drifter (12-23-2021)
Old 12-22-2021, 09:11 PM   #17
RZNT4R
Thanks for discharging the equivalent of over a thousand pounds of CO2 in the atmosphere.
You did a bad.
Old 12-22-2021, 09:35 PM   #18
soundman98
ProCrastinationConsultant
soundman98's Avatar
i was in high school in the early 2000's. back when gm's dexcool cars started all the issues of people just putting the good ol' green stuff back in, 'because they knew better'...
i've sat on the side of the road from the aftermath in friends cars. i've seen the repair bills, at least before the car was scrapped because it cost too much to repair.
i'm not claiming that subaru's flavor of coolant tastes better or is in any way more superior, i'm only saying that these cars came with that flavor, and for anyone to make the choice to alter it to a different color/brand/type means that you're taking matters into your own hands, and bad shit happening ain't out of the question anymore. unless you've done the research to make sure that a different variant of coolant isn't going to soften silicones, or deteriorate gaskets, it's always a bad idea to change coolant types.
Old 12-22-2021, 09:36 PM   #19
soundman98
soundman98's Avatar
Originally Posted by Zaraia View Post
This might be a stupid question but was i supposed to pull the metal hoses from the engine bay? It made a huge explosion of a funky smelling oily liquid. I nearly pooped myself.
that sound indicated you need to get the car to a qualified mechanic.
Old 12-22-2021, 09:51 PM   #20
Zaraia
Drives: 2015 Scion Frs
Well the car is in pieces in my backyard with no way to move it. Any recommendations? Atleast the heater core/ a/c unit is out.
Zaraia is offline   Reply With Quote
Old 12-22-2021, 09:58 PM   #21
soundman98
soundman98's Avatar
check your insurance. mine covers towing for something like 50 miles. usually plenty of shops within that radius.
Old 12-22-2021, 10:35 PM   #22
Zaraia
This a/c delete is looking more and more likely…the rule of buy once cry once prevails once again. lesson learned i guess. 😭
Old 12-22-2021, 10:38 PM   #23
Zaraia
If i take it to a mechanic who knows how long it’ll be in for, also we are at the end of the year which is going to make the whole ordeal longer, thats why i was trying to do it myself, also I'm dead set on learning things. Thank you guys for the humor though its making this experience bearable truly.
Old 12-22-2021, 11:02 PM   #24
soundman98
soundman98's Avatar
historically, beginning of the year is a slower time for the trade/service industries, as everyone blew their wads on the holiday's and big family events, so nothing left to repair that nagging vehicle issue.
meaning most of the shops are usually eager for work, and faster turnaround. just gotta call and ask.
Old 12-23-2021, 04:46 AM   #25
Project_1796
Drives: Scion FRS 10 series
Oops yes, you were supposed to have a shop recover the freon before disconnecting the line, replace the heater core, put the a/c line back in and you can recharge the a/c system. You might want to check on your radiator for any leaks too.
Project_1796 is offline   Reply With Quote
Old 12-23-2021, 06:36 AM   #26
RZNT4R
Yes, change coolant *TYPES*
Like Subaru's blue Super Coolant and Toyota's pink Super Long Life Coolant are both PHOAT, the color difference means nothing. I'm not saying to just dump green prestone from 50 years ago in there.
But what I'm getting at here is that I've seen this tendency a few times on here, where someone comes in with a picture of a leak or some shit and instead of helping, the fluid itself becomes the topic of the conversation.
That needs to stop.
It's OK to mention it so it gets properly flushed and refilled with the right stuff once it's repaired, but it shouldn't become the top issue.
Old 12-23-2021, 01:05 PM   #27
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
The A/C goes into the interior manifold too and if that system fails in the heater box there is some lubricant in the refrigerant lines.
The color of that may have some relevance in diagnosis.
What are the common colors for random A/C lube?
Does R-134a make your voice squeeky if all the windows are rolled up?
Old 12-23-2021, 02:13 PM   #28
RZNT4R
AC lubes are clear or green. You don't want to be in an enclosed space if a system vents, 1 pound of that stuff discharging in a large shop is REALLY unpleasant. Discharging a pound inside a car... you're gonna have a bad time, or the time of your life if you're into that, but it might be your last time.
OP deleted their post but they yanked the lines from the H valve and dumped the whole system, the oily mess was not red.
The Following User Says Thank You to RZNT4R For This Useful Post:
How is it possible to lose coolant, if the coolant system in a car is a closed loop, ghostzfh Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 09-12-2020 01:09 AM
Coolant level dropping & Dirty coolant redwine Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 44 09-30-2018 08:37 PM
Coolant loss - Void Warranty/ Edit: coolant flush question BRZach Engine, Exhaust, Transmission 15 01-02-2016 08:21 PM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 05:56 PM
Still Leaking? 636 Issues | Warranty | Recalls / TSB 15 01-11-2013 03:41 PM
