Old 12-10-2021, 07:56 AM   #43
ROADRACER
Drives: unlimited cheap build N/A track car
Originally Posted by RedReplicant View Post
This is what has been discussed elsewhere https://www.dcemotorsport.com/Home/EPAS
The units look very similar to what I ran in my Miata, which is a Koyo from a Saturn Vue (and other cars). The Pro Street ECU looks the same as my control unit and also has the same harness w/ rheostat to control assist.
I would be kind of curious to see what failsafe mode is like on the units we have. Normal assist or turns off completely?
Thanks. I didn't realize we were talking about a stand alone system. With the CAN-bus system in our cars I would be surprised if it would still drive and not go into some limp mode or have other serious issues.
ROADRACER is offline   Reply With Quote
Old 12-10-2021, 10:11 AM   #44
Icecreamtruk
Drives: Track preped NA FRS
For what its worth, I run the EPS with its control module as a "standalone" on my LS swap. I just give it power and nothing else and its working at 100% strength all the time. After a year of testing the car at the track I've had many issues, but none of them are related to power steering. That thing stays strong and constant thru the whole session, regardless of loads. So the failsafe that gets triggered is probably not needed and if it could be disable I highly doubt any actual damage would happen to the unit.
Good luck on your problem, it was my problem as well until I swapped engines
Icecreamtruk is offline   Reply With Quote
The Following 2 Users Say Thank You to Icecreamtruk For This Useful Post:
ML (12-21-2021), RedReplicant (12-10-2021)
Old 12-14-2021, 09:34 AM   #45
ROADRACER
I would be kind of curious to see what failsafe mode is like on the units we have. Normal assist or turns off completely?[/QUOTE]
If you are referring to the stock 86 EPS unit, i can tell you exactly what it is like. The electric assist suddenly turns off. It does this at very high load moments, so the steering effort instantly becomes MUCH harder. Its not a good feeling, and can make it difficult to maintain a smooth line as it turns off and then back on. I am use to it now, but still hate it.
Old 12-24-2021, 03:59 AM   #46
treedodger
treedodger's Avatar
Drives: 2022 GR86 (was 2013 BRZ)
I experience almost the exact same thing on my 2013 when switching to higher grip tires, in high g corners. Almost stock ride height w/ 7k/8k springs. It feels like the electric assist just stops completely during heavy trail braking or cornering.
No sign of rubbing inside the fender well.
2022 GR86 / 2013 BRZ
86drivechallenge.com/
treedodger is offline   Reply With Quote
Old 01-13-2022, 12:48 PM   #47
ROADRACER
yea, Its a fairly common problem for track cars that are pushed. Reducing castor helps, but not a lot. It could probably be fixed with a software/firmware update, but I think it is buried so deep in the programming that it would require Subaru engineers/programmers to fix it, and I don't think they really care about our problems.
The steering issue and rear wheel hop when power sliding in the rain are the two things that bother me the most with my car. I have been unsuccessful fixing either of those issues.
The Following 4 Users Say Thank You to ROADRACER For This Useful Post:
DocWalt (01-13-2022), Jdmjunkie (01-13-2022), RedReplicant (04-17-2022), treedodger (01-17-2022)
Old 04-17-2022, 11:20 AM   #48
amirnew
Drives: 2013 BRZ sprintex SC
guessing this was not sorted for anyone,
happans to me also now after upgrading to sem-slick tyres... really scary and really not safe.
someone knows the reason? maybe givving the EPS direct power line from the battery trough a relay can solve the issue?
does someone has the equipment to measure the power to the EPS and see if there are major drops due to high current draw?
if that will be the cause than we can have "easy" fix.
did someone tried givving the EPS power directely from the battery before?
really need to fix this issue....
amirnew is offline   Reply With Quote
Old 04-17-2022, 01:35 PM   #49
RedReplicant
Drives: None
I was able to lessen it by fixing some interference, but it didn't go away.
edit: Ordered a 2017+ module to test, worth a try since they are cheap
RedReplicant is offline   Reply With Quote
Old 04-17-2022, 07:50 PM   #50
churchx
churchx's Avatar
Drives: 2014 GT86
Do report here, if it will help. There are many that still track their early model twins.
Old 04-18-2022, 11:06 PM   #51
Kelse92
At the track
Drives: '14 FRS - Former e92 M3
Has anyone attempted to run an air duct up toward the location of the unit and get some cool air there? A friend of mine had a similar issue on a C7 Z06 and a air duct helped
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
Kelse92 is offline   Reply With Quote
Old 04-23-2022, 08:31 PM   #52
treedodger
treedodger's Avatar
I think it's and overload issue, not an overheating issue, because it seems to happen as much in the beginning of track session as the end (on cool days).
The good news is I found a fix: Buy a 2022!
Old 05-24-2022, 01:11 PM   #53
ClayMan
Drives: 22 BRZ
Had this happen on a 2022 yesterday. Not a good feeling approaching a corner at high speeds!
ClayMan is offline   Reply With Quote
Old 05-24-2022, 01:39 PM   #54
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Yup, keeps happening on my 2022 too. Some corners are worse than others.
Old 05-24-2022, 02:25 PM   #55
RedReplicant
Drives: None
My car is still in pieces, but I want to try what Icecreamtruk is doing before I swap in the newer module I bought. It sounds like you can run it with no CAN integration, just power, and it no longer has cut out. I don't know what this means for an otherwise stock car since we are both on standalone ECUs, mine a Haltech with stock CAN integration.
It is pretty terrible to hear this is an issue in the new gen too.
Old 07-03-2022, 02:13 PM   #56
Spartan117
Drives: 2022 brz rr660 -2.8/2 camber
Dont mean to revive a dead thread, but its pretty obvious on the new gen as well and I'm hoping to ID a fix.
So while I don't have a fix. I'm able to replicate every time give exception to cool down laps.
It only happens to me while I'm entering a turn where the track is graded downhill [so the majority of the weight of the car is on the front-end] while I'm trailbraking.
It happens while I'm turning both right or left and I'm not turning the wheel past 9/3 o'clock [validated by video] and it only happens on the downhillish turns between 70-80mph [via video/gps].
Running a 2022brz, hats/RLCA -2.8/2 camber on 17" rt660s.
Spartan117 is offline   Reply With Quote
Steering issue under braking ! AJ PwR Tracking / Autocross / HPDE / Drifting 146 04-25-2023 05:47 PM
Possible Steering Issue ? TJB_902 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 06-24-2015 01:38 AM
power steering ender2664 Engine, Exhaust, Transmission 32 03-21-2015 04:16 PM
Steering wheel issue Khalis Issues | Warranty | Recalls / TSB 1 05-04-2013 01:19 AM
Electric power steering madfast Scion FR-S / Toyota 86 GT86 General Forum 33 10-13-2011 10:11 AM
